Old 11-24-2004, 02:20 PM   #1
Deemeetree
Electrician
Deemeetree's Avatar
Send a message via AIM to Deemeetree
Default [FAQ] How-To: Removal and Installation of a Distributor O-Ring.
I know it's a fairly simple install, but to one (as myself) who doesn't really wrench away at an engine (only when something breaks) constantly, here's a write-up if you ever find any oil coming from the bottom of the distributor.
There was oil under the distributor, on top of the transmission, and everywhere in that area. I pin-pointed the culprit to be the distributor o-ring.
Thanks to Luserkid for helping me out and making it easier, on my other thread, regarding this subject.
Step 1:
With something straight, mark where your distributor is already at so your timing won't be affected. I used my trusty Architect's Scale.
Step 2:
Make a nice straight line with a nail or a screw. Now, whenever you need to do any sort of adjustment, you know where the stock timing is. If you need to change your timing for power, that's another story, but I'm probably NEVER going to do that.
Step 3:
Remove the first bolt that holds it in place. I took Luserkid's advice, and started with the bolt closest to the firewall. Use a 12mm box wrench.
Step 4:
Then, remove the bolt closest to the front of the car (sorry for the blurry pic, Macro pwnz me).
Step 5:
Then, the last bolt, the upper one.
Step 6:
Pull it out SLOWLY. This is the distributor removed.
This is why I think it's the culprit:
Steady build-up of oil at the bottom coming from here.
Step 7:
Remove the o-ring with a needle-nose plier or small flat-head screwdriver. If you have lots of tools, a need-nose pick will do good.
The second I grabbed the o-ring, it cracked right in half. It felt VERY dry aswell, which, I think, is the reason is was leaking.
Step 8:
Install the new o-ring with a little bit of engine oil just to lubricate it.
Step 9:
MAKE SURE YOU DON'T TURN ANYTHING (FINS). PLACE IT BACK SLOWLY AND MAKE SURE THE FINS ENTER THE GROOVES INSIDE THE HEAD.
Step 10:
Bolt everything back nice and snug and line up your distributor with the line you made earlier.
You're done.
Before you install the distributor back on, you might want to take a rag and use some degreaser and get into the cracks as much as you can under the cylinder head and on top of the transmission. Clean it off good and start her right up.
No CEL's and no pinging. Seems to have worked.
Honda Part # 30110-PA1-732. $2.22 at Honda.
Check http://www.slhondaparts.com for your Part #. Might be the same for all D-Series, it might not. Double check.
Thanks.
Modified by Dimi at 2:39 PM 11/24/2004
Aegean Wiring and Lighting
dspanoudakis@hotmail.com
E-mail me for all types of electrical work needed in the Tri-State area.
K.G.K. Electrical Contracting
Deemeetree is offline Report Post   Reply With Quote
Old 11-24-2004, 02:24 PM   #2
2fast4u831
I'm really 2slow
1994 Honda Civic
2fast4u831's Avatar
Send a message via AIM to 2fast4u831
nice
H2B squad member #09 my project
think fast, neukin , Turbogixxer , DVS
2fast4u831 is online now Report Post   Reply With Quote
Old 11-24-2004, 02:28 PM   #3
_Spugen_
_Spugen_'s Avatar
Send a message via AIM to _Spugen_
GJ mang...
95 Civic Coupe - FOR SALE!
_Spugen_ is offline Report Post   Reply With Quote
Old 11-24-2004, 02:30 PM   #4
Deemeetree
Electrician
Deemeetree's Avatar
Thanks.
Old 11-24-2004, 02:31 PM   #5
huntarrr
huntarrr's Avatar
Send a message via AIM to huntarrr
Default Re: [FAQ] How-To: Removal and Installation of a Distributor O-Ring. (Dimi)
Very nice.. good how-to!
[DC Squad Member # 0501]
huntarrr is offline Report Post   Reply With Quote
Old 11-24-2004, 02:32 PM   #6
CivicEJ1
Send a message via AIM to CivicEJ1
CivicEJ1 is offline Report Post   Reply With Quote
Old 11-24-2004, 02:34 PM   #7
SOHC4life 96
SOHC4life 96's Avatar
Default Re: [FAQ] How-To: Removal and Installation of a Distributor O-Ring. (CivicEJ1)
Great write-up. Let us know if this solves the problem.
Originally Posted by ressuREXion
after reading how i got caught in both of those, maybe it would be safe to assume i have narcalepsy
Originally Posted by Mr. E.G.
whoa, thats tough. i guess i would have to say that i would rather lick a dudes asshole that sick his duck.
RIP Earl Laskey 1944 - 2006 You will be missed
SOHC4life 96 is offline Report Post   Reply With Quote
Old 11-24-2004, 03:06 PM   #8
Deemeetree
Electrician
Deemeetree's Avatar
Old 11-24-2004, 03:13 PM   #9
icucnme
icucnme's Avatar
Send a message via AIM to icucnme
Default Re: (Dimi)
You can use a 31mm O ring from napa for about 80 cents also. The closest honda dealer for me is 1hr away so I had to improvise. I just did this about 2 weeks ago and problem fixed.
Vouches-cruzan007,sleepinonacreeper,Teal95Coupe,just_stock ,Chronicsinners,ep3man
Nihonjin,gsober,b18vtecboi Paypal verified and 100% ebay feedback. Id:hatch-attack
-06 YZ250F-Boosted 94 Integra Ls-
icucnme is offline Report Post   Reply With Quote
Old 11-24-2004, 03:45 PM   #10
Deemeetree
Electrician
Deemeetree's Avatar
I did go to AutoZone, Advance and O'Reiley's...nothing. Had to go to Honda. No one had the size.
Old 11-24-2004, 05:18 PM   #11
93Civac
93Civac's Avatar
Nice write up with good quality pics
2001 Chevy Tahoe - weekend pimpin
1990 Mustang LX 5.0 Notchback
1995 Civic DX- daily driver
2002 Lexus IS300
1999 Chevy Tahoe- Traded in
1996 Midori Green Hatch 2000 B16a2 swap SOLD biought it back and SOLD AGAIN
1993 Civic DX -SOLD
1995 Civic EX- SOLD
1990 CRX ZC Swap- SOLD
93Civac is offline Report Post   Reply With Quote
Old 11-24-2004, 05:49 PM   #12
s73
good write up
s73 is offline Report Post   Reply With Quote
Old 11-24-2004, 06:36 PM   #13
Dan GSR
Dan GSR's Avatar
Send a message via AIM to Dan GSR
Default Re: [FAQ] How-To: Removal and Installation of a Distributor O-Ring. (s73)
easy maintenance that anyone can do on their own
Frost White 95 LS... SOLD
2006 VW GTI
R-Speed
Dan GSR is offline Report Post   Reply With Quote
Old 11-24-2004, 07:15 PM   #14
Luserkid
Luserkid's Avatar
Send a message via AIM to Luserkid
Default Re: [FAQ] How-To: Removal and Installation of a Distributor O-Ring. (Dan GSR)
Glad i could help
You could see the marking i was trying to explain in this picture, for everyone that does this job remember which way the marking went because if you dont you wont be able to put the dist. back on right
93 B18C-<FONT COLOR="red">T</FONT> DX coupe
<FONT SIZE="2"><FONT COLOR="red">Janer Performance</FONT></FONT>
<FONT COLOR="blue">-Engine Building-</FONT>
-Turbo Install-
<FONT COLOR="green">-General Mechanic-</FONT>
-We Sell BDL http://images.honda-tech.com/set1/smile/emthup.gif -
PM for good deals. http://images.honda-tech.com/set1/smile/emthup.gif
Vouch
Custom Clutch Lines
RIP Earl Laskey 12.1.06 You will be missed! http://images.honda-tech.com/set1/smile/emsad.gif
Luserkid is offline Report Post   Reply With Quote
Old 11-24-2004, 07:47 PM   #15
Deemeetree
Electrician
Deemeetree's Avatar
Thanks all.
Old 11-24-2004, 08:00 PM   #16
Built to Spill
el diablo
Built to Spill's Avatar
Default Re: (Dimi)
Finally a decent 04 memeber.Nice write up.
-Richard
My Vouch Thread
Built to Spill is offline Report Post   Reply With Quote
Old 11-24-2004, 08:01 PM   #17
thrty8street
thrty8street's Avatar
Send a message via AIM to thrty8street
Default Re: (Dimi)
nice write up, I like how you were detailed; something that most people leave out when they do write ups.
DC5 Squad member #012
vouches in profile....
thrty8street is offline Report Post   Reply With Quote
Old 11-24-2004, 08:11 PM   #18
CardDealer
Banned
Default Re: (thrty8street)
The fins on the distributor are offset, so there is no way you could put it in 180deg off.....
good writeup
CardDealer is offline Report Post   Reply With Quote
Old 11-25-2004, 03:51 AM   #19
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Built to Spill)
Thanks man. Search under my name and under the Archives, I have a few FAQ Write-ups. Why I was a bit frustrated when I was labeled a 2004 member (even though I'm here since 2003 but my name got reset).
Indeed. If you look at my other FAQ Threads, they are pretty detailed and pic intensive.
Thanks.
Old 11-25-2004, 04:38 AM   #20
darkcvc
Blue Sedan Crew
1995 Honda Civic
darkcvc's Avatar
Default Re: (2FAST4U831)
great write up
Danny- Pics of my 95 Sedan w/ Ferio Interior
95 Civic DX Ferio DD, 95 Chevy Silverado, 05 Dodge Durango SLT
darkcvc is offline Report Post   Reply With Quote
Old 11-25-2004, 10:04 AM   #21
Deemeetree
Electrician
Deemeetree's Avatar
Thank you.
Old 11-25-2004, 11:07 AM   #22
Andres-eh2
Andres-eh2's Avatar
Send a message via AIM to Andres-eh2
Tks for your FAQ participation. Nice Writeup
Andres Photography || http://www.andresb.com
LM24 || http://www.lm24.net
Andres-eh2 is offline Report Post   Reply With Quote
Old 11-25-2004, 03:52 PM   #23
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Andres-eh2)
No problem.
I'll be doing a Write-Up on installing Omni Power Slip-On Coil-Overs for the 1992-1995 Civic chassis in a couple weeks.
Old 11-26-2004, 11:43 AM   #24
Nico
Nico's Avatar
Send a message via AIM to Nico
Default Re: (Dimi)
I will probably be doing this pretty soon. Nice write-up.
'92 White DX Hatch w/ stock B18B
'99 EBP Si --&gt; Hit-n-Run: 6-27-04, 1:33 a.m. http://images.honda-tech.com/set1/smile/emdgust.gif
HEELTOE
BodyKits NW
Nico is offline Report Post   Reply With Quote
Old 11-26-2004, 12:11 PM   #25
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Nico)
Did you get my PM?
Bookmarks
2005, 92, accord, civic, distributor, honda, how, install, marking, oring, prelude, removal, replace, ring, tahoe, to
