Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Oil leak on an element near oil filter
Old 11-16-2004, 10:39 AM
bengro's Avatar
Default Oil leak on an element near oil filter
This question could apply to anyone i suppose. I have a 03 element 4wd and it is leaking a little oil near the filter it may be the filter which happens to be a fram but i made sure the old seal came off with the old filter and cleaned the surface. I also put new oil on the new filter over the seal. I am almost positive that it is a bad filter or seal on the filter but wanted to know if anyone had similar problems. As it is right now i am just going to drive it until the next oil change is due.
Old 11-16-2004, 10:59 PM
spoondek's Avatar
Default Re: Oil leak on an element near oil filter (bengro)
its not a faulty oil filter. you have to tighten the s.o.b like its a virgin pu$$y
lots of peeps have that same problem. just tighten it more
Old 11-19-2004, 01:00 AM
RangerJoe's Avatar
if you drive with a known oil leak, you are an idiot...sorry.
go take it in ASAP, have it checked out. take it to a shop, or HONDA better yet. because if they install it, and it still does it, you can blame them.
Old 11-30-2004, 12:09 PM
jmlude's Avatar
Hey I was wondering if you had this problem fixed yet. I was having the same problem with my Prelude and it ended up being a seal that needed to be replaced behind the enginer oil cooler, which is the part the oil filter sits on. Supposedly this rubber seal goes bad around 60,000 miles and is one of the parts that is replaced when you take it into the dealer for that mileage inspection. Well the part costs about $3.00 and should take an hour or less to fix.
Old 12-03-2004, 05:31 PM
HiRevn's Avatar
Default Re: Oil leak on an element near oil filter (jmlude)
If it's not the filter, I would bring it back to the dealer. That thing should be covered by your warranty.
Old 12-06-2004, 04:20 PM
TEXN3's Avatar
Default Re: Oil leak on an element near oil filter (HiRevn)
there is a TSB and recall on CRV's with the same issue, a potential hazard is engine fires.
DelsolVted
14
03-15-2011 08:12 PM
r33dm0n3y
06-23-2009 05:30 PM
devin_hoang
36
03-24-2009 01:08 PM
00ls1
08-01-2008 07:48 PM
degradated
10-29-2001 07:32 PM
Quick Reply: Oil leak on an element near oil filter
