How Do You Tighten Rear View Mirror On A 2000 Civic??????
Old 11-15-2004, 07:17 PM
impound's Avatar
Default How Do You Tighten Rear View Mirror On A 2000 Civic??????
self explanatory......search is my friend....if you know then answer....thank you very much
Old 11-15-2004, 07:26 PM
gobblebox59's Avatar
Default Re: How Do You Tighten Rear View Mirror On A 2000 Civic?????? (impound)
you take it apart and put it back together, i got a 99 si, my friend knocked my rear view mirror completely off and it took 5 minutes to put it back, its self explanatory when you take it apart and put it back together.
Old 11-15-2004, 07:37 PM
impound's Avatar
Default Re: How Do You Tighten Rear View Mirror On A 2000 Civic?????? (gobblebox59)
do you take apart behind the mirror or where it mounts to the car????someone said you could adjust it up top
Old 11-15-2004, 07:39 PM
Downs's Avatar
I think that the top adjustment (at the roof) doesn't actually tighten the mirror. It just tighten the arm to the mirror.
Old 11-15-2004, 10:54 PM
l2agnar0k's Avatar
Default Re: How Do You Tighten Rear View Mirror On A 2000 Civic?????? (Downs)
theres a little plastic cover piece you can take off of the back part of the mirror arm. I cant remember what kind of screw its called, but its like a star. you tighten that and the mirror gets stiffer if thats what your asking.
Old 11-16-2004, 06:29 AM
impound's Avatar
Default Re: How Do You Tighten Rear View Mirror On A 2000 Civic?????? (l2agnar0k)
YES!!!!!!!!thanks...i was messin with that plastic piece...just hadnt got it off yet....thanks...lock
Old 09-04-2010, 06:10 AM
NRT_2000's Avatar
my actual mirror it self is loose, but i found a good way to fix it.... i just took a rubber band and kept raping it and twisting it up rite where the ball joint is and it eventually made it firm and not loose anymore
mfishman93
01-20-2008 04:22 PM
sinfulj32
02-13-2005 07:57 PM
AGB5901
18
06-16-2004 02:40 AM
CereaLand
Audio / Security / Video
03-25-2003 07:09 PM
Quick Reply: How Do You Tighten Rear View Mirror On A 2000 Civic??????
