94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
Old 11-06-2006, 05:19 PM
  #176
BlueIntegraBoy's Avatar
Default Re: (tmramsburg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmramsburg &raquo;</TD></TR><TR><TD CLASS="quote">I love my gsr cluster in my EK!! If blueintegraboy wanted to make a little money, he could make a kit for all the popular genertations. Hint-Hint. i would buy one</TD></TR></TABLE>
LOL, there isn't much of a kit. I mean, the fitting is all up to you. And the wiring has to be done by you, unless you want to fly me over
BlueIntegraBoy is offline
Old 11-26-2006, 12:48 PM
  #177
brooksto's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
thank you for making this write up, I just put a 98-01 ls cluster into my 96 civic and followed your instructions. The only problem I had was the cruise light would not come on but then I realized that maybe the ls didnt have a cruise option and so there is no light for it. Is this correct? Is there a simple way to add a cruise light? Thanks again for the write up, I finally have a working speedo again!!!
brooksto is offline
Old 11-26-2006, 01:06 PM
  #178
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (brooksto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto &raquo;</TD></TR><TR><TD CLASS="quote">thank you for making this write up, I just put a 98-01 ls cluster into my 96 civic and followed your instructions. The only problem I had was the cruise light would not come on but then I realized that maybe the ls didnt have a cruise option and so there is no light for it. Is this correct? Is there a simple way to add a cruise light? Thanks again for the write up, I finally have a working speedo again!!!</TD></TR></TABLE>
The LS should have a cruise light. You need to splice the red/blue wire from the green cruise Civic plug with an unused wire pin (pink for washer fluid light) and stick it in D5. It works, I did it in my friend's EX.
Old 11-26-2006, 01:50 PM
  #179
brooksto's Avatar
where is the cruise light located on the integra cluster? If its supposed to be in the lower left then I definantly dont have one. you know I said its an ls but I really dont know, its a 98-01 for sure, redlines about 7k. maybe an rs? sorry I dont know much about integras.
btw: there are actually no unused wires available for me as I dont have a wire for washer fluid. I had tried using the seat belt wire instead just because that light didnt matter to me.
brooksto is offline
Old 11-26-2006, 02:10 PM
  #180
RACEPAK's Avatar
nice
RACEPAK is offline
Old 11-26-2006, 02:36 PM
  #181
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto &raquo;</TD></TR><TR><TD CLASS="quote">where is the cruise light located on the integra cluster? If its supposed to be in the lower left then I definantly dont have one. you know I said its an ls but I really dont know, its a 98-01 for sure, redlines about 7k. maybe an rs? sorry I dont know much about integras.
btw: there are actually no unused wires available for me as I dont have a wire for washer fluid. I had tried using the seat belt wire instead just because that light didnt matter to me. </TD></TR></TABLE>
RS never came with cruise. You can add it by buying a bulb and socket as well as the lower left icon triangle.
Old 11-26-2006, 03:09 PM
  #182
brooksto's Avatar
any idea where I could buy the icon triangle from?
brooksto is offline
Old 11-26-2006, 03:21 PM
  #183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto &raquo;</TD></TR><TR><TD CLASS="quote">any idea where I could buy the icon triangle from?</TD></TR></TABLE>
Don't think you can buy it separately from the bezel.
Old 11-27-2006, 08:30 PM
  #184
95lscivic's Avatar
Is it possible to put a 91 integra ls cluster into a 93-95 civic coupe? I'm sure it is, but I can't seem to find any diagrams on how to do it, and this seems to be a decent place to ask such a question.
95lscivic is offline
Old 11-28-2006, 04:02 PM
  #185
LAMBOAVENGER210's Avatar
i have a 95 civic obd1 with the v tec wired straingt to pin a4 at computer is that correct cause my v tec not kicking in?? need help
LAMBOAVENGER210 is offline
Old 11-28-2006, 05:38 PM
  #186
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (LAMBOAVENGER210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAMBOAVENGER210 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 civic obd1 with the v tec wired straingt to pin a4 at computer is that correct cause my v tec not kicking in?? need help</TD></TR></TABLE>
Wrong thread. There are a lot of factors why your VTEC could not be working.
Old 12-04-2006, 09:23 PM
  #187
SilverGT's Avatar
I just got my hatch and installed a 97 integra clutster i got for free at my work. it was automatic so there are the P,D,R,1,2,3 etc. but i couldnt beat it for the price. it looks good i have one question about the wiring.....the integra cluster have a door ajar icon i wanna hook this up does anyone know where i can tap into so that icon works. i was thinking the dome light but that to far anywhere closer? its for a 1992 civic hatch
SilverGT is offline
Old 12-04-2006, 09:29 PM
  #188
Default Re: (SilverGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverGT &raquo;</TD></TR><TR><TD CLASS="quote">I just got my hatch and installed a 97 integra clutster i got for free at my work. it was automatic so there are the P,D,R,1,2,3 etc. but i couldnt beat it for the price. it looks good i have one question about the wiring.....the integra cluster have a door ajar icon i wanna hook this up does anyone know where i can tap into so that icon works. i was thinking the dome light but that to far anywhere closer? its for a 1992 civic hatch</TD></TR></TABLE>
I ran wires from the door sensors to the wires of the door ajar lights on my EG6 cluster. You can do the same. It's not that far.
Old 12-04-2006, 09:36 PM
  #189
SilverGT's Avatar
do where exactly is this wire? near the door ajar sensor? but dont you want to the door sensor to detect driver and passenger side? if you only do one side it only senses one side right?
SilverGT is offline
Old 12-04-2006, 09:46 PM
  #190
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverGT &raquo;</TD></TR><TR><TD CLASS="quote">do where exactly is this wire? near the door ajar sensor? but dont you want to the door sensor to detect driver and passenger side? if you only do one side it only senses one side right?</TD></TR></TABLE>
The door sensor only has one wire coming from it. I ran wires from both sensors to different wires on the door ajar lights. Of course, you only have one light, so I'd run both wires. Have both of the wires connect to the door ajar icon.
Old 12-11-2006, 09:14 PM
  #191
pkdog167's Avatar
Default Re: (BlueIntegraBoy)
Hi, got my integra cluster for my civic from ebay with harness....My car is a auto...I just want to know if you guys know how to wire the gear indicator from a civic to integra....really want to know..Thanks guys
pkdog167 is offline
Old 12-11-2006, 09:47 PM
  #192
Default Re: (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, got my integra cluster for my civic from ebay with harness....My car is a auto...I just want to know if you guys know how to wire the gear indicator from a civic to integra....really want to know..Thanks guys</TD></TR></TABLE>
Wire colors are probably the same. Match them up.
Old 12-12-2006, 11:55 PM
  #193
pkdog167's Avatar
cool!!!I was searching on internet for about 3 or 4 hours for that lol........and I was thinking why I don't just come here and ask....my cluster is coming !!!
pkdog167 is offline
Old 12-15-2006, 01:42 PM
  #194
brooksto's Avatar
is the fuel gauge going to be accurate? My car felt like it was getting low on fuel (gets hard to start when the tank is almost empty) but the integra cluster indicated I still had 1/4 tank left. Looking at the specs the integra has a 13.2 gallon fuel tank while my 96 civic has a 11.9 gallon tank. I would think this would throw the gauge off, has anyone experienced this or driven until the integra cluster indicated empty?
brooksto is offline
Old 12-15-2006, 04:12 PM
  #195
Default Re: (brooksto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto &raquo;</TD></TR><TR><TD CLASS="quote">is the fuel gauge going to be accurate? My car felt like it was getting low on fuel (gets hard to start when the tank is almost empty) but the integra cluster indicated I still had 1/4 tank left. Looking at the specs the integra has a 13.2 gallon fuel tank while my 96 civic has a 11.9 gallon tank. I would think this would throw the gauge off, has anyone experienced this or driven until the integra cluster indicated empty?</TD></TR></TABLE>
It's just a gauge receiving a signal from the fuel sender, nothing else. The gauge doesn't know how big the tank is.
Old 12-16-2006, 06:30 PM
  #196
SilverGT's Avatar
i dont know if anyone experience this but my rpm seems like its jumping at like 2k to 3k the rpm seems to be pinging...like up and down....but at idle its fine, it only happens when im on the gas. if i let off the rpm gauge is fine.....anyways if anyone has experience a problem like this let me know im gonna double check my wiring but if its not ath is it my car?
I will hook up my autometer tach to see if it does it on that. thanks in advance.
i have a 1992 Civic CX hatch 5 spd with a 97 integra auto cluster i didnt hook up the gear wiring just everything else.
SilverGT is offline
Old 12-17-2006, 07:10 AM
  #197
ieatpaint315's Avatar
Yes you're right. It's off by roughly 1/4 tank. When I fill up, it will be 1/4 tank above F for ~100 miles, then come down as I drive more. When the car is completely empty I'm about an 1/8th tank above E. I almost thought about seeing if the needle could be pulled off and reset on there at a different angle, but I didn't want to mess it up.
ieatpaint315 is offline
Old 12-17-2006, 05:10 PM
  #198
brooksto's Avatar
Default Re: (ieatpaint315)
thanks for the info, I was thinking the fuel needle was off some. Its not a huge deal to me as I usually go by the odometer anyway but Ill have to remind anyone that drives my car not to let it go below 1/8. Could just physically moving the needle back some fix it or would the needle actually have to be taken out and moved to the left and then put back in? Or could just the cluster fuel guage be swapped over and use the integra needle? or use an integra fuel sender? I hope there is a solution.
&gt;&gt;silvergt I havent had the problem you are describing but we do have different cars and clusters.
brooksto is offline
Old 12-22-2006, 07:24 AM
  #199
pkdog167's Avatar
You can't just move the needle, you will mess it up. I did it to my old cluster, and it's not working since then. So you have to take out the needle very careful and put it back on.
pkdog167 is offline
Old 12-24-2006, 08:50 PM
  #200
Bostek's Avatar
An ITR cluster in an EK looks sick. I'm gonna do this.
Bostek is offline
Quick Reply: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
