94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
Old 06-13-2006, 09:41 PM
  #151
SanSational's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
ok. and where can i get an electronic VSS? bump on the diagrams I wired a 98 GSR cluster into my 93 hatch without a problem (only wire splicing)
SanSational is offline
Old 06-13-2006, 09:46 PM
  #152
BlueIntegraBoy's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (90dmintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dmintegra &raquo;</TD></TR><TR><TD CLASS="quote">ok. and where can i get an electronic VSS? bump on the diagrams I wired a 98 GSR cluster into my 93 hatch without a problem (only wire splicing)</TD></TR></TABLE>
Junkyard. Any one from a B-series or D-series should work.
BlueIntegraBoy is offline
Old 06-13-2006, 09:55 PM
  #153
sweet. thanks man. now all i need is that diagram
Old 06-13-2006, 09:57 PM
  #154
90-93 integra ls pinout
PIN...Wire Color...Wire Function
A1...Yellow/Red...Seat Belt Reminder Light
A2...Green/Red...Parking Brake Switch Light
A3...Green/Black...Hatch Open Indicator Light
A4...Green/Red...Low Fuel Indicator Light
A5...Yellow/White...Fuel Gauge
A6...Yellow/Red...ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7...Red Gauge...Lights, Dash Light Dim
A8...Empty
A9...Red/Black...Gauge Lights
A10...Green/Yellow...Right Turn Signal Indicator
B1...Green/Blue...Left Turn Signal Indicator
B2...Red/Blue...High Beam Indicator
B3...Blue/Red...ABS Indicator Light
B4...Blue...Tachometer
B5...Green/Red...Door Open Indicator Light
B6...Yellow/Green...Engine Coolant Temp Gauge
B7...Black...Ground
B8...Yellow...Ignition Power
B9...Green/Orange...Malfunction Indicator (Ck Eng.) Light
B10...Black/Yellow...Charging Sysem
B11...White/Blue...Charging System (Battery) Light
B12...Yellow/Red...Low Engine Oil Pressure Light
C1...Red...Cruise Control Unit
C2...Red/Black Gauge Lights...Cruise Control Dimming Circuit
C3... Empty
C4...Empty
C5...Black...Cruise Control Ground
C6...Empty
C7...Yellow...Ignition Power for Cruise Control Unit
Old 06-14-2006, 06:48 AM
  #155
damn you're good
Old 06-14-2006, 10:40 PM
  #156
Caretaker's Avatar
any of you guys have any more pics of the ITR gauge installed in an eg, a much more cleaner one? im planning to do one on my car. thanks. (i saw the earlier pics)
Caretaker is offline
Old 06-20-2006, 11:14 AM
  #157
H22a1civic's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (SanSational)
H22a1civic is offline
Old 06-20-2006, 09:38 PM
  #158
hey blue
i wired it up and everything works, but for some reason, I have to turn the dimmer switch down to get the guage lights to work, and even then, they're barely lit? And also, whenever I accelerate, my charging light will stay on. Any ideas on why this is happening?
Old 06-20-2006, 11:22 PM
  #159
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SanSational &raquo;</TD></TR><TR><TD CLASS="quote">hey blue
i wired it up and everything works, but for some reason, I have to turn the dimmer switch down to get the guage lights to work, and even then, they're barely lit? And also, whenever I accelerate, my charging light will stay on. Any ideas on why this is happening?</TD></TR></TABLE>
Perhaps a grounding problem? Wouldn't know why the charging light would be on other than a problem with the alternator.
Old 06-21-2006, 10:00 AM
  #160
I know this isn't the right forum but since you helped out...
http://i61.photobucket.com/alb...r.jpg
http://i61.photobucket.com/alb...3.jpg
http://i61.photobucket.com/alb...2.jpg
Old 06-22-2006, 02:10 AM
  #161
Yes, feel free to post pics of your swap.
Old 07-05-2006, 09:35 PM
  #162
hatchciv92's Avatar
hey man i see you know about alot of this. and i got a big problem, i wire a 00 civic cluster into my 92 honda civic and i followed your wire diagrams and everything works except the fuel gauge .. i tried repining the one that are empty and no nothing, help me out please. ASAP..thanks man.
hatchciv92 is offline
Old 07-10-2006, 03:55 PM
  #163
tbx blaster's Avatar
Default Re: (Bonez21)
why has no company just made a jumper harness for this
tbx blaster is offline
Old 07-10-2006, 04:19 PM
  #164
hatchciv92's Avatar
Default Re: (tbx blaster)
**** im saying. they make everything so hard.but u know anything about it????
Old 07-11-2006, 09:00 AM
  #165
DARKB20's Avatar
Default Re: (hatchciv92)
DARKB20 is offline
Old 07-24-2006, 07:28 PM
  #166
HuskerHybrid's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (94_HATCH)
I have the two HARD TO FIND blue integra plug harnesses for sale if anyone is interested, PM me.
HuskerHybrid is offline
Old 08-22-2006, 01:10 AM
  #167
b18_crx's Avatar
subscribed i will be tackling this tommorow!
b18_crx is offline
Old 09-30-2006, 08:59 PM
  #168
112480's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (b18_crx)
Here's mine: 98 UKDM Type-R Cluster 170mph!! in my 92 VX hatch
112480 is offline
Old 10-01-2006, 02:56 AM
  #169
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (112480)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 112480 &raquo;</TD></TR><TR><TD CLASS="quote">Here's mine: 98 UKDM Type-R Cluster 170mph!! in my 92 VX hatch
Nice choice.
Old 10-09-2006, 09:55 PM
  #170
gsrpedro's Avatar
what about EFs???
gsrpedro is offline
Old 11-03-2006, 09:53 PM
  #171
ssdiablo's Avatar
how do i know with PLUG its A,B,C,D ???? for the Eg and a 94 Integra Cluster
ssdiablo is offline
Old 11-04-2006, 12:57 AM
  #172
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (ssdiablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssdiablo &raquo;</TD></TR><TR><TD CLASS="quote">how do i know with PLUG its A,B,C,D ???? for the Eg and a 94 Integra Cluster</TD></TR></TABLE>
Uhh, scroll down the first post. There are pictures.
Old 11-06-2006, 02:59 PM
  #173
DC5s0uth's Avatar
how bout if its a automatic dc2 cluster? same wiring?
DC5s0uth is offline
Old 11-06-2006, 04:00 PM
  #174
Default Re: (doyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doyEK &raquo;</TD></TR><TR><TD CLASS="quote">how bout if its a automatic dc2 cluster? same wiring? </TD></TR></TABLE>
Yes
Old 11-06-2006, 04:35 PM
  #175
tmramsburg's Avatar
I love my gsr cluster in my EK!! If blueintegraboy wanted to make a little money, he could make a kit for all the popular genertations. Hint-Hint. i would buy one
tmramsburg is offline
Quick Reply: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
