94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
#103
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
Just finished swapping my GSR cluster into my 99 civic... wasn't sure if it was a 94-97 or 98-up (is there a way to look and tell?)... so I tried fuel in c1 first... didn't work... and i looked at the diagram again and for some reason I could have sworn it said to put it at c8, so i tried that and was pissed when that didn't work. Then I looked over it again and there it was... right there plain as day C3... not C8... lol... oh well, it all works now! Oh yeah, and I repinned my SRS plug. The only cutting i had to do was for the cruise control.
Great Write Up!!!
Pics:
Modified by inneyeseakay at 11:35 AM 2/20/2006
Great Write Up!!!
Pics:
#104
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (inneyeseakay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inneyeseakay »</TD></TR><TR><TD CLASS="quote">Just finished swapping my GSR cluster into my 99 civic... wasn't sure if it was a 94-97 or 98-up (is there a way to look and tell?)... so I tried fuel in c1 first... didn't work... and i looked at the diagram again and for some reason I could have sworn it said to put it at c8, so i tried that and was pissed when that didn't work. Then I looked over it again and there it was... right there plain as day C3... not C8... lol... oh well, it all works now! Oh yeah, and I repinned my SRS plug. The only cutting i had to do was for the cruise control.
Great Write Up!!!
Pics:COMING SOON!</TD></TR></TABLE>
Yeah, I better clarify how to tell the difference between the years.
Great Write Up!!!
#105
has anyone tried slightly heating the civic bezel and making it fit the integra cluster? it seems to me that maybe if you heat it enough and pull out slightly on the bottom corners, it might just pull the top and bottom into line with the rest of it... if only it will stay... ?
my fitment isn't terible, but it could be a little better
Modified by inneyeseakay at 11:32 AM 2/20/2006
#106
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inneyeseakay »</TD></TR><TR><TD CLASS="quote">has anyone tried slightly heating the civic bezel and making it fit the integra cluster? it seems to me that maybe if you heat it enough and pull out slightly on the bottom corners, it might just pull the top and bottom into line with the rest of it... if only it will stay... ?
Modified by inneyeseakay at 11:32 AM 2/20/2006</TD></TR></TABLE>
Yeah, all of my swaps look like this. I haven't tried heating it up, but perhaps you should try.
#107
I wanna try this, but I am so clueless. So If I wanted to put 97 GSR into my 93 EG....I repin the gsr plugs for my eg?? Sorry for the stupid question....just trying to figure this out.
#109
Re: (OshkyCiv23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OshkyCiv23 »</TD></TR><TR><TD CLASS="quote">I wanna try this, but I am so clueless. So If I wanted to put 97 GSR into my 93 EG....I repin the gsr plugs for my eg?? Sorry for the stupid question....just trying to figure this out.</TD></TR></TABLE>
You can't repin the EG harness for an Integra cluster. The plugs are different and the pins are larger so you can't remove the wires and put them in an Integra plug. You have to cut, match, and connect using Integra or 96-00 Civic plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inneyeseakay »</TD></TR><TR><TD CLASS="quote">My seatbelt, highbeam, trunk ajar, door ajar don't work... any ideas?</TD></TR></TABLE>
Check the bulbs and double check the wiring. Never had a problem with my lights.
#110
Re: (BlueIntegraBoy)
ok.... I think it might work now. Thanks
Are the canadian models the same..cause my friend has a Integra Type R Canadian model that I am going to try...
#111
Re: (OshkyCiv23)
Are the canadian models the same..cause my friend has a Integra Type R Canadian model that I am going to try...</TD></TR></TABLE>
Yes
Yes
#113
Re: (lesturr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lesturr »</TD></TR><TR><TD CLASS="quote">nice write up </TD></TR></TABLE>
For sure... this is what forums are really about!!
#114
hea im new to this site......be a nice firend hea hook me up with a diagram how to hook up the v-tec control for b16a
#116
Re: (top_notch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top_notch »</TD></TR><TR><TD CLASS="quote">ya.....i need help to hook up my b16a jdm motor with a v-tec controller............need infor and diagram...........hit me up......thanks</TD></TR></TABLE>
Wrong thread. But if you have a VAFC, then go to Apexi's website and they have installation instructions with wiring diagram.
#118
Re: (JCL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCL »</TD></TR><TR><TD CLASS="quote">this is a noob question but where do you cut the wires after you can get the cluster out of a 92dx im planning to put in a 97ITR</TD></TR></TABLE>
Make sure you cut probably around 5 inches of wire left from the Integra harness to allow soldering of wires onto the EG harness.
#122
Sorry if this is a dumb question, but why isn't the JDM Type R cluster compatible with the civic?
Thanks, Great write-up!
#123
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (crxY-49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxY-49 »</TD></TR><TR><TD CLASS="quote">Sorry if this is a dumb question, but why isn't the JDM Type R cluster compatible with the civic?
Thanks, Great write-up!</TD></TR></TABLE>
It is. I never said that.
#125
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">It is. I never said that.</TD></TR></TABLE>
Well why won't the JDM cluster work with your diagram? Do you think it would be just as easy to install?
Thanks
Thanks
