94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
#77
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (********)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******** »</TD></TR><TR><TD CLASS="quote">my fuel wire had to go into C 3 i had it in c1 but i think since i have the japan spec cluster its slightly different great work any wayz also my 98-01 cluster went into my 96 coupe</TD></TR></TABLE>
This is funny, I've own at least 7 98 Spec ITR clusters and they all had the fuel gauge pin at C1 like then 98-01 USDM clusters.
#78
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
help my friend needs help!!!
we need to wire a 98+ jdm itr ecu into a 97 integra , and his wiring harness isnt matching up , he has many plugs left over.....only 2 blue plugs go into his cluster....how do we change the wiring, thank you!!!!!
#83
Help
Hey guys i did the swap to from my 92 cluster to a 94-01 gsr cluster it was workin fine untill a couple of days wen i was on the high way and it started going alll wacky by just flutering and now it doesn't work just the speedometer and odomiter the rest of the things work fine like rpm, temperature, and gas any one know how to fix cause i checked the wiring and it looks good HELP PLEASE
#84
Re: Help (maluseanjohn516)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maluseanjohn516 »</TD></TR><TR><TD CLASS="quote">Hey guys i did the swap to from my 92 cluster to a 94-01 gsr cluster it was workin fine untill a couple of days wen i was on the high way and it started going alll wacky by just flutering and now it doesn't work just the speedometer and odomiter the rest of the things work fine like rpm, temperature, and gas any one know how to fix cause i checked the wiring and it looks good HELP PLEASE </TD></TR></TABLE>
Its your Vehicle Speed Sensor.
#88
Thanks (BlueIntegraBoy)
<U>i would like to thank BlueIntegraBoy for the wiring diagrams</U>.. i followed his instructions to the letter the only difference is that i have a funny green wire running to the A1 pin which i can't figure out, when i grounded A1, my interior light comes on LOL .. in the end i just taped it up.. the rest of the wire colours are all the same as USDM
this is what it looks like on my JDM EK4 SiR
thanks again.. i would never have been able to do this would your wiring diagram
#90
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (Solo1B16Hatch)
I just completed my dash installation. Everything worked perfect on the first try. Thanks for the excellent post!
#91
can somebody tell me what i have to do to get the integra cluster to fit in my 92 civic please i cant get the black thing with the vents and my hazords to fit in at all please help
#92
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (ghostcivic)
[QUOTE=ghostcivic]can somebody tell me what i have to do to get the integra cluster to fit in my 92 civic please i cant get the black thing with the vents and my hazords to fit in at all please help
[/QUOTE
did you swap in any of the integra's heater items?
[/QUOTE
#96
Re: (BlueIntegraBoy)
hey wussup man. do you have or kno where i can get a diagram for a 02 type-s cluster into a eg or a ek or a teggy??? any help would be greatly app.
#98
thank you soo much for writing up this diagram!! i love you!! i followed the diagram and installed an integra cluster into my civic. it looks sweet! everything works good. thanks once again... btw this is my first attempt in doing this. if i can do it then anyone can. haha. im soo happy!
#99
yes im about to do this swap and i got a 99 dash with obd 2 wiring already on it. so the diagram that you have would i be using the 98-up cluster diagram to do my wiring?
#100
Re: (liltruong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liltruong »</TD></TR><TR><TD CLASS="quote">yes im about to do this swap and i got a 99 dash with obd 2 wiring already on it. so the diagram that you have would i be using the 98-up cluster diagram to do my wiring?</TD></TR></TABLE>
Depends on which Integra cluster you have. 96-00 Civic cluster harness are the same throughout the years.
