how much hp does a b18a have
how much hp does a factory b18a have? i did a little research and found diffrent people saying differant things like it only had 110hp and others saying it had 160hp i want know. hit this up if you know the truth
Re: how much hp does a b18a have (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">90-91 130 Flywheel HP @ 6000rpm
92-93 140 Flywheel HP @ 6300rpm
Anybody know why the hp is different..??</TD></TR></TABLE>
I have read that it was 130hp for the 90-93's and 140hp for the 94-01's.
But I think the 97's and up had a whopping 142hp.
1 Post
info is right
the difference in years is more aggressive cams for the 92-93 integra
btw 94+ are 142 hp w/ a different I/M but pretty much has the same build up as the 92-93 platform and yes different engine code(B18B)....
info is right
Re: how much hp does a b18a have (92integra_gs)
90-91 92-93 are different b/c the mani's are different and better tuning in the obd1. the 94 has a bigger tb thats where they get the 2hp.
1 Post
Re: how much hp does a b18a have (erebunicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx »</TD></TR><TR><TD CLASS="quote">90-91 92-93 are different b/c the mani's are different and better tuning in the obd1. the 94 has a bigger tb thats where they get the 2hp.</TD></TR></TABLE>
sorry bro i beg to differ... i know cuz my homie has a 90 teg & 95 teg and i got a 92 and 93 teg and the intake manifold is not different(for 90-93 teg) its the same... and for a fact i know its the cams (more aggressive cams for the 92-93)
and yes the tb is bigger but also the I/M is different....
1 Post
so let us say yes its the manifolds are that are different (in the 90-91 & 92-93) wouldn't it only gain like 2-5 hp at the most? think about it..
its the cams (10 hp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">its the cams (10 hp)
Yeah, I second that. Friend of mine has a b18b in his civic and his little brother has a b18a in his rex. I put some crane stage 2s in the b18b and the stock b18bs in the b18a and there was a noticable diff in power. Yet idle remained somewhat the same. Slight lope. - Darrell
from my understanding the 90-91 had a "small port" head as well as weaker cams.
to settle the arguement, the 90-91 and 92-93 technically have the same intake manifold, but there are differences. on the 90-91, there is a dashpot and air boost valve while on the 92-93 OBD1 the locations are there for these two items, only they're not drilled.
