Old 11-07-2004, 03:00 PM   #1
Calvinator
Calvinator's Avatar
Send a message via AIM to Calvinator
Default Symtoms of a bad distributor cap and rotor?
Sorry, the search feature is down. Basically, what usually happens when you have a bad cap and rotor? Also, how often are they supposed to be changed?
93 Civic CX 12.56 stock B16 sc32 at 10psi
96 Mustang GT 275rwhp/330tq
01 SLP Camaro SS
Calvinator is offline   Reply With Quote
Old 11-07-2004, 04:35 PM   #2
Calvinator
Calvinator's Avatar
Default Re: Symtoms of a bad distributor cap and rotor? (xtremeazian)
Does anyone know?
01 SLP Camaro SS
Old 11-07-2004, 04:38 PM   #3
jethawk
jethawk's Avatar
i had my dizzy go on me on my way home one day... driving home from picking up my GF... my CEL light came on and then the car died like it ran out of gas... push the pedal down to the floor and the revs kept dropping... pulled over to the side of the road and called a tow truck because the car definetly wasnt going to start.. good thing it happend only 3 km away from my house after a 400 km road trip!
jethawk is offline   Reply With Quote
Old 11-07-2004, 04:39 PM   #4
civictildeath
civictildeath's Avatar
missing, crossfiring, hard to start in wet weather
RIP Bubba 5-27
ECU CODES
O2 Sim Install
SUSPENSION
CHASIS
<FONT COLOR="blue">1999 EM1</FONT>
<FONT COLOR="red">1997 EJ8</FONT>
<FONT COLOR="blue">1993 Sol SI</FONT>
3rd gear grind member #8
civictildeath is offline   Reply With Quote
Old 11-07-2004, 05:06 PM   #5
civiccpedx
civiccpedx's Avatar
Default Re: Symtoms of a bad distributor cap and rotor? (civictildeath)
i think your suppose to replace them either every year, or every 6 months, im not sure. and my book is to far away
Great turbo write-up/how-to [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [url="http://www.honda-tech.com/zerothread?id=1263795"]http://www.honda-tech.com/zerothread?id=1263795[/url]
civiccpedx is offline   Reply With Quote
Old 11-07-2004, 07:02 PM   #6
Calvinator
Calvinator's Avatar
Default Re: Symtoms of a bad distributor cap and rotor? (jethawk)
Hey Jethawk, that sounds EXACTLY like my problem. You replaced your cap and rotor and it was fine? Or you had to replace your whole dizzy? thanks let me know.
01 SLP Camaro SS
Old 11-07-2004, 07:03 PM   #7
jethawk
jethawk's Avatar
had to replace my whole dizzy... and its not a cheap part at all let me tell you that! lol
Old 11-07-2004, 07:06 PM   #8
Calvinator
Calvinator's Avatar
damn...so im guessing replacing the cap and rotor won't do anything?
01 SLP Camaro SS
Old 11-07-2004, 07:08 PM   #9
The Mista Mike
The Mista Mike's Avatar
Send a message via AIM to The Mista Mike
Every 30,000 miles or 24 months, whichever comes first inspect and replace, if necessary, the spark plug wires, distributor cap and rotor
Check the outside for cracks and damage, then look inside it for cracks, carbon tracks and worn, burned or loose contacts.
Straight out of Haynes...
No car at the moment.
The Mista Mike is offline   Reply With Quote
Old 11-07-2004, 07:10 PM   #10
Calvinator
Calvinator's Avatar
Well, ill go ahead and try the cap and rotor, and if that doesn't work. I have a d16y8 dizzy laying around. Is there anyway I can swap the guts outta the y8 into the z6 dizzy since the z6 and y8 dizzy's dont interchange?
01 SLP Camaro SS
96, b16, bad, cap, civic, distribuotr, distributor, dritrbuator, honda, replace, rotor, symptoms, symtpoms, thunderbird, turbo
