Rewiring entire engine bay...
#30
Yep, that's a '94 Camry V6 you see there. It was really interesting to be working on such a car, and to see the faces of local car guys
Bottom-line though, it was all from the fact that I couldn't afford a Supra
#31
Re: Rewiring entire engine bay... (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg »</TD></TR><TR><TD CLASS="quote">For the Firewall Bulkhead Connectors. For the best cost while still keeping something that isnt cheaply made. I decided on some AMP CPC(Circular Plastic Connectors). They work great.
Here are the connector. They also didnt sell at 63 pins when I ordered them. Which would have came in handy. But for the price you cant beat them. Way better then the price for a Mil-Spec bulkhead connector.
I went with the Series 1 Connectors. If you plan on running some power wires to like your Alternator or Starter and want to run a bulkhead. They have Connectors that will take bigger gauge wire like 10-12 GA if you wanted.
http://www.alliedelec.com/cata...m=106
Here is the contacts for these connectors. Choose them depending on your wire size that you will be running.
http://www.alliedelec.com/cata...m=109
I would also suggest getting the Extraction Tool. Trust me you wont get them out any other way. For insertion you can just push them in until they click. You might also want to check out the Right-Angle Cable Clamps and Straight Cable Clamps on this page too.
http://www.alliedelec.com/cata...m=110
All in all for the price im very happy with these bulkhead connectors. They work great and are very durable and the price cant be beat. The best thing about Allied Electronics is that you dont have a minium buy order like Digi-Key.
If you want any other info on these connectors or anything feel free to PM me with questions.
Sal</TD></TR></TABLE>
I use all of these connectors at work. I would also recommend a set of pin crimpers if you don't have them. A regular set of crimpers/needlenose pliers will take you FOREVER, and won't crimp as clean as a nice set of pin crimpers will.
#32
H-T Order of Merit
Re: Rewiring entire engine bay... (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">
I would also recommend a set of pin crimpers if you don't have them.</TD></TR></TABLE>
Where would you buy those? Also, are they universal to all pins or are they specific to certain pins? Sorry, I'm just now starting to get into the wiring and things like that so I'm learning. Thanks
#33
Re: Rewiring entire engine bay... (TouringAccord)
The crimpers are specific to those type of connectors. Only problem is they are a decent amount of money. Im cheap so I just used some regular crimpers. It is very time consuming but it does get the job done.
#34
H-T Order of Merit
ok, thanks. So I'm guessing that the sites that sell the connectors and pins also sells the crimpers?
#35
yup... I believe my company buys them from McMaster Carr or Grainger, or maybe directly from AMP... But they look kinda like this (NOT EXACTLY.. these are for a slightly different style pin), and they are anywhere from $35-$60 but make life SOOO easy.
#37
Hey, either of you guys in the beginning of this post have pics closer up of where you routed everything going through the firewall?
#38
Re: Rewiring entire engine bay... (RC000E)
Here's my wire tuck.
Looks like this now but with ITB's. the plenum manifold was used for tuning, the block is Dart now also.
#41
Re: Rewiring entire engine bay... (d@ve.G)
I am a neat freak and heres my car.
All I have done is rewire and reroute the OEM harness.
I also just got done doing this to a buddys OBD 2 accord.
Modified by kid-honda at 12:43 PM 2/5/2005
#42
Re: Rewiring entire engine bay... (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang »</TD></TR><TR><TD CLASS="quote">and why is the vin tag removed from the tranny in that ryan autry guy's ride? </TD></TR></TABLE>
I think I remember reading a post where if you buy a brand new tranny from Honda, you don't get a VIN tag with it. VIN tags only come with trannies that were installed in a car.
I'll try to find the thread where I read this. I did a quick search, but found nothing.
#44
Re: Rewiring entire engine bay... (keithv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">
I'll try to find the thread where I read this. I did a quick search, but found nothing.</TD></TR></TABLE>
the new honda transmissions have "H DOT" stamped on them and no vin tag you are correct. (sorry about the thread hijack .
#46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E »</TD></TR><TR><TD CLASS="quote">EK9T...you have a source (website or company name)for those disconnects you have attached to the firewall?</TD></TR></TABLE>
Yes, I would also liek to know... did you use one of the links posted earlier?
#47
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Re: Rewiring entire engine bay... (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">
Yes, I would also liek to know... did you use one of the links posted earlier?</TD></TR></TABLE>
http://www.p-r-s.com
#48
Re: Rewiring entire engine bay... (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Are all those yellow things fusible endlinks?
#49
i HAS questions ?
Re: Rewiring entire engine bay... (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy »</TD></TR><TR><TD CLASS="quote">Are all those yellow things fusible endlinks?</TD></TR></TABLE>
Looks similar to what Geoffrey Ring (EFI University instructor) did on a harness he showed us. He had yellow labels with clear shrink wrap over them to label all the wires.
#50
yea... its yellow heat shrink with writing on them... and over that is some clear heatshrink
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy »</TD></TR><TR><TD CLASS="quote">
http://www.p-r-s.com</TD></TR></TABLE>[/URL]
call them up... ask for clint... he'll have pretty much anything ull need... and if he doesnt... he can get within a day or 2
im pretty **** about wiring... here's a couple more small things... its takes a lil longer to do then the generic hack job... but it looks much cleaner, u never have to worry about the connection, and everything i make at least is quick disconnect in some way or another... ill never hard-wire something so as u would have to cut it to remove it
