Old 10-31-2004, 08:01 PM   #1
racekar
Default Changing auto tranny fluid on 2000 acura integra gs
I have done manual tranny fluid changes but i have never done an auto tranny on this car..
can someon write post some brief steps on how to? is there a tranny filter on the integra auto tranny or is is just a drain bolt and fill through the dip stick? thanks
racekar is offline   Reply With Quote
Old 10-31-2004, 08:21 PM   #2
DB8_TEG
DB8_TEG's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (dchung1)
just take the drain bolt out, clean the bolt off with a clean rag, tighten the drain bolt then fill it up via the dipstick and you are done.
No filter
DB8_TEG is offline   Reply With Quote
Old 11-01-2004, 04:35 AM   #3
JimBlake
JimBlake's Avatar
... And IF the fluid is brown or smells burnt, drive around a little & change it again. A couple times.
When you drain an auto trans, the torque converter doesn't drain, so you're only changing about 1/3 or 1/2 of the fluid.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 11-01-2004, 08:25 AM   #4
m R g S r
m R g S r's Avatar
Send a message via AIM to m R g S r
Default Re: Changing auto tranny fluid on 2000 acura integra gs (JimBlake)
Shit, I should really do that on my 95ls, i haven't changed it ever!
Manhattan College Mech. Engineering Student
2002 S2000--485whp pump gas
2009 Si Sedan--DD
m R g S r is offline   Reply With Quote
Old 11-01-2004, 08:31 AM   #5
TEXN3
Send a message via AIM to TEXN3
Default Re: Changing auto tranny fluid on 2000 acura integra gs (m R g S r)
recommended changes should occur every 25k-30k miles.
it's about 60 bucks from the dealer. there is a great write-up at http://www.g2ic.com for doing a complete fluid change on a B18a integra, i'm sure the transaxle for the B18b and B18a are quite similiar, maybe some computer differences.
http://www.g2ic.com/forums/sho...fluid
note: you may have to be a member to view this...i'm not sure.
tuna
TEXN3 is offline   Reply With Quote
Old 11-01-2004, 08:49 AM   #6
timmy8151
timmy8151's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (TEXNTEG)
Though the recommended interval is 25K-30K miles, I usually recommend 15K intervals. Fluid isn't that expensive and is easy to change, since there isn't a filter.
As posted above, a single drain and refill isn't going to change all the fluid. If you want to do a more thorough flush, do a triple flush as Jim Blake recommended.
timmy8151 is offline   Reply With Quote
Old 11-01-2004, 10:07 AM   #7
LostGsr
LostGsr's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (timmy8151)
Here's another link:
http://www.c-speedracing.com/h...d.php
"Inside every fat girl is a skinny girl sleeping inside her for warmth"
LostGsr is offline   Reply With Quote
Old 11-01-2004, 10:52 AM   #8
..::91TEG-G2::..
how much would this run you in fluid?
[quote=Akuma]WHAT THE EXPLIFUCKINGTIVE!!!!????
You damn northerners. It's like a different universe. No Air Conditioners, Milk In Bags. Next thing you know, people in the North are going to have pigs that **** cooked bacon.[/quote]
DA squad member #41
[url="http://www.honda-tech.com/garage?cmd=viewcar&id=3693"]My Garage[/url]
..::91TEG-G2::.. is offline   Reply With Quote
Old 11-01-2004, 11:20 AM   #9
timmy8151
timmy8151's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (..::91TEG-G2::..)
Remember only to use Honda ATF, because of the Z1 additive. I've seen the fluid sell anywhere from $2.50 to $4 per quart. A drain and refill will require 3 qts per change.
Old 11-01-2004, 11:24 AM   #10
MyceliuM
MyceliuM's Avatar
Send a message via AIM to MyceliuM
At this website it shows how to change the automatic transmission fluid on a B18C1 engine. I have an '01 Teg Ls B18B1. Are the procedures still the same?
MyceliuM is offline   Reply With Quote
Old 11-01-2004, 11:34 AM   #11
JimBlake
JimBlake's Avatar
Default Re: (MyceliuM)
Um, yeah. That link shows how to change fluid in a manual transmission. LS vs. GSR should be the same. And on a manual, pretty much all of it drains out.
But we were talking about an automatic. Drain plug is on the bottom somewhere, but probably a little different than the manual. And you fill it thru the dipstick hole.
JimBlake
'01 Saab 9 & '05 9x
Old 11-01-2004, 11:57 AM   #12
MyceliuM
MyceliuM's Avatar
Default Re: (JimBlake)
What's a dipstick hole?
Old 11-01-2004, 12:30 PM   #13
timmy8151
timmy8151's Avatar
It's the hole, where the dipstick goes into the transmission. The dipstick is used to check the amount of ATF in the transmission.
Old 11-01-2004, 01:09 PM   #14
LostGsr
LostGsr's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (LostGsr)
Originally Posted by LostGsr
ahh my bad, yea that's the link to changing a manual transmission fluid. For the automatic, it's even easier. There's a plug on the transmission casing that a 3/8 socket drive will fit directly in it. Take the plug out and drain, then fill from the dipstick hole like Jim Blake indicated.
Old 11-01-2004, 02:43 PM   #15
TEXN3
nevermind...go with the link I posted above, it WILL answer your questions and give you thorough directions of what to do.
tuna
00, 2000, 2001, acura, auto, automatic, change, dipstick, drain, fill, fluid, g3, integra, tranny, trans, transmission
