Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 10-20-2004, 12:50 PM   #1
onyx00
Send a message via AIM to onyx00
Default Tires rotated, now car pulls left?
I had a local shop rotate my tires while thye were changing my oil. Now the car pulls left.
Is it possible the lift they used somehow messed up the alignment, or is it more likely one of the tires up front is pushing or pulling?
I checked tire pressure, and all is well there (36 fronts, 34 rears).
Wondering if I need to spend another $80 on alignment (had it done this summer already).
- 2000 PY ITR #00-1468 (Deceased), 2001 PY ITR #01-349 (Deceased), 2007 TL-S. SOLD
- 2008 Mitsubishi Lancer Evolution GSR. 340 HP / 344 TQ at the wheels.
onyx00 is offline   Reply With Quote
Old 10-20-2004, 01:03 PM   #2
WowOzYouRock
WowOzYouRock's Avatar
Send a message via AIM to WowOzYouRock
Default Re: Tires rotated, now car pulls left? (onyx00)
is it still in the same rotation?... well, just wait til it wear out a bit and even the wear on the tires ... then get it align if it continue pulling....
Michelin Pilot Sport tires 225/45/17 (Brand NEW) , 255/40/17 90% left --- $400 local - $450 shipped
The OG Honda-Tech "Jerk"....
WowOzYouRock is offline   Reply With Quote
Old 10-20-2004, 01:11 PM   #3
mstewar
mstewar's Avatar
Send a message via AIM to mstewar
most alignment shops warranty the alignment for x amount of miles.. call the shop that did it and ask..
no lift I've seen should have done anything to do with your alignment..
ITR #98-0158 - SOLD -- ITR #98-1040 - SOLD
ITR #00-0187 - SOLD -- ITR #00-0332 - SOLD -- ITR #01-1107 - SOLD
ITR #98-0106 - RIP -- ITR #98-0055/MWHC H2 #55 - SOLD
mstewar is offline   Reply With Quote
Old 10-20-2004, 01:19 PM   #4
Track rat
Track rat's Avatar
Default Re: Tires rotated, now car pulls left? (mstewar)
If your bring an unevenly worn tire from the back to the front it can make it pull left or right. Swap your fronts from left to right and see if the pull goes away or pulls the other way.
P1 Auto Rocks! (Rocked) [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
'98 type R H2 #81 - 2006 HC/H2 National Champ
'01 5.4 Ford Expy 4x4 - tow mule
'07 4 door Accord SE...manual, of course [img]http://images.honda-tech.com/set1/smile/emwink.gif[/img]
Track rat is offline   Reply With Quote
Old 10-20-2004, 01:23 PM   #5
GOOCH-JDM-ITR
GOOCH-JDM-ITR's Avatar
Send a message via AIM to GOOCH-JDM-ITR
Default Re: Tires rotated, now car pulls left? (Track rat)
it really depends on how the tires were worn origianlly.
Mine always pulls diferent after a rotation
my b18c LHT-JRSC build thread
GOOCH-JDM-ITR is offline   Reply With Quote
Old 10-20-2004, 01:30 PM   #6
DC2fanboy
DC2fanboy's Avatar
I think as long as it doesn't pull hard, (i.e. you can't stay in your lane for like 100m or something) it is probably a wear issue, especially since you've checked your tire pressure.
I've had an incident where I had been riding the side wall of my tires for a while (due to low pressure/leakage during storage) and I ended up blowing it out when I noticed and tried to pump it to the correct pressure (it had been pulling left on the highway).
Do you know how the rotated the tires?
I always check tire pressure meticulously now... especially after changing rims... live and learn... Click the image to open in full size.
DC2fanboy is offline   Reply With Quote
Old 10-20-2004, 06:09 PM   #7
Bbasso
Bbasso's Avatar
Do you have directional tires? Did the shop follow the recommended tire swap pattern for directional tires?
Bbasso is offline   Reply With Quote
Old 10-20-2004, 06:19 PM   #8
Runnerdown
Send a message via AIM to Runnerdown
Tires do that all the time. Swap them side to side and see if it goes away.
Runnerdown is offline   Reply With Quote
Old 10-20-2004, 08:35 PM   #9
Honduh Chicken
I fry gay turkeys
Honduh Chicken's Avatar
Default Re: (Runnerdown)
Did it used to pull to the right? Click the image to open in full size.
Signature removed per the request of: God
Honduh Chicken is offline   Reply With Quote
Old 10-20-2004, 09:29 PM   #10
Bryce
Bryce's Avatar
Default Re: (Honduh Chicken)
Mine have done that before, cars lowered and i get camber wear. try swapping the fronts to the opposite side.
Bryce is offline   Reply With Quote
4x4, alignment, car, changing, left, messed, pulling, pulls, rotate, rotated, side, tire, tires, wheels, worn
