***Forced Induction Forum FAQ***
Old 10-15-2004, 10:19 AM
Rory Breaker's Avatar
Default ***Forced Induction Forum FAQ***
Here are some questions we see pop up frequently from time to time. Hopefully this will encourage people to ask more detailed questions rather than some of these bland general questions. It also should give people new to the game a bit better understanding of what things are and how they work. I would also advise everyone to check out
- Learn How Everything Works! and read up on turbochargers, as there is some excellent beginners information there that will at least allow you to understand some of the jargon we use here.
This is going to be a community FAQ. Im getting it started with a few, and encourage everyone to take a little time and post links to information they feel would be valuable in here. Sick of seeing people posting "how much power does xxx make"? Find the answer or write something up and PM a link or writeup it to me, or just post it here. I will check this post periodically and arrange your posts for quick reference.
***DO NOT POST COMMENTS IN THIS THREAD. ONLY POST LINKS/ANSWERS TO CONTRIBUTE TO THE FAQ. IF YOU POST USELESS COMMENTS, WE WILL DEDUCT POINTS AND RESTRICT PRIVILEGES. PLEASE BE RESPONSIBLE WITH THIS. IF YOU HAVE ANY SUGGESTIONS ON TOPICS BUT CANT FIND AN ANSWER, PM ME***
This is OUR forum guys, all of us collectively. Do your part to keep it fresh and interesting by contributing to this FAQ.
We need you guys to post up common questions and a link to answers in this thread, so get to it!
Thanks!
EXACTLY What you need to understand before considering turbocharging your stock engine. THIS IS A MUST SEE FOR THE NOVICE USER!!
The science behind Modern Performance engine bearings - Courtesy of DSport Magazine
DSport Magazine - Modern Performance Engine Bearing
Piston Rings & Blowby
[Size=4] How a turbocharger works [/size]
How a supercharger works
5 Things to never do as a driver in a turbocharged vehicle
Supercharger vs. Turbocharger - What's the difference?
Important Questions to Ask Yourself When Selecting A Turbocharger for Your Specific Application (Part 1)
Part 2
Octane Changes After Installing Forced Induction
Turbocharger Catalog
- Complete listings of Garrett/ Honeywell, Precision (PTE), Borg-Warner, Turbonetics, MHI and Holset.
http://speedtrappconsulting.com/Arti...ce-Information
Garrett Turbo Tech Explanations 101,102, 103:
Garrett Turbo Tech 101-Basics
https://www.turbobygarrett.com/turbo...Tech%20101.pdf
Garrett Turbo Tech 102 -Advanced
https://www.turbobygarrett.com/turbo...Tech%20102.pdf
Garrett Turbo Tech 103 -Expert (ALL THE MATH)
https://www.turbobygarrett.com/turbo...Tech%20103.pdf
Turbocharger Failure Diagnostic Charts & Videos - A great way to narrow down whether or not your turbo is actually failing and not just guessing "seals"
Titles in Red font are the symptoms that the turbo was/is exhibiting, while the titles in Black font are possible causes
https://speedtrappconsulting.com/ima...se%20chart.pdf
Delphi - Helpful videos on ways to know if the turbocharger has failed
Different kinds of smoke - Is it the turbocharger or something else!??!?!
What is in a turbo kit, what do I need?
http://www.cse.uconn.edu/~yele....html
-->COMPLETE How-To:: Turbocharge Your Honda // Rep-ing Hypnotik Speed - Honda-Tech
Are Ebay/SSautochrome/OBX manifolds any good?:
There are COUNTLESS threads available on this by searching Google and other forums.
How to rebuild a turbocharger
How to properly rebuild your turbocharger if you can.
Compressor Maps and Reading them properly:
Turbocharger tech- Compressor maps. - Honda-Tech
How a turbocharger really works. In depth video from Holset (Thanks to TheShodan)
- YouTube
http://www.youtube.com/watch?v...lated
Turbocharger Myths Busted by Rick Balsy - Ecotec 2.0 Assistant Chief Engineer
https://www.youtube.com/watch?v=O-YdCZ3Hm7g&t=223
How Anti-lag Works
How a turbo is made
- YouTube
Ball Bearing vs Journal Bearing - Courtesy of TheShodan
Ball-bearing vs. Journal Bearing - Honda-Tech
Oil Restrictors: Fittings vs Flanges & When One Is Needed:
https://honda-tech.com/forums/forced...royed-3263966/
Oil Line Etiquette and proper configuration -A MUST SEE FOR INSTALLATION
Wastegate Springs and Part (TiAL Specific) Explained
Wastegate Interchangability - TiAL vs. Turbosmart - MUST SEE FOR INSTALLATION
Which manifold works for me?? Topmount/ramhorn/miniram/log
Which manifold works for me? - Honda-Tech
Do Turbo Blankets actually work?
One less "scientific" video that really does show the main point
Thanks to ChanceEG
Article: Turbocharger heat shields: Fact or Fiction?
Heat Shielding - Fact Or Fiction - Import Tuner Magazine
Heat shields - fact or fiction
Radiator, fans, shrouds, etc - The all-inclusive cooling thread (thanks Hussain-vtec)
Cooling System*** - Honda-Tech
Fuel pump - Name Brand vs Knock 0ff - Flow comparison with Data - (thanks NotARacist)
Real talk time: Fuel pumps, bench testing, and what it means to you - Honda-Tech
Where do I run my wastegate line to? Compressor or IM? (thanks Testudo)
Wastegate vacuumm line question - Honda-Tech
Common bolt/nut sizes for Honda turbo setups:
]Almost everything you wanted to know about turbo install......bolt sizes, thread pitch, oil feed and - Honda-Tech
How to decipher Garrett/Precision Turbo Names:
first tech write up, look in! - Honda-Tech
Spark plug Gap when diagnosing ignition Misfire NOTE: As sparkplug gap gets smaller, idle quality reduces / Lean condition occurs
How can I hook up an alarm and turbo timer?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1018699""""&quot ;"]ONE Offical way to setup up your Alarm+Turbo Timer - Honda-Tech
What do I gap my plugs at?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=877602""""" "]Spark Plug Gap??? - Honda-Tech
Whats an Electric supercharger/turbocharger? Any good?
NO.
Buying a used JRSC - what do I look for?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=907454""""" "]Jrsc questions... - Honda-Tech
General JRSC questions/information
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=853964""""" "]Anyone have a JRSC?? - Honda-Tech
AIR Intake Manifold?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=961203""""" "]Intake manifold comparison: Edelbrock vs. AIR manifold - Honda-Tech
SSAutochrome/OBX Turbo manifold?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=941816""""" "]SS Autochrome Manifold - Honda-Tech
Whats the difference between a log and equal length manifold (general manifold design info too)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=925312""""" "]FINALLY -- TURBO MANIFOLD TEST (What happens when a log manifold is changed to a Full Race Manifold? - Honda-Tech
Hondata or AEM?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=963992""""" "]would you run aem ems or hondata ?? - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=708650""""" "]Beaten to death...AEM VS Hondata...(sorry)... - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=612698""""" "]AEM or Hondata - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=671022""""" "]do i buy aem ems or hondata - Honda-Tech
What is A/R?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1023414""""&quot ;"]why is A/R so important? - Honda-Tech
Drag3 Turbo Install:
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=635014""""" "]Complete Guide for Drag 3 Turbo Installation - Honda-Tech
How do I break in my motor?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=878397""""" "]NEW ENGINE BREAK-IN...Some new ideas - Honda-Tech
Dyno comparison: Skunk2 Pro 1's vs CTR camshafts(Jeff Evans)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=2520138""""&q uot;"]Dyno comparison: Skunk2 Pro 1's vs CTR camshafts - Honda-Tech
Smaller turbo + more boost or Large turbo + less boost?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1004578""""&quot ;"]Benefit of higher WHP @ lower PSI - Honda-Tech
Spark Plug Information, NGK #'s and more! (thanks HXMan)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=510127""""" "]NGK Spark Plugs....Everything You Ever Wanted To Know and More... - Honda-Tech
Everything you want to know about NGK spark plugs (Ladysman)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=510127""""&qu ot;"]NGK Spark Plugs....Everything You Ever Wanted To Know and More... - Honda-Tech
Oil Return Line Assembly (thanks HXMan)
http://www.fast-turbo.com/oilreturnassembly.html
Mounting Oil Lines on Firewall (thanks to B18EG6 & Type-X) :
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=377208""""" "]Oil lines mounted on firewall...basic walkthrough - Honda-Tech
What about EGTs? How important is EGT?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=248965""""" "]EGT's Explained! Your answers are HERE - Honda-Tech
BSPT/NPT/AN Fittings Explained and Line Info
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=364948""""" "]fittings: NPT, BSP BSPT, 4AN etc etc etc....what do they all mean?!?!?! - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1226089""""&quot ;"]Some general information regarding fittings/hoses - Honda-Tech (thanks vtec.dc2)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1312904""""&quot ;"]FAQ oil feed and drain lines/fittings WITH PICS !!! - Honda-Tech (thanks BlueShadow)
How to install AN fittings
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=2150049""""&q uot;"]HOW TO INSTALL AN FITTINGS!!!! - Honda-Tech(B R Fittings)
Why am I getting boost creep/spiking with my Drag manifold?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=856210""""" "]How many people have had boost creep/spike issues with drag manifold? - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=802961""""" "]Those with Drag Manifolds, lets solve this problem! Check in here! - Honda-Tech
What size IC piping should I use? (thanks BlueShadow and Schister66)
https://honda-tech.com/zero...02591
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread/2409417""""""]when does 2.5" intercooler piping start to become a restriction - Honda-Tech
Where do I tap my EGT guage?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=163453""""" "]EGT Probe, where to put it? - Honda-Tech
Can I install Hondata and Injectors BEFORE I install my turbo kit?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=98092"""""& quot;]Get Hondata + injectors then install turbo later?? - Honda-Tech
What spark plugs do I use on an FI Honda?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=156273""""" "]What spark plugs do you use on FI cars? - Honda-Tech
How do I hook up my MBC?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=117513""""" "]ATTN people using turbo XS boost controllers and tial wastegates.. ?? - Honda-Tech
Installing your Walbro pump
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread/2424575""""""]Integra Walbro Pump Install - Honda-Tech
Injector info:
http://www.robietherobot.com/s...e.htm
How do I install DSM injectors? (thanks 93turbo16)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=691345""""" "]using DSM injectors - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=195834""""" "]what do i need to run dsm injectors? - Honda-Tech
http://www.geocities.com/uncgo....html
Resistor Box wiring:
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=441107""""" "]Resistor box wiring.... - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=517274""""" "]Official Injector Resistor Box Install......56k, Buy Broadband. - Honda-Tech
GSR Engine Build - How-to and tips: (thanks to Jeff Evans for an awesome writeup)
http://forums.evans-tuning.com...build
The *definitive* AFC Hack thread: (thanks JDavis)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=841443""""" "]AFC hack ignition recurve explained. - Honda-Tech
Uberdata install and tuning information: (thanks keebler65)
http://home.mn.rr.com/keebler65/honda
Information on Catch Cans and how to construct them: (thanks 95gsrcivic)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=766009""""" "]Everything is ready for my Endyn setup, then I find this thread... - Honda-Tech
$30 Breather / Catch Can ---- Opinions - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=687222""""" "]Endyn barbed fittings------------what is the part number--------------what car are they from-----OEM - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=684673""""" "]Catch cans, read the archives and still kinda confused. - Honda-Tech
...and the official crankcase evacuation thread:
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1199935""""&quot ;"]The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan / - Honda-Tech (thanks dasher)
How do you setup the AVC-R gear boost?
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1037051""""&quot ;"]AVC-R Boost by gear - Honda-Tech
Want to turbo your SOHC? Results!
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1067168""""&quot ;"]So You want to turbo your SOHC and want ideas about the numbers it will make - NEWBIE INFO - Honda-Tech
How do I ship my block to get it sleeved? (thanks Testudo)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=629402""""" "]Shipping a block: INFAMOUS STYLE!!! - Honda-Tech
CFM vs PSI? Is 7PSI on one turbo the same as 7PSI on another? (thanks dornon13)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1055905""""&quot ;"]Does a big turbo make more hp than a small turbo on the same engine at the same psi? - Honda-Tech
HOW-TO Install JRSC 92-00 Civic (thanks Enzospeed):
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1283655""""&quot ;"]How to install JRSC - 92-00 Civic - Honda-Tech
Motorola 2.5Bar Map Sensor Info (thanks 93turbo16):
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1266876""""&quot ;"]Motorolla 2.5 bar map sensor question. - Honda-Tech
General CRX Turbo Shopping List w/Prices (thanks BlueShadow):
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1157746""""&quot ;"]FAQ: EF CRX/Hatch B series turbo shopping list (BlueShadow's turbo project) - Honda-Tech
Where do I tap my EGT gauge? (thanks Testudo)
Wastegate: Route into DP = loss of power? (thanks Testudo)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=94820"""""& quot;]How much performance is lost by routing wastegate pipe into exhaust??? - Honda-Tech
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=151845""""" "]Downpipe size vs open/closed loop question? - Honda-Tech
Tial Wastegate setup -
EBC - Top and Side ; MBC or no BC at all - Side port, leave top open
Turbo Rebuild:
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1397101""""&quot ;"]How to Rebuild your own Turbo (like a ghetto scientist) - Honda-Tech (thanks stealthmode62)
Pulling motor tips; remove motor for mild build? (thanks Elpiar)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1419944""""&quot ;"]Is it possible to change piston/rods without taking engine out of the car? - Honda-Tech
GM 3Bar Wiring (thanks vtec.dc2)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1440585""""&quot ;"]Some information about GM 3bar and connnector install for Hondata - Honda-Tech
Volumetric Efficiency (thanks vtec.dc2)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1025485""""&quot ;"]Whats needed to calculate volumetric efficiency? - Honda-Tech
Partial Throttle Tuning (thanks elpiar)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1543394""""&quot ;"]Part Throttle Tuning Techniques? - Honda-Tech
ALL EBAY TURBO INFORMATION:
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/zerothread?id=1749857""""&quot ;"]Noobs and EBAY turbo's, your question's answered. - Honda-Tech
ARP Head Stud TQ specs
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=2279128#post37569630""& quot;"""]ARP TORQUE SPEC AND PATTERN - Honda-Tech
Adjusting Valve Lash (thanks to OMG THE GOGGLES)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=3213442""""&q uot;"]Hi Def How To: Valve Lash Adjustment on Honda Engine - GSR B18C1 - Honda-Tech
How to install & assemble P.T.F.E & Teflon Braided AN Hose (Thanks to OMG THE GOGGLES)
https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/"https://honda-tech.com/forums/showthread.php?t=3220511""""&q uot;"]HD Tutorial: How to install & assemble P.T.F.E & Teflon Braided AN Hose - Honda-Tech
Rory Breaker is offline
Old 01-19-2005, 12:33 AM
TeStUdO's Avatar
Default Re: ***Forced Induction Forum FAQ*** (TeStUdO)
https://honda-tech.com/zerothread?id=109160 -oil return line setup
https://honda-tech.com/zerothread?id=114490 -oil return line parts
https://honda-tech.com/zerothread?id=71999 -where to weld oil return
https://honda-tech.com/zerothread?id=119100 -oil return line
https://honda-tech.com/zerothread?id=119539 -oil pan welding
https://honda-tech.com/zerothread?id=119715 -oil pan welding
https://honda-tech.com/zerothread?id=118687 -oil grade to use
https://honda-tech.com/forums/forced-induction-16/oil-question-3192726/ -Oil Grade discussion
https://honda-tech.com/zerothread?id=118694 -ft for oil feed line
https://honda-tech.com/zerothread?id=118807 -oil feed line
https://honda-tech.com/zerothread?id=119681 -oil feed line
https://honda-tech.com/zerothread?id=93550 -part for oil feed line
https://honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
https://honda-tech.com/zerothread?id=126335 -oil t question
https://honda-tech.com/zerothread?id=125438 -another place to buy oil lines
https://honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
https://honda-tech.com/zerothread?id=134078 -feed diagram
https://honda-tech.com/zerothread?id=133948 -oil bpst fitting again
https://honda-tech.com/zerothread?id=144586 -oil feed line restrictor
https://honda-tech.com/zerothread?id=155510 -oil leaks
https://honda-tech.com/zerothread?id=158018 -oil feed 3' better
https://honda-tech.com/zerothread?id=156571 -oil pan bolts
https://honda-tech.com/zerothread?id=170223 -oil pressure readings
https://honda-tech.com/zerothread?id=168084 -oil feed fitting
https://honda-tech.com/zerothread?id=131450 -oil feed diagram
https://honda-tech.com/zerothread?id=195068 -oil pressu
https://honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
https://honda-tech.com/zerothread?id=365360 -install of walbro 255lph EF
https://honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
https://honda-tech.com/zerothread?id=116891 -closed loop turbo info
TeStUdO is offline
TeStUdO's Avatar
https://honda-tech.com/zerothread?id=123326 -blow off valve tightening
https://honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
https://honda-tech.com/zerothread?id=155616 -flexpipe issue
https://honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
https://honda-tech.com/zerothread?id=373528 -map sensor explanation and chipping
https://honda-tech.com/zerothread?id=121859 -hondata info on pumps
https://honda-tech.com/zerothread?id=117300 -spark plugs
https://honda-tech.com/zerothread?id=156273 -spark plugs (2)
https://honda-tech.com/zerothread?id=116886 -changing plugs
https://honda-tech.com/zerothread?id=117326 -flexpipe for good price
https://honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
https://honda-tech.com/zerothread?id=119569 -guage for autometer
https://honda-tech.com/zerothread?id=119591 -autometer guages
https://honda-tech.com/zerothread?id=121452 -aero fpr
https://honda-tech.com/zerothread?id=119884 -best FPR?
TeStUdO is offline
Old 01-19-2005, 12:34 AM
TeStUdO's Avatar
https://honda-tech.com/zerothread?id=118885 -place to buy aem fpr
https://honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
https://honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
https://honda-tech.com/zerothread?id=120889 -profec b install
https://honda-tech.com/zerothread?id=116651 -Radiator fans
https://honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
https://honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
https://honda-tech.com/zerothread?id=122396 -block guard
https://honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
https://honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
https://honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
https://honda-tech.com/zerothread?id=125639 -hks ssbv clip
https://honda-tech.com/zerothread?id=153531 -more hks bov install
https://honda-tech.com/zerothread?id=125852 -carsound cat part #
https://honda-tech.com/zerothread?id=92570 -turbo timer relay
https://honda-tech.com/zerothread?id=128321 -turbo timer wiring
https://honda-tech.com/zerothread?id=132485 -radius rods
https://honda-tech.com/zerothread?id=63095 -rear seat removal
https://honda-tech.com/zerothread?id=133644 -injector fitment
https://honda-tech.com/zerothread?id=104940 -thermal to cat issues
https://honda-tech.com/zerothread?id=136680 -egt guage stuff
https://honda-tech.com/zerothread?id=137223 -which runner to tap for egt
https://honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
https://honda-tech.com/zerothread?id=139706 -tools to carry
https://honda-tech.com/zerothread?id=140003 -base fuel map
https://honda-tech.com/zerothread?id=140774 -bleeding coolant
https://honda-tech.com/zerothread?id=156073 -js safeguard
https://honda-tech.com/zerothread?id=168470 -js safeguard, who is using
https://honda-tech.com/zerothread?id=160428 -summit part
https://honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
https://honda-tech.com/zerothread?id=170821 -wires to tap for guages
https://honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
https://honda-tech.com/zerothread?id=171314 -EGT temps
https://honda-tech.com/zerothread?id=166449 -vacuum sources
https://honda-tech.com/zerothread?id=175335 -assembling an fittings
https://honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
https://honda-tech.com/zerothread?id=193263 -greddy profec b
https://honda-tech.com/zerothread?id=85987 -installing rc injectors
https://honda-tech.com/zerothread?id=106033 -matching wires rc injectors
https://honda-tech.com/zerothread?id=133644 -fitment of rc injectors
https://honda-tech.com/zerothread?id=107030 -polarity does not matter
https://honda-tech.com/zerothread?id=154935 -once installed
https://honda-tech.com/zerothread?id=159623 -tips to install
TeStUdO is offline
TeStUdO's Avatar
turbo install http://coolazz.tripod.com/turbo.html http://home.attbi.com/~jeffrich/
injectors http://www.hstuners.com/forums...11436
resister wiring https://honda-tech.com/zerothread?id=441107
fuel pump http://www.theoldone.com/articles/fuelpump/
DIY boost controller http://www.geocities.com/chmwatson/FAQs/mbc.html
DIY Oil line kit https://honda-tech.com/zerothread?id=432769
Oil press sensor install http://www.theoldone.com/articles/oilpressure/
a/f gauge install http://www.rx-7.org/1stgen/airfuel.htm http://www.roadraceengineering...s.htm http://www.hstuners.com/forums...d=826
boost gauge install http://www.seansa4page.com/mya....html http://www.carreview.com/proje....aspx http://www.seansa4page.com/mya....html http://www.roadraceengineering...s.htm
TeStUdO is offline
Old 04-19-2005, 12:55 PM
Moderator in Chief
Muckman's Avatar
<u>Overheating</u>
This is for all the threads I see each day about overheating! If your car is over heating the #1 cause is air in the system.
If you have recently drained and refilled the system then this is almost certainly the answer. Some cars have bleeder valves located near the upper coolant line going into the head. Fill the radiator until coolant starts to pour out of the open bleeder then tighten it up. Cars without this bleeder valve can pull the radiator cap off and warm the car up until coolant reaches the very top of the radiator neck. In either case I le to re bleed the system again after a few miles to make sure the entire system is fully circulated. Some tips include leaving the cabin heater on full to allow full coolant circulation and filling the overfill bottle to its "max" level in-case the system needs to draw in more coolant. https://honda-tech.com/zerothread?id=140774
Other common causes are a bad thermostat, radiator fan isn't kicking on or is inadequate. And in the most extreme case, a bad head gasket will cause overheating as super hot combustion chamber gases are super heating the coolant.
Muckman is offline
Old 05-30-2005, 04:54 PM
gen2integra2001's Avatar
Default Re: ***Forced Induction Forum FAQ*** (Rory Breaker)
nice write up man...this is gonna be realllly handy
gen2integra2001 is offline
Old 06-17-2005, 09:42 PM
Joseph Davis's Avatar
Default Re: ***Forced Induction Forum FAQ*** (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">Engine management options https://honda-tech.com/zerothread?id=1277997</TD></TR></TABLE>
Incomplete + inadequate.
Joseph Davis is offline
Old 01-17-2006, 01:03 AM
JDM Vision's Avatar
Default Re: ***Forced Induction Forum FAQ*** (J. Davis)
JDM Vision is offline
Old 05-07-2006, 05:50 AM
KeyserSoze's Avatar
Default Re: ***Forced Induction Forum FAQ*** (Bense)
Here is a pretty cool writeup explaining turbocharging, supercharging and basic engine operation. Puts things in laymans terms with nice illustrations as well and a brief history of the turbocharger.
http://www.turbocompressori.ne...s.htm
KeyserSoze is offline
Old 05-21-2006, 10:58 AM
alphaek's Avatar
alphaek is offline
Old 08-16-2006, 12:27 AM
exim@uu.pp121.net's Avatar
Default Re: ***Forced Induction Forum FAQ*** (alphaek)
Great threads!
exim@uu.pp121.net is offline
Old 08-18-2006, 05:30 PM
standinghollow's Avatar
Default Re: ***Forced Induction Forum FAQ*** (exim@uu.pp121.net)
standinghollow is offline
Old 08-29-2006, 03:02 PM
needanew1's Avatar
How Turbo's work:
http://www.turbonation.com/turbo.htm
needanew1 is offline
Old 11-06-2006, 11:53 AM
low91rex's Avatar
so much info in here!
low91rex is offline
Old 11-07-2006, 09:11 PM
sauceja's Avatar
Default Datalogging
I found this helpful with trying to datalog and since I haven't found a more solid source.
https://honda-tech.com/zerothread?id=1454695
Also, but I am sure mentioned elsewhere
http://www.xenocron.com
http://www.moates.net
sauceja is offline
Old 11-18-2006, 07:46 PM
zzcoupezz's Avatar
Default Re: ***Forced Induction Forum FAQ*** (next21)
what about nitrous?
zzcoupezz is offline
Old 12-29-2006, 08:27 AM
Importrev's Avatar
Default Re: ***Forced Induction Forum FAQ*** (zzcoupezz)
This is a nice link
http://forcedinductions.com/help.htm
http://forcedinductions.com/helpadvanced.htm
Importrev is offline
Old 09-27-2007, 06:09 PM
PHILLLLIIPPPP's Avatar
bump
PHILLLLIIPPPP is offline
Old 11-23-2007, 04:45 PM
boostede46's Avatar
THANKS EVERY BODY WHO PARTICIPATING IN THIS FORUM IT HAS HELP ME ALOT!!
boostede46 is offline
Old 12-10-2007, 11:07 AM
mtownek9's Avatar
the first link under "What is in a turbo kit, what do I need?" is dead.
mtownek9 is offline
Old 12-25-2007, 02:33 PM
hondapimpin420's Avatar
great info guys
hondapimpin420 is offline
Old 03-27-2008, 12:51 PM
95greenlude's Avatar
Default Re: ***Forced Induction Forum FAQ*** (hondapimpin420)
HOW TO INSTALL A WET NITROUS SYSTEM by: 95greenlude
https://honda-tech.com/zerothread/2261379
95greenlude is offline
Old 04-27-2008, 11:35 AM
LSej1's Avatar
Good to know info
LSej1 is offline
Old 05-26-2008, 07:11 PM
96civic_hb's Avatar
Default Re: ***Forced Induction Forum FAQ*** (LSej1)
http://www.automotivearticles....shtml-Turbo Selection
http://www.turbochargedpower.c...s.htm-Turbo terms
96civic_hb is offline
Quick Reply: ***Forced Induction Forum FAQ***
