| Welcome to Honda-Tech! | ||
#1 |
i spun a bearing so im lookin toward a rebuild kit, as long as i didn't bend anything, so new bearings, oil pump, ANY1 Know Where To Find A Kit??
Thanks
-R.I.P. Brian Arbogast Vouches: 305S0L, B18cHatch4u, MattyP, delsoldreams, boarding2008 |
#2 |
i dont know if anybody sells a complete rebuild "kit" but you can pick up some ACL bearings from a couple different distributors on this site, one of them being EARL. you can pick up a gasket set and oil pump from your local honda dealer. hope that helps a little. maybe somebody else has some pointers about where to pick up gaskets for a better price.
RDR 12.009@113, 11.53@121 ....all motor streetcars Modern Automotive Performance (763)545-3800 |
#3 |
Any1 Have Any Links or More Info For Me??
THANKS
#4 |
exactly what other parts would i need??
#5 |
MiG-21 superfan
1975 MiG 21bis |
http://www.importperformanceparts.net offers alot of rebuild parts, like higher-flowing oil pumps and bearings
http://www.hondaautomotiveparts.com is a decent source for parts, i know their sister site acuraautomotiveparts.net offers honda part for 25% off OE list....
модератор / '09 Mercedes-Benz C63 AMG / '07 Si sedan / END OF AN ERA / 5'16", 149.7kgs / RON PAUL |
#6 |
| Garage is empty, add now |
if you spun a rod bearing, the crank is going to need to be checked out, to see if you ate the journal up.
i can sell you a package deal that will give you a great basis for an all motor d16. if all you need is bearings, pistons, rings, pins, and a gasket kit, off the top of my head i could sell it for $500. |
#7 | |
Banned
#8 | |
MiG-21 superfan
1975 MiG 21bis |
#9 |
dude here's some advice, drop the d-16 and why dont you get some B series motor? sounds like some extra horse power, reliable, and you get more street credit dawg, haha im kidding, you got to think what is more worth your money
'92 240SX Fast Back Close to Broken down. |
#10 |
MiG-21 superfan
1975 MiG 21bis |
full d16z6 build for $2500 with 90% OE honda parts that will net you around 20-25 more whp and 20+ more ft/lbs than a b16 swap...or, b16 swap with all the associated parts for $2500.....
#11 |
d16z6 build for $2500...ill tell you what, ill do that build for $1500, all day long, any day of the week including God's day.
i built a d16z6 for a thousand. it runs nearly 14:1, eats up b, h, and k series engines with a jg engine dynamics cam, and TB. i love b series, but there is a lot to be done with a d16. but the next trick is droppin a fully built turbo h22a runnin 11:1 with 16lbs into a 1988 crx si shell. |
#12 |
MiG-21 superfan
1975 MiG 21bis |
to make over 150 whp reliably out of a sohc vtec, I have found you need...
p29's @ .5mm over with rings- 250 Crower 2 or 3 cam- 325 Springs/ TI rets- 320 ARP rod bolts- 50 Bore, mill/deck, balance, shot-peen rods, valve job- 500 portwork- free, if you know what you are doing or portwork- 500 bearings, gaskets, WP/t-belt- 250 Clutch- 325 y8 intake mani- 50 BBK TB- 250 or Type R TB- 150 Header- 300-600 PowerFC- 650+250dynotime or Hondata- 295+250 dynotime or chipped p28- 150 This is assuming you already have the complete engine and it is not damaged, your fuel pump is up to the task, your injectors are balanced/ flowing properly, and already have obd1 harness plugs so you don't need jumper harness.... PS- sure, you could cut many many corners, but every extra mile you get out of the setup is worth it as is every little HP...
#13 |
i just did the same thing looking for same info and if you find anything please let me know, i need to get my car back on the road
thanks tangy.. |
#14 |
wow this topic is OLD>
I just swapped in a gsr Wish i would've stayed sohc (moneywise) or bought another car and built a motor as the money was availbale. just my .02
| Tags |
| bearing, cheap, civic, cost, d16, full, gasket, honda, kit, kits, performance, rebuild, rod, sale, spun |
