Could a bad PCV valve cause you to fail an emissions test?
Old 10-08-2004, 05:00 AM
prelude9999's Avatar
Default Could a bad PCV valve cause you to fail an emissions test?
My car failed the emissions test and I noticed my PCV valve wasn't working so I replaced it and now it works. Would this have any effect on passing the test?
Old 10-08-2004, 06:55 AM
Sephro's Avatar
Default Re: Could a bad PCV valve cause you to fail an emissions test? (prelude9999)
yes it could...
Old 10-08-2004, 07:23 AM
AndyD's Avatar
Could a bad PCV cause major bogging issues??
Old 10-08-2004, 08:00 AM
Default Re: Could a bad PCV valve cause you to fail an emissions test? (AndyD)
my pcv was bad and i didn't notice any bogging issues, seemed to run the same with and without it, i guess for $3 and 30 seconds you can't go wrong replacing it
Old 10-08-2004, 08:34 AM
LugNutZ's Avatar
Yes, it can. If your running your car cap the vacum pull the valve and put a breather in. It will remove all those less explosive oil fumes from your intake. Every little bit helps when your trying squish your friends WRX.
beana
05-19-2009 06:49 PM
ProLineDesigns
12-10-2007 03:54 PM
SpoolnByYou
02-08-2006 03:59 PM
Quick Reply: Could a bad PCV valve cause you to fail an emissions test?
