Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 10-03-2004, 01:07 PM   #1
4U2NV
4U2NV's Avatar
Send a message via AIM to 4U2NV
Default Strange Clicking/Fluttering/Tapping Sound... HELP!!!
Alright, I'm getting a weird sound from the engine which becomes noticeable after 3K rpms... It may make the sound below 3K, but it's not nearly as audible... It sounds kinda like a baseball card in bicycle spokes, and goes away promptly when the gas is released... The car doesn't seem to perform any differently, and drives like normal, but just that damn noise...
Axles are good, drivers side was replaced about two weeks ago... I've checked all the bolts on the manifold flange for my header, so I don't think it's an exhaust leak... I do get a brief squeal/whir at startup, could it be something with the alternator pulley going bad...? I'm going to try a valve adjustment tomorrow, and if that doesn't work I planned on taking off both the p/s and a/c belts to see if that eliminates the problem...
If neone has experienced symptoms like this and figured out the problem, your remedies are appreciated... I'm open to suggestions... TIA...
Old Whip: '99 CRP DC4-JDM B18B
New Whip: '03 RRP RSX-S
http://fast-turbo.com/ http://images.honda-tech.com/set1/smile/emthup.gif
http://arturbo.com/ http://images.honda-tech.com/set1/smile/emthup.gif
I'd rather be judged by twelve, than carried by six...
4U2NV is offline   Reply With Quote
Old 10-03-2004, 05:59 PM   #2
4U2NV
4U2NV's Avatar
Default Re: Strange Clicking/Fluttering/Tapping Sound... HELP!!! (4U2NV)
Night bump... Click the image to open in full size.
Old 10-03-2004, 06:17 PM   #3
kur0ryu
kur0ryu's Avatar
2 things that I think it could be:
1. valve lash too loose, need a valve adjustment
2. loose flywheel bolts. I had this problem before and it sounded like what you said. Eventually they all loosened out and I had to pull the tranny.
So.. I'd try a valve adjustment (can't hurt) and if it's still there it's probably more serious.
http://members.***.net/nickmys...4.jpg
91 Mugen/Toda CR-X SiR (LHD EF-8)
2003 IBP Lexus IS300 5spd LSD
"one man's misfortune is Oscar Meyer's fortune http://images.honda-tech.com/set1//smile/emcrook.gif "
kur0ryu is offline   Reply With Quote
Old 10-03-2004, 07:05 PM   #4
vtec94civic
2002 Honda S2000
vtec94civic's Avatar
Send a message via AIM to vtec94civic
had the same problem. at lower rpms you could barely hear it and once i got into the 3.5-4k range you would start to hear the noise again like a wood pecker. needlessto say on my way back from the dyno i started to hear this noise and about 20 mins away from the dyno it got louder and louder until my oil light came on and i knew i spun some bearings.
vtec94civic is offline   Reply With Quote
Old 10-03-2004, 07:19 PM   #5
93lsd
93lsd's Avatar
i would do a valve adj and if it doesnt go away drain your oil with 2 paint strainers you can get from local parts stores and see if you have any metal in your oil and if so it may be a main or rod getting ready to spun, how many miles do you have on it
I WORK ON HONDAS ALL DAY LONG "AND HATE IT"
93lsd is offline   Reply With Quote
Old 04-06-2005, 09:16 AM   #6
Redline96LX
* B A N N E D *
Default Re: (93lsd)
ive had this problem too. does it sound like maybe the injectors are rattling?
actually it sounds like something in the combustion chamber, sort of like someone is rattling little shards of metal, making a rustling of leaves, but with metal shavings? sort of like that?
Redline96LX is offline   Reply With Quote
acura, bolts, fluttering, flywheel, loose, rsx, sound, spokes, symptom, tapping, tl
