Old 09-26-2004, 06:33 AM   #1
col138
col138's Avatar
Send a message via AIM to col138
Default Really high Revs when starting the car
Hiya, im new and im in desperate need of advice.
I've just fitted an AEBS intake manifold to my EK jordan. The problem i have got is when i start the car up the revs go sky high. I used new gaskets, and im pretty sure i've got all the hoses in the right places. i haven't touched the idle screw. so im just wondering if anyone has an idea of what could be wrong.
Any help would be great
Cheers Col
col138 is offline   Reply With Quote
Old 09-26-2004, 06:50 AM   #2
murmur9
murmur9's Avatar
Send a message via AIM to murmur9
Default Re: Really high Revs when starting the car (col138)
sure you have new gaskets? did you clean off the old gasket **** that usually sticks to the metal? sounds like that or you have a messes up sensor...could be a vacume too how high is sky high? try taking your battery cable off....reset the ECU.....put it back together...start it....see if it still does it.
F/S :
~P2E ECU (manual)
~D16y7 Intake Manifold with all sensors, throttle bod..etc -make offer
~D16y7 wiring harness
~D16y8 (P2E) ECU
WTB:
~CRX HF exaust manifold</U>!!!!!! ASAP please pm me if you have one
murmur9 is offline   Reply With Quote
Old 09-26-2004, 06:56 AM   #3
col138
col138's Avatar
Default Re: Really high Revs when starting the car (murmur9)
I'm pretty sure i cleaned off all the gasket stuff. i've had the battery off so shouldn't that have reset the ECU. When i start it up its going to over 6000 i turn it off after then cos the engines freezing.
Old 09-26-2004, 07:19 AM   #4
BeerBaron105
BeerBaron105's Avatar
does it make a noise like a jet engine, if so u have a vac leak probably between the head and the intake manifold
http://www.wheyabove.com
Your source for nutrition, fitness, supplement advice
BeerBaron105 is offline   Reply With Quote
Old 09-26-2004, 07:20 AM   #5
Deemeetree
Electrician
Deemeetree's Avatar
Send a message via AIM to Deemeetree
You probably have an exhaust leak.
Did you properly torque down the intake manifold and set all hoses where they belong?
Did you break anything in the process and didn't fix it, such as a sensor or wiring harness?
Aegean Wiring and Lighting
[email]dspanoudakis@hotmail.com[/email]
E-mail me for all types of electrical work needed in the Tri-State area.
K.G.K. Electrical Contracting
Deemeetree is offline   Reply With Quote
Old 09-26-2004, 07:25 AM   #6
Kamin
Kamin's Avatar
Send a message via AIM to Kamin
Default Re: (Dimi)
its not an exhaust leak, he has a vacuum leak. no way an exhaust leak can affect idle RPM.
you did not clean off the head well enough for the new gasket to seat when you put the intake manifold on, OR you forgot to connect a large hose (brake booster). a small vacuum hose wont do this, this is a big leak to cause a rev that high.
Kamin is offline   Reply With Quote
Old 09-26-2004, 08:04 AM   #7
x00gsr
x00gsr's Avatar
Like they said its a vacuum leak make sure you atleast torque down all the bolts to requirements. Make sure you replace the intake manifold and throttle body gaskets. Also if your not sure if it has a vacuum leak. Take a bottle of Carb Cleaner and spray it around the gaskets. If it starts to choke where you sprayed it. Than thats where the leak is at.
x00gsr is offline   Reply With Quote
Old 09-26-2004, 11:12 AM   #8
col138
col138's Avatar
Cheers For your help guys, i've give up for today. I'll let you know how it goes.
Cheers Col
Old 09-26-2004, 11:17 AM   #9
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Kamin)
I'm sorry, I meant vaccum leak. I'm building my own exhaust so exhaust has been on my mind all day.
Why I asked if he torqued down all bolts on the intake manifold.
Old 09-27-2004, 09:55 AM   #10
col138
col138's Avatar
I've put my old manifold back on and it works fine. So i'm guessing i've got an air leak somewhere like you guys say. I don't know who is familar with an AEBS IM, but there are so may holes for vacuum hoses. Does anyone have any pictures of an installed manifold on a B16. Cheers for your help
car, engine, gasket, head, high, honda, rev, revs, revving, start, started, startibg, starting, turns, wrong
