Old 09-24-2004, 03:42 PM   #1
Deemeetree
Electrician
Deemeetree's Avatar
Send a message via AIM to Deemeetree
Default [FAQ] How-To: Install Energy Suspension Polyurethane Shifter Bushings. Part 1 of 2.
I've read many threads on people asking how to install ES Poly Bushings but no How-To threads. So, I've taken it upon myself to show you the steps on installing some new Poly b00shings.
Energy Suspension Poly b00shings:
Sorry for the darkness and bluriness. The part # is 16.1102R for all 1988-2000 Honda Civic models, excluding the 1999-2000 Honda Civic Si (I believe).
Step 1:
Drive your vehicle on some ramps. It makes it a whole lot easier to crawl under your vehicle.
Step 2:
Behind your transmission, you'll find this bracket with one part of the linkage going to it.
This linkage is held by a 12mm bolt. It's self-threading on the other side, so no nut.
Step 3:
Unbolt the 12mm bolt and move it out. Might take a little shove here and there to get it out, especially if it's the stock b00shing and bolt.
Step 4:
Once you remove the bolt, the linkage should drop right out of the way. If you are directly under it, watch out so that it doesn't hit you square between the eyes.
Step 5:
There will be a sleeve inside the stock bushings. Use some regular needle-nose pliers as I did, or anything that is big enough to shove in the sleeve and pry it out. The needle-nose worked like a charm, went right through.
Step 6:
With your needle-nose or a screwdriver, push out the old b00shing. I used a 12" screwdriver for the leverage. I didn't want to slip using the needle-nose and bruise a few knuckles.
Step 7:
Lube up the new Poly b00shings with the supplied grease that comes in the package. Don't over do it. This grease is a bit sticky once it gets applied.
Step 8:
Place one of the b00shings on one side of the mount. Should slide in fairly easy due to the lube.
Step 9:
Slide in the other b00hing. A new sleeve is provided in the package. Lube this up aswell.
DON'T FORGET TO INSTALL THE NEW SLEEVE!
Step 10:
Squeeze the linkage back up onto the bracket and bolt it back in place. Might take a shove here and there to lign it back up.
Once you're done, take it for a spirited drive. You WILL notice a difference.
Definitely crisper shifting. No more sloppiness. Also, this is only with the transmission side installed. There is another b00shing that is installed where your shifter drops through the floor. Since I couldn't wedge myself under there, part 2 of 2 will come by next week. I will also provide a step-by-step on the install.
Install time +/- 10 minutes.
Hope this helps!
Sorry for some of the blurry pics, new Digi and learning how to use it.
EDIT: PART 2 OF 2 CAN BE FOUND HERE: http://honda-tech.com/zerothread?id=1002429
This is for the Shifter end of the install.
Modified by Dimi at 7:15 AM 9/25/2004
Aegean Wiring and Lighting
dspanoudakis@hotmail.com
E-mail me for all types of electrical work needed in the Tri-State area.
K.G.K. Electrical Contracting
Deemeetree is offline Report Post   Reply With Quote
Old 09-24-2004, 03:47 PM   #2
AzntaggeR
TSPeed Factory
1994 Honda Del Sol
AzntaggeR's Avatar
Send a message via AIM to AzntaggeR
Default Re: [FAQ] How-To: Install Energy Suspension Polyurethane Shifter Bushings. Part 1 of 2. (Dimi)
looks like you didn't have to cut down the sides of the bushings for it to slip into place. i had to do that and it was a bitch. nice write up.
Speed Factory
94' del Sol B18C1-T (sold) | 01' IS300 (daily)
02' ZX-6R (sold) | 03' ZX-6R (sold) | 04' GSX-R600 (daily) | 05' GSX-R600 (stunt)
AzntaggeR is offline Report Post   Reply With Quote
Old 09-24-2004, 03:48 PM   #3
Deemeetree
Electrician
Deemeetree's Avatar
Nope. Slipped right in. I was hoping for that, didn't want to trim anything.
Old 09-24-2004, 04:07 PM   #4
Archidictus
Unceasing Measure
1998 Oldsmobile Intrigue
Archidictus's Avatar
Send a message via AIM to Archidictus
Default Re: (Dimi)
I found that the process becomes much easier if you take the linkage completely off the car before you start trying to take bushings out or put them back in. That way you can use a vice to cram everything in there nice and tight without having to worry about something slipping out 1/16th of an inch while you're trying to wedge it back into the transmission bracket and ****ing up your whole damn day .
Good writeup though .
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline Report Post   Reply With Quote
Old 09-24-2004, 04:23 PM   #5
AGENT 99
AGENT 99's Avatar
Default Re: (Archidictus)
there is not a better time to install a short shifter as well. I did both at the same time and loved the difference.
good write up- finish w/shirt shifter!
HT Anti-Apostrophe club. Its tight.
AGENT 99 is offline Report Post   Reply With Quote
Old 09-24-2004, 04:45 PM   #6
Deemeetree
Electrician
Deemeetree's Avatar
Thanks for the advice. I'm thinking on getting the Evasive shifter for $35 but I need some review on it. I'm loving the TWM shifter but $160 for a shifter with a knob is kinda steep. But it does drop the shifter 3".
Thanks for the feedback.
Old 09-24-2004, 06:36 PM   #7
Deemeetree
Electrician
Deemeetree's Avatar
Aww, no one else likes my FAQ.
Old 09-24-2004, 06:43 PM   #8
SOHC4life 96
SOHC4life 96's Avatar
Default Re: (Dimi)
I do. If only I could put it to use on my car. Stupid automatics
Originally Posted by ressuREXion
after reading how i got caught in both of those, maybe it would be safe to assume i have narcalepsy
Originally Posted by Mr. E.G.
whoa, thats tough. i guess i would have to say that i would rather lick a dudes asshole that sick his duck.
RIP Earl Laskey 1944 - 2006 You will be missed
SOHC4life 96 is offline Report Post   Reply With Quote
Old 09-24-2004, 06:51 PM   #9
SnowSurfer
SnowSurfer's Avatar
Default Re: (DOHC4life)
nice write up...link to where i can buy me some (yes im too lazy to google it)
SnowSurfer is offline Report Post   Reply With Quote
Old 09-24-2004, 08:08 PM   #10
Deemeetree
Electrician
Deemeetree's Avatar
I got mine from SummitRacing.com for $20 shipped. You can probably find them at other sites for a few dollars cheaper, but they look like those shady websites that might not send their products on time and what not. SummitRacing is very popular and sent my item the next day. I received it 4 days later with Ground delivery.
Old 09-24-2004, 08:19 PM   #11
SkoundrelUSA
SkoundrelUSA's Avatar
Very useful except for the fact the jerk on ebay sent me the wrong bushings
"So whats the deal with politics? I don't get it...Am I right people? "
SkoundrelUSA is offline Report Post   Reply With Quote
Old 09-24-2004, 09:12 PM   #12
Jimmy
Moderator
Jimmy's Avatar
Default Re: [FAQ] How-To: Install Energy Suspension Polyurethane Shifter Bushings. Part 1 of 2. (SkoundrelUS
great writeup
Where did you purchase the bushings at and how much?
/// 1994 Integra RS-T | 2002 cbr f4i
Jimmy is online now Report Post   Reply With Quote
Old 09-24-2004, 10:10 PM   #13
Deemeetree
Electrician
Deemeetree's Avatar
Originally Posted by Jimmy
great writeup
A couple of posts up...
SummitRacing for $20 shipped. http://www.summitracing.com
Old 09-25-2004, 07:16 AM   #14
Deemeetree
Electrician
Deemeetree's Avatar
Edited and Updated with Part 2 of 2.
Old 09-25-2004, 08:04 AM   #15
Nico
Nico's Avatar
Send a message via AIM to Nico
Default Re: (Dimi)
Nice Write up Dimi.
'92 White DX Hatch w/ stock B18B
'99 EBP Si --> Hit-n-Run: 6-27-04, 1:33 a.m. http://images.honda-tech.com/set1/smile/emdgust.gif
HEELTOE
BodyKits NW
Nico is offline Report Post   Reply With Quote
Old 09-25-2004, 08:15 AM   #16
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Nico)
Originally Posted by Nico
Nice Write up Dimi.
Old 09-25-2004, 01:23 PM   #17
Goullish
Goullish's Avatar
Default Re: (Dimi)
Very Nice.
Goullish is offline Report Post   Reply With Quote
Old 09-25-2004, 01:24 PM   #18
xbB
Nice writeup man!
'90 CRX DX - sold
'88 Panda CRX <FONT COLOR="red">Si</FONT> - sold
'89 y-49 CRX <FONT COLOR="red">Si</FONT> - sold
'05 Scion xB
xbB is offline Report Post   Reply With Quote
Old 09-25-2004, 06:51 PM   #19
Deemeetree
Electrician
Deemeetree's Avatar
Thanks guys.
Old 09-29-2004, 03:13 PM   #20
Andres-eh2
Andres-eh2's Avatar
Send a message via AIM to Andres-eh2
If im doing this on a 94+ teg linkage, will i have to get a press to push it in?
i did it with the stock one but it was a PITA and this might be harder
Andres Photography || http://www.andresb.com
LM24 || http://www.lm24.net
Andres-eh2 is offline Report Post   Reply With Quote
Old 09-29-2004, 03:39 PM   #21
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (Andres-eh2)
If I was back living in Astoria, I would help you out (damn I miss NYC). Besides that, I hear if you place the bushings in the freezer for an hour or 2 they'll shrink. Might be enough shrinkage to not use a press. These actually went in A LOT easier than the stock ones.
The stock ones is a 1 piece bushing with "lips" at the end. The ES ones, are a 2-piece design. So, the smaller end of the bushing goes in. No need to get them pressed in.
Then again, I've never worked on Integra linkage. Try the Integra forum for more details.
Part 2 of 2 is there aswell if you need any more help. PM me if anything...
Old 09-29-2004, 05:13 PM   #22
hondainspired
hondainspired's Avatar
Send a message via AIM to hondainspired
Default Re: (Dimi)
simple enough... i need all new shifter bushings as it is...
JAY
01 Audi TTR- DAILY
88 FC + 13B-RE= TRACK
hondainspired is offline Report Post   Reply With Quote
Old 09-29-2004, 05:23 PM   #23
x00gsr
x00gsr's Avatar
i wish someone made a how to install for the energy suspension master bushing set.
x00gsr is offline Report Post   Reply With Quote
Old 09-29-2004, 05:43 PM   #24
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (x00gsr)
Soon enough I'll make one.
That one DEFINITELY needs a press though, for all the suspension pieces needed to get changed out.
Old 09-29-2004, 05:46 PM   #25
Deemeetree
Electrician
Deemeetree's Avatar
Default Re: (hondainspired)
Don't forget my Part 2 of 2, also on here with the same thread title...except Part 2 of 2.
Bookmarks
161102r, 2003, accord, bushing, bushings, civic, energy, honda, install, installing, integra, is300, polyurethane, shifter, suspension, suspention
