need help indentifying a turbo
Old 06-09-2010, 09:50 PM
black da9's Avatar
Default what do you think of this turbo
Not sure what the model the turbo is, I know it's a borg warner with ett that's it.
Specs on the turbo are as follows.
compressor
inducer- 53 exducer-77 trim 47
3 inch inlet and 2 1/4 outlet
turbine
inducer-57 exducer-69 trim 68 A/R is 83
t3 divided inlet flang 3inch 4bolt outlet flang
I have these part numbers
Compressor Housing
53271013082
Turbine housing front side
1270 101 9061A
Turbine housing back side
BWS-GJS
XSIMO4.1
Wastegate actuator flange area on turbine
300507
1-D1
The engine is b18c1 9.1.1 pistons with eagle rods all arp bolts mild port and polished and valve angle job on head with gsr cams and type r valves, springs and retainers. 2 1/2 charge piping 3 inch exhuast.
Any help would be appreciated.
Old 06-12-2010, 07:38 AM
black da9's Avatar
Default Re: need help indentifying a turbo
bump
TwoKSiR
01-31-2010 08:48 PM
eglslsd
06-14-2007 05:36 PM
marko_think
06-28-2005 02:55 PM
booscivic
12-15-2003 07:14 PM
nitroedhx
02-12-2003 08:55 PM
Quick Reply: need help indentifying a turbo
