s2k s2000 gauge cluster fully functional in an eg or ek?
Old 07-04-2010, 10:22 AM
  #2276
DSRxCandyh2bEG's Avatar
Default Re: s2k s2000 gauge cluster fully functional in an eg or ek?
Just thought I'd share some pics of my cluster installed... I didn't wire the speedo healer and am not going to use a ECT box. This is my Street Class Drag Car so I just wanted a better display than oem, a tach thats more accurate...
Old 07-09-2010, 10:47 PM
  #2277
jdmdb8r's Avatar
good work, finally somebody with some pics of the actual work done, now if only some would post some pics of the actual write up...
Old 07-09-2010, 11:29 PM
  #2278
FlewByU352's Avatar
wait what darkside? do you have a DSM in your Honda? lol Cluster looks bad *** though. Does anyone know the name of those fully digital displays that are like in the shape of the S2K cluster usually seen in drag or road racing cars?
Old 07-10-2010, 03:40 AM
  #2279
die_lawn's Avatar
heres my del sol that i had wired up an AP2 s2k cluster in, only thing i didn't do was the temp. other than that everything else worked. theres a video on there as well.
http://speedhawaii.com/2010/01/die_lawns-honda-del-sol/
i CAN do wiring for people as well so if anyone wants it done, they can just PM me and we can work something out!
Old 07-10-2010, 08:39 AM
  #2280
DSM, No offense but I would never have a DSM. hahah. Those thinks are a giant oil leak.
Darkside Racing is from Northern California and we are about 24 members deep.
The clusters your talking about are called the "Aim's Dash" displays.
Here is a link: http://www.aimsports.com/auto/index.html
I feel bad because I didn't really take pics of the way I got everything to work. I will say I mounted the cluster inside another clusters housing though...
Old 07-14-2010, 10:50 AM
  #2281
unusual71's Avatar
I did mine this way too worked very well.
there is still no write up out there? I just came to post my speedo healer numbers to help out the others.
if people still want one I could post one up Im pretty sure I took pictures of the whole process except maybe actually screwing it into the car but that was the same as stock.
its really not that hard only took me 8 or 9 hours including all the research and gathering proper info and all that. actual wiring and install only took like 4 or 5 and I went slow.
anyways with a 1995 VSS out of an Integra LS (trans code S80) and an AP1 cluster my value was +3950% on the speedo healer
Old 07-14-2010, 10:56 AM
  #2282
unusual71's Avatar
Originally Posted by 1hotredg35
Do I have to splice the white wire from the SPEEDOHEALER into the VSS sensor ,or completely cut it and wire the VSS only to the SPEEDOHEALER?
the speedo healer should have 2 wires for signal (white and green if i remember). You cut the wire for the speed signal, blue with white, behind the cluster, and one end of the freshly cut wire, the one leading under the dash and off to the VSS, gets spliced to the green wire of the speedohealer. The other end of the freshly cut blue/white wire, going to the new cluster, gets the other speedohealer signal wire, the white one.
Now i can't remember if i have the order of the green and white correct it has been a while, but the order DOES MATTER. My gauge showed zero until i switched the green and white wire and then it worked and with the speedohealer value i posted above it is bang on.
your exact value will be different depending on tire size and gearing. I am running a taller than stock tire.
Old 07-14-2010, 12:30 PM
  #2283
The G2 Racer's Avatar
I was expecting a crank walk comment. My car doesn't like but I also just rebuilt the motor pretty much.
I'm gonna be putting one of these into my DSM this winter.
Old 07-14-2010, 07:53 PM
  #2284
jdmdb8r's Avatar
thanks for the help/info....
Old 07-15-2010, 04:55 AM
  #2285
What do you people want for a write up? The wiring diagrams?
Old 07-15-2010, 09:40 AM
  #2286
Hahaha. I'll leave it at that cause I don't wanna cause a huge discussion about hondas vs DSM's.
The cluster should look sick in the DSM dash though. Good luck with it.
Old 07-15-2010, 02:42 PM
  #2287
no worries, I've had both cars and love and hate both hahaha.
Thanks man, it's been done before and looks pretty sweet imo.
Old 07-23-2010, 06:18 PM
  #2288
SL0WEGG's Avatar
Anyone have any suggestions on which retailer has the fastest shipping on these speedohealer's. I've driven my car around for a few months here and there. I'm tired of seeing that damn 0 lol and so i can track my gas mileage on e85.
Old 07-31-2010, 08:54 AM
  #2289
rickyracer's Avatar
well here are some pics of my ap1 cluster in my em1....everything is working perfect....
Old 08-01-2010, 04:51 AM
  #2290
Tyconway's Avatar
finished my swap in my ek this weekend...made a fiberglass bezel to hold the ap1 cluster... Heres a preview...
Old 08-04-2010, 04:02 PM
  #2291
Tyconway's Avatar
anyone have any problems with reprogramming the Modifry ect... got the file on my laptop, the data cable is connect, but the modifry unit wont accept the text file transfer... anyone got any info or can help me out. I've emailed bob but haven't got any response
I ordered the one for ap1 for aem
I have a kswap in my ek, with Kpro, so im guessing i need the stock file b/c my temp gauge lights up all the bars when the car is cold.
Old 08-15-2010, 04:27 PM
  #2292
Jonny-X's Avatar
Check the build thread in my sig for my em1 I did it and it's fully functionless. I glassed a bezzel also. Mine looks oem.
Old 08-15-2010, 05:08 PM
  #2293
integlspwr2k's Avatar
s2000 cluster with pigtails for sale!
http://www.hondamarketplace.com/show....php?t=2820668
Old 08-30-2010, 06:22 AM
  #2294
luchura's Avatar
Need some help with the dash console lights on ap1 (B10) what is this connected to? (Ground), I have done this, and the dash console lights are still off. At night can't see the numbers and labels, how do I turn this lights on? is it (B3)?, I have tried to connect to the dimmer and it did not work too. What pings turn on this lights? (+) (-)?
Thanks.
Old 09-08-2010, 07:14 AM
  #2295
zco
zco's Avatar
Thanks.
i got same issue on my ap2 cluster in my ek4. help please !
ive wired every other light up, speedo working too !
Old 09-08-2010, 11:57 AM
  #2296
For AP1, connect B10 to ground. That's how it was wired in my DA and in DSM and works perfectly.
As for the AP2 gauge lights, I can't help, sorry guys.
Old 09-08-2010, 05:19 PM
  #2297
zco
zco's Avatar
would that mean the pin A19 on this ap2 cluster ? i'll give that shot today.
http://www.marklamond.co.uk/products...p2_cluster.pdf
also, my driverside seatbelt sometimes does not work. i have to tap the cluster and it'll turn on. im thinking it might be a bulb.. i'll replace that today and see how it goes
Old 09-09-2010, 07:24 AM
  #2298
Yup, should be it.
IIRC, there is a bulb for the seat belt, check it first.
Old 09-09-2010, 11:14 AM
  #2299
If anyone wants to have the Immobilizer Indicator light working on the AP1 cluster you can do it like so:
D15 to power (from the OEM Immobilizer light or to your alarm).
D16 to ground.
Old 09-10-2010, 01:39 PM
  #2300
Bartman201's Avatar
Does anyone sell the AP1 cluster with a custom harness for an EG?
im looking for something plug & play.
Quick Reply: s2k s2000 gauge cluster fully functional in an eg or ek?
