Old 03-11-2006, 09:24 AM   #126
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
iTrader Rating: (3)
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (crxY-49)
Originally Posted by crxY-49
Well why won't the JDM cluster work with your diagram? Do you think it would be just as easy to install?
Thanks
Originally Posted by BlueIntegraBoy
NOTE: JDM Integra Type-R clusters will work with these diagrams. Make sure you know which spec cluster you have. 96 Spec will have a catalytic converter icon near the CEL and the 98 Spec do not. Use the 94-97 Integra diagram for 96 Spec and 98-01 Integra diagram for 98 Spec.
インテグラ タイプR 98-0425
07 Pilot EX-L w/Navi & 4WD, 07 Fit Sport
BlueIntegraBoy is offline   Reply With Quote
Old 03-22-2006, 09:10 AM   #127
Nevaeh Speed
Nevaeh Speed's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
Any pics of ek clusters into any eg's. Post up.
Nevaeh Speed is offline   Reply With Quote
Old 03-22-2006, 09:35 AM   #128
Nevaeh Speed
Here's a pimp one
Some hybrid hacking going on, but super sweet.
Old 03-24-2006, 07:45 AM   #129
urosch
urosch's Avatar
Default Re: -99 EDM ITRcluster in -96 EDM EK3 (NeMoo)
I`ve put 98 ITR cluster in my EK.
But ABS light doesn`t work and also hazard and imobilizer lights don`t work. For hazard light I have done like NeMoo described, but C5 on my cluster is blank. Anyone can help?
Civic VTI `96 (EK4) - sold
´98 ITR #624
http://forum.jdm.si/index.php
urosch is offline   Reply With Quote
Old 03-24-2006, 09:08 AM   #130
JCL
JCL's Avatar
so for a 98 spec itr you just connect to a 92 hatch by using butt connectors?
16x7 + 35 5x114.3 blitz 01 for sale!
JCL is offline   Reply With Quote
Old 04-26-2006, 03:20 PM   #131
h22 ac
h22 ac's Avatar
I just put in a 98 spec us type r cluster into my 95 integra ls. I followed your instructions and everything works great now except the ABS light. It stays on constantly now. At this time i have the wire for the ABS disconnected, because i don't know where to pin it. your feedback is greatly appreciated.
Mahalo
Henry
h22 ac is offline   Reply With Quote
Old 04-27-2006, 02:13 AM   #132
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (h22 ac)
Mahalo
Henry
The ABS light is integrated into the SRS plug (yellow) for 98-01. It would be in pin A4. The ABS light in your cluster harness is located on the 8th pin of the 16 pin plug. The color of the wire is BLUE/RED. Splice that wire to the A4.
インテグラ タイプR 98-0425
Old 04-27-2006, 12:36 PM   #133
h22 ac
h22 ac's Avatar
wow, mahalo for your expertise. U r a Honda Wizard.
Old 04-27-2006, 03:20 PM   #134
Dark19Acura
2000 Acura Integra
Dark19Acura's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (stackz)
I have an integra automatic 98 with a manuel swap obd1
i want to put the 96 JDM spec cluster in my integra what i need to do??? thank you
Dark19Acura is offline   Reply With Quote
Old 05-22-2006, 01:07 PM   #135
james88
james88's Avatar
so i just bought an 98-00 itr cluster for my 92 civic. Do i have to use itr connectors? or will any 16 & 13 integra connectors fit?
james88 is offline   Reply With Quote
Old 05-22-2006, 01:35 PM   #136
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (james88)
Preferably from a 98-01 Integra will work the best, prevent more rewiring. You can also get from a 94-97 Integra, but will have to switch a couple of wires. 96-00 Civic plugs will work, but will have to do major rewiring.
インテグラ タイプR 98-0425
Old 05-22-2006, 02:22 PM   #137
james88
james88's Avatar
ok thanks, so im gonna goto the junkyard find a 98-01 integra, cut the wires about 5 inches back. cut my wires and wire them straghit into the teg one and hook it up that sounds right ^_^
Old 05-23-2006, 01:48 PM   #138
hybridej7
hybridej7's Avatar
Send a message via AIM to hybridej7 Send a message via Yahoo to hybridej7
excellent info......... might have to go out and get me an integra cluster for my civic.....
http://images.honda-tech.com/set1/smile/emthup.gif <U>GOOD BUYERS & SELLERS</U> http://images.honda-tech.com/set1/smile/emthup.gif
kapoosh valve-tracebuzta-96ls-Mr_WETTY-walker111--TyPe-R6-10K4U
hybridej7 is offline   Reply With Quote
Old 05-25-2006, 06:26 PM   #139
james88
james88's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (hybridej7)
ok, can i use any 16 pin and 13 pin connectors? i cant find any itrs around my area so what other cars can i get them from?
Old 05-26-2006, 12:39 AM   #140
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
96-00 Civic or 97-01 CRV
インテグラ タイプR 98-0425
Old 05-26-2006, 02:28 PM   #141
james88
james88's Avatar
thanks brother, ill take a look in the junk yard tomorrow, im sure they got some ******* 96+ civics there.
holla
Old 05-26-2006, 02:55 PM   #142
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: (james88)
Ok, don't forget to cut like 5 inches of wire off. You'll have to repin the wires around first to the Integra cluster (some wire colors won't match the stock Integra harness).
インテグラ タイプR 98-0425
Old 05-26-2006, 10:05 PM   #143
james88
james88's Avatar
Default Re: (BlueIntegraBoy)
i dont think i can repin them, i think they 92 civics are much fater, i think i will just have to cut them off my harness and connect them to the other one
Old 05-27-2006, 03:00 AM   #144
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
No, I meant repin the EK plugs into Integra-like plugs.
インテグラ タイプR 98-0425
Old 05-27-2006, 03:03 AM   #145
thahuhstunna
thahuhstunna's Avatar
Send a message via AIM to thahuhstunna
not my thing, but a fine write up nonetheless... well done
Originally Posted by John Gaherin
We’re just talking about money here. Money is not the maiden’s virtue, it’s the currency of ******.
Originally Posted by rogue420
Fine you win jesus.
http://images.honda-tech.com/set1/smile/emsmilep.gif
Originally Posted by Kenny Rogers
I cheat.
http://www.postgamepub.com/phpBB2/index.php--Up and Running
thahuhstunna is offline   Reply With Quote
Old 06-06-2006, 09:02 PM   #146
standinghollow
standinghollow's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (thahuhstunna)
standinghollow is offline   Reply With Quote
Old 06-07-2006, 10:52 PM   #147
Markis.
Markis.'s Avatar
Send a message via AIM to Markis.
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (standinghollow)
picked up the cluster 2 days ago im a try my hand at it tomorrow so ill let ya guys no i think the hardest part is gonna be mounting it o yea the cluster i picked up was a 96 ls cluster and u wont believe how much i got it for
Coupe Dreams 11
Markis. is offline   Reply With Quote
Old 06-07-2006, 11:19 PM   #148
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (Markis.)
Good luck man. Once you do the first, it's easy.
インテグラ タイプR 98-0425
Old 06-13-2006, 08:46 PM   #149
SanSational
SanSational's Avatar
whynotandrewsan
Send a message via AIM to SanSational
hey, so ... does anyone know if it's possible to swap a GSR cluster into a 1990 Integra??? I know it's possible, but are there any wiring diagrams?
Andrew.
flickr
facebook
SanSational is online now   Reply With Quote
Old 06-13-2006, 08:56 PM   #150
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (90dmintegra)
Yes, it's possible. Search the Integra forum for DA wiring diagram. You will need an electronic VSS and run a wire to the ECU. There's a few threads on how to convert to electronic VSS.
インテグラ タイプR 98-0425
92, 9295, 9401, 97, 98, civic, cluster, dc2, diagram, ecu, honda, integra, pieces, s2000, swap, wiring
