Old 03-25-2015, 09:20 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Tech Article: Valve Lash Adjustment
Old 05-18-2007, 08:23 AM
  #76
EE_Chris's Avatar
Default Re: (PhatAcuraIntegra)
Just set the #1 piston to TDC and do all of its valves. Then set #3 to TDC and do all its valves. Then do #4...and #2.
You can only set ALL of the valves for a particular cylinder when that particular piston is at TDC on the compression stroke. But when you've got #1 to TDC, it just so happens that the intake valves for #2 are closed and can be adjusted...same story for #3's exhaust valves.
At the end of the day, just do one cylinder at a time - it's not confusing that way.
Old 05-18-2007, 07:40 PM
  #77
HeikDiesel's Avatar
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Just set the #1 piston to TDC and do all of its valves. Then set #3 to TDC and do all its valves. Then do #4...and #2.
At the end of the day, just do one cylinder at a time - it's not confusing that way.</TD></TR></TABLE>
When you start running valves on 16 cylinder engines youll learn to only roll them twice
Make it simple. When #1 is on TDC (all 4 rocker arms loose) set all 4 of those, the two intakes on 2 and the two exhaust on 3. Roll it 360* and set the rest. Cake
Old 05-20-2007, 07:33 PM
  #78
nihad's Avatar
Hey my problem isnt that i dont know how to set them. It s that i think i have the wrong springs or the retaingers. so they dont come up all the way. ANd for that they tick Are
all the d16 engine valve spring and retainers the same like zc and the rest. Oh they are
JGE Spring and Retainers i believe got it with a head.
Old 05-20-2007, 10:13 PM
  #79
HeikDiesel's Avatar
Default Re: (nihad)
Well springs only return the vavle from the open postion to closed so aftermarket shouldnt affect the lash setting at all. I guess I could make a video if its really that confusing. As for the zc being the same as d16 I don't know
Old 05-23-2007, 08:32 PM
  #80
nihad's Avatar
do it.
Old 05-29-2007, 07:46 PM
  #81
HeikDiesel's Avatar
Default Re: (nihad)
Ill try to get one of my buddies to film and do a video for this...maybe itll help
Old 08-12-2007, 03:49 PM
  #82
redpilltheory's Avatar
Default Re: Tech Article: Valve Lash Adjustment (Sehc Tib Alli Zerif!!!!!)
Thank you, nice write up.
Old 04-16-2008, 07:47 PM
  #83
Metal Head's Avatar
Ahone else confused by it saying #6 ? ?? ? ? ? ? We dotn have 6 cylinders
Old 07-27-2008, 03:40 PM
  #84
HeikDiesel's Avatar
Default Re: Tech Article: Valve Lash Adjustment (Metal Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Head &raquo;</TD></TR><TR><TD CLASS="quote">Ahone else confused by it saying #6 ? ?? ? ? ? ? We dotn have 6 cylinders</TD></TR></TABLE>
Where did I use #6 at? I browsed the post and couldn't find it
Old 07-27-2008, 03:51 PM
  #85
Resident Gearhead
BryanM.'s Avatar
Default Re: Tech Article: Valve Lash Adjustment (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">With all of the engines that I have built I set all valves for the cylinder at TDC and then do the intake valves for the next cylinder and then the exhaust. Now you must either set #6 to TDC or #1 to TDC.</TD></TR></TABLE>
Just a typo big deal.
Nice write up, great pics too
Old 07-27-2008, 07:08 PM
  #86
HeikDiesel's Avatar
Default Re: Tech Article: Valve Lash Adjustment (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Nice write up, great pics too </TD></TR></TABLE>
It wasn't a big deal, I just wanted to know where it was so I could fix it.
Old 07-29-2008, 08:24 AM
  #87
95sihb's Avatar
(just under the last picture) Good job.
When #1 cylinder is on TDC, this would be the closest to the driver side, I set all 4 valves for that cylinder, the intake valves on #2, and the exhaust valves on #3. After this you rotate the engine 360* and put #4 cylinder on TDC with #1 cylinder on overlap. Once again overlap is when exhaust valves are closing with intake still opening. You can make sure of this by grabbing the rocker arm with your fingers and try and move it up and down. It should have no play on either intake or exhaust<U>. With #6 on TDC </U>I set all 4 valves for #4 cylinder, intake valves on #3 cylinder and exhaust valves on #2. Check all with a torque wrench and after wards check to make sure clearance hasn't changed
Old 07-29-2008, 08:39 AM
  #88
HeikDiesel's Avatar
Default Re: Tech Article: Valve Lash Adjustment (95sihb)
Fixed it. Should be good to go now
Old 07-29-2008, 10:10 AM
  #89
D50boy's Avatar
Shouldn't you be checking the clearance between the rocker arm and camshaft? I think you may have goofed.
Old 07-29-2008, 10:19 AM
  #90
HeikDiesel's Avatar
Default Re: Tech Article: Valve Lash Adjustment (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't you be checking the clearance between the rocker arm and camshaft? I think you may have goofed.</TD></TR></TABLE>
No, you check it between the tip of the valve and the foot of the rocker arm. When you check that clearance the rocker arm is seated against the camshaft
Old 07-29-2008, 10:32 AM
  #91
D50boy's Avatar
http://www.c-speedracing.com/h...t.php
I was going by this. The one for the SOHC is the same. Not calling you out or anything, I'm just curious to why you checked at that spot.
Old 07-29-2008, 10:45 AM
  #92
HeikDiesel's Avatar
I can't view that site but if they are checking it between the cam and rocker arm that would be the same clearance as valve stem to rocker arm. When you push that feeler gauge in at the valve stem it pushes the rocker arm against the cam. When you put a feeler gauge between the camshaft and rocker arm it pushes the rocker arm against the valve stem. I've just never heard of anyone checking it there
Old 07-29-2008, 01:24 PM
  #93
methos713's Avatar
Rotate the engine and watch the exhaust valve to open and when it starts to close(the rocker arm moving up) look for the intake valve to open. When it just barely starts to move you can set all valves for #1 intake on 2 exhaust on 3. Rotate it 360* and do the same that you did for 4 to #1 and set the rest of the valves.</TD></TR></TABLE>
Can this be done on B-series also?
Old 07-29-2008, 01:39 PM
  #94
HeikDiesel's Avatar
Default Re: Tech Article: Valve Lash Adjustment (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">
Can this be done on B-series also?</TD></TR></TABLE>
Every inline engine I've worked on that's how I set the valves
Old 09-16-2008, 12:26 PM
  #95
daytripper46's Avatar
I don't get it. I have a 2000 Honda Civic 1.6L. I would like to try to do a valve adjustment. I have read your answer. When adjusting the valve for #1 cyl at TDC, do you adjust both the intake and exhaust? Or do you need to rotate the engine 180 degrees?
Thanks,
daytripper46
Old 12-29-2008, 10:18 PM
  #96
skateroyals's Avatar
i know this a dumb question but i cant figure out what cylinder is number one the cylinder closet to the dizzy or the cam gear?
Old 01-24-2009, 06:45 PM
  #97
jdmdc2boi12's Avatar
wow verhy nice
Old 03-07-2009, 07:13 PM
  #98
mattliston's Avatar
oldy goldy, Just used this thread for a weekend maintainence impulse, thanks OP
Old 03-07-2009, 10:26 PM
  #99
T Rick agin's Avatar
Default Re: Tech Article: Valve Lash Adjustment (PhatAcuraIntegra)
sweet write up
Old 03-07-2009, 11:08 PM
  #100
lpite's Avatar
My addition would be that it might take you awhile to figure out what the proper drag of the feeler guage is like. I know it took me 3-4 tries to get it just right, I was doing them too tight and it would idle like poo.
Quick Reply: Tech Article: Valve Lash Adjustment
