| Welcome to Honda-Tech! | ||
#51 |
which fuse is for the turn signal on a 94 civic ex? I only saw a fuse for the turn signal on the 96-00 civic diagram...
Girls are like cars you want every hot one that you see, but you only love yours. Good Sellers: b18cEK Good buyers: 95 Integra, honda_0910, cybergreencivic, siboosted |
#52 | |
#53 |
you have a underhood diagram of the 92-95 fuse box?
#54 | |
#55 | |
H-T White Ops
I AM NOT YOUR FRIEND (unless I am). DO NOT PM ME. _ If you make a thread then (1) more people will be able to answer and (2) the information can help others! |
#56 |
so what you basically are sayign is that you dont have power going into the fuse box. the ignition switch is not a heavy load bearing player int he car, it is mostly just changing low current signals, the switch is after the fusebox. if you dont have power going into the box, then check the power going in more thoroughly, or the ground. try doing a voltage drop test with a load on. such as headlights, i know they dont work, ut just have them switched on.
wish in one hand, crap in the other, see which fills first. |
#57 |
Sweeeet!
POSTURE Sitting Right posture.bigcartel.com SSR Vienna | Nardi | Project μ | wēk´sôs |
#58 |
thanks, i needed this
#59 |
#60 | |
#61 |
Good ish...
#62 |
1993 Honda Civic |
Under Hood 92-95 Honda Civic.
R.I.P. 93 Honda Civic EJ1, Stolen, Stripped Burned :-( Vouches: "bschulz", "germanegturbo", "Itr-Mugen" |
#63 |
1994 Honda Del Sol |
Subscribed. Excellent resource.
::My 94 Del Sol SI Build:: |
#64 | |
Anyone know where to find the wire diagram on 96 honda civic inside fuel panel on number 15 as the picture here. Its say the fuse 7.5A on number 15 to the alternator, VSS, and ELD. I having problem with this fuse, keep on burnt out. I check all the wire harness on the engine bay didn't find any bad wire harness and also the ecu.
I need a diagram on this fuse number 15 so I can check to see which wire is...how to track and see what's causing this problem. As I search on here, found couple of others answer about 2 extra plugs that aren't using that those might be touching or loose. Therefore, I already check them and put electrical tape around its to make sure not touching anything. Thanks everyone Quote:
#65 |
H-T White Ops
civicx, can you please remove the giant quote of images from your post?
I can see about getting you information later today.
#66 |
Sorry about that. I did removed and what's left are information that according to my car. I don't know why I kept having this problem. I did rechecked all the wire harness again on the engine bay and the wire harness by the ecu or near the ecu. I don't see what cause this to burnt fuse. On CONNECTOR "D" to the ecu on the last plug 16 (wire color: green/red) ELD or Electrical Load Detector. I checked this wire to the engine bay, I don't see anything that loose or cut anywhere and its plug good into the ecu on this Connector "D". This is the only plug that labeled "Electrical Load Detector".
Everytime, the fuse 7.5A on number 15 inside the fuse panel burnt out. It's has a check engine light and its show code 20 which ELD. With this caused the SPEED stop working, probably the alternator too. I'll try and change the alternator to a different one and see if any help. Before, I never has this problem, everything has been working good, no check engine light or anything. However, my engine got damage and I replace the long block using whatever plugs left on this long block because its is the same OBD2A. All I did was plug and play after all, nothing changed. Thank you, I hope you can give me some help. As I search through the internet I saw couple others were having the same problem but the result was not solved. Some say replace the engine fuse box to solve this problem. I thinking of doing that but as I checked mine and compared to a friend of mine. I don't see why I need to change this fuse box. The positive and negative wires that connect to the fuse box are still good and not touching each other as I having problem in the past on my other civic. As far as other fuses that are inside this fuse box are still good. In fact, I already change all the fuses in there to new one other than the black fuse box. |
#67 |
Where under the dash is the underdash fuse/relay box... the second one?
#68 |
H-T White Ops
It's behind the little door that's on your driver's side.
#69 |
Thanks, great information. This was not in my owner's manual.
#70 | |
H-T White Ops
![]() I would like to try to help, but want to try to keep the clutter down in this thread. I'll post in your new thread though.
#71 |
2004 Honda S2000My Garage |
I love this thread.
Every 96-00 Civic ive been in had a broken fuse lid cover.
2003 Honda S2000 Sebring silver (RIP) 2004 Honda S2000 Nighthawk black pearl (current) |YOU DON'T NEED A CAMBER KIT, YOU NEED AN ALIGNMENT| |
#72 | |
H-T White Ops
It looks like it has to do with the stock security system. What exactly is going on with the car besides the blown fuse?
#73 |
dam i cant find whats wrong with my daytime light they dotn stay on
#74 |
can u link the daytime running light relay cant find on my honda civic hatchback cx 2d (1997) the year and its purple btw and im a guy incse lmao
#75 | |
1996 Honda Civic |
BTW- Make sure that fuse #17 (7.5 A) is good because this is used with the IG2 power hookup. |
| Tags |
| 1993, 1998, 93, 98, box, civic, del, diagram, fuse, honda, locations, panel, sol, windshield, wiper |
