Will a bad heater core cause the engine to overheat?
Old 04-27-2004, 01:45 PM
NatedoggAZ's Avatar
Default Will a bad heater core cause the engine to overheat?
curious about this one....
may have been the cause of my old engines problems...want to be sure that same problem does not persist with my new swap...
thx!
Old 04-27-2004, 01:58 PM
lsvtecracer's Avatar
Default Re: Will a bad heater core cause the engine to overheat? (NatedoggAZ)
If the heater core is leaking then yes it will cause the car to overheat because the cooling system will slowly lose all the coolant. You can bypass the heater core, but you won't have heat in the winter time. It's a temporary fix if you don't have the time or money to fix it.
Old 04-27-2004, 02:00 PM
NatedoggAZ's Avatar
gotcha, where will the coolent be leaking - on the inside or outside?
Also, I do live in Arizona and we rarely use our heatrers here...
maybe I should just bypass it for now if it turns out to be the problem - is that a pain in the ***?
Old 04-27-2004, 02:23 PM
Race Egr's Avatar
If its leaking you will smell antifreeze inside ur car. It's a major pain to replace to, you have to pull the whole dash out. Just bypass it if you dont use your heat.
Old 06-25-2014, 05:15 AM
Dc4cris's Avatar
I did a heater core bypass cause the collant was leaking into my carpet and the car would over heat but it still seems to over heat does anyone know why??
Old 06-25-2014, 05:30 AM
I never narc'd on nobody!
NotARaCist's Avatar
Well for starters, don't bump a 10 year old thread. Ever. Just don't do it.
The overheating obviously wasn't being caused by your heater core. You have a leak somewhere else. Start finding it.
mjmonteiro
03-23-2016 10:25 AM
slowassBubble
01-13-2010 11:07 PM
Manny1987
Honda S2000
12-18-2009 06:24 AM
Ohannon7
11-30-2008 06:08 AM
md88hfcrx
10
12-20-2005 01:08 PM
Quick Reply: Will a bad heater core cause the engine to overheat?
