Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 04-11-2004, 07:38 PM   #1
Civiclx
Garage is empty, add now
Civiclx's Avatar
iTrader Rating: (0)
Default HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
did a search, I have an autometer boost gauge and a blitz dtt turbo timer that reads boost in khpa, does anyone know how to convert these measurements?
__________________
VOUCH FOR CIVICLXhttp://www.honda-tech.com/zerothread?id=697609 VOUCH FOR CIVICLX
Civiclx is offline   Reply With Quote
Old 04-11-2004, 07:44 PM   #2
TurboTegB18c
TurboTegB18c's Avatar
iTrader Rating: (0)
Send a message via AIM to TurboTegB18c
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Civiclx)
1 bar is equal to 14.5 psi. so u take whatever bar u get and multiply by 14.5 and that's ur psi.
__________________
Trackmasters
Dynojet tuning
http://www.etrackmasters.com
Dealer for Rocket Motorsports
http://m24x.zeroforum.com
Need References?? My vouch thread http://www.honda-tech.com/zerothread?id=382495
Best ET: 10.307@146.73mph
Best MPH: 10.398@148.56mph
TurboTegB18c is offline   Reply With Quote
Old 04-11-2004, 07:54 PM   #3
alpha
alpha's Avatar
iTrader Rating: (0)
Send a message via AIM to alpha
http://www.supramania.com/conversions.html
alpha is offline   Reply With Quote
Old 04-11-2004, 07:54 PM   #4
Civiclx
Civiclx's Avatar
iTrader Rating: (0)
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (TurboTegB18c)
is bar the same as hkpa? because my turbo timer reads it in hkpa? i thought bar was kg/cm^3
__________________
Old 04-11-2004, 07:59 PM   #5
Civiclx
Civiclx's Avatar
iTrader Rating: (0)
looks good, but what about hkpa and mpa (wrx stock gauges)
__________________
Old 04-11-2004, 10:00 PM   #6
EFb18b
EFb18b's Avatar
iTrader Rating: (0)
Send a message via AIM to EFb18b
Quote:
14.5psi = 1 bar
1 bar = 1.0197 kg/cm^2
EFb18b is offline   Reply With Quote
Old 04-11-2004, 10:05 PM   #7
Hoosier Daddy
iTrader Rating: (0)
For the V/SAFC guys:
(kg/cm^2) = PSI
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi
Hoosier Daddy is offline   Reply With Quote
Old 04-12-2004, 02:12 AM   #8
MiraiZ
1998 Acura Integra
My Garage
MiraiZ's Avatar
iTrader Rating: (0)
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Hoosier Daddy)
there must be tons of conversion calculators on the net Click the image to open in full size.
__________________
1998 Honda Integra Type R Turbo (All JDM) est. 320whp (race car)
1992 Rover Mini Cooper (team car) est. 90whp (sold)
2004 Subaru Forester Cross Sports 2.0 Turbo est. 210 whp (daily car)
MiraiZ is offline   Reply With Quote
Old 04-12-2004, 05:26 AM   #9
Honda Hick
Honda Hick's Avatar
iTrader Rating: (0)
Send a message via AIM to Honda Hick
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (MiraiZ)
Quote:
I like this site the best. It converts EVERYTHING.
http://www.convert-me.com
1 psi = 6.895 kilopascal (kPa) or 68.95 hectopascal (hPa) or 0.06895 bar.
I don't see a khPa, but I'm assuming it is kPa.
Honda Hick is offline   Reply With Quote
Old 04-12-2004, 05:32 AM   #10
DaX
iTrader Rating: (0)
Actually,
1 bar = 10^5 Pa, which is approx. 1 atm, or 14.7 psi.
Just do a google search on pressure conversion, there are tons of websites.
DaX is offline   Reply With Quote
Old 04-12-2004, 07:19 AM   #11
Civiclx
Civiclx's Avatar
iTrader Rating: (0)
Default Re: (DaX)
Quote:
Originally Posted by DaX
Actually,
keep in mind that is atmospheric pressure which is completetly different than a manifold vacuum
__________________
submit to reddit
Tags
12, 15, bar, blitz, boost, conversion, converted, dtt, guage, khpa, lbs, mpa, pounds, psi, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
