97 GSR Not Starting .. Suggestions needed
#27
Re: 97 GSR Not Starting .. Suggestions needed
#30
crank it and pull a plug, it should have gas on it. if it does then:
http://techauto.awardspace.com/ignition.html
#31
#32
yes its spraying good i just change my fuel filter fuel pump .. didnt check spark yet but i brough new one gonna try em on later ill let u guys kno .
#33
UPDATE:
ok, so because of the fuel pump struggle the dudes at High End Autosports in Convina, CA hooked me up with great pricing on their SS brake lines & a SS clutch line.
I also bought a new CMC & CSC which will hopefully solve the problem of it not going into gear
Going to try making some gains on it today
#34
ALSO!!
I don't want to post another thread in the brake tech section, but the GSR has ABS and I'm wondering with changing the lines to SS affect this? And do I also have to bleed the ABS system when I do the lines? If so how do i do that?
Thanks again!
Thanks again!
#36
#37
Update:
I'm not sure what car god I pissed off, but I'm getting no luck.
"Bench bled" the CMC and got it all working. Clutch pedal feels great.
Went to go start and NOTHING.
Mind you, I literally started it like 2 weeks ago a few times over when I replaced the fuel pump. Thats the video I have embedded. All I did was change the CMC and CSC thats it!
It wouldn't cycle at all. While I was dealing with that, the shitty alarm installed kept going off, so I cut the power wire:
After that an annoying clicking sound wouldn't stop sounding in the right lower driverside kick panel area. and no its not the main relay. The click would continue for a few seconds even after I disconnected the battery.
I noticed the bulb on the crap alarm system blinking and also the red light on the CD player blinking.
I've really got nooooooo damn idea what the problem is and why the pump wont cycle. I thought I was going to cruise the GSR around the neighborhood, apparently I was very very wrong. Please help
#38
you sure your clutch pedal is adjusted properly?
after i replaced cmc i had to adjust so it would hit the switches.
http://112.imagebam.com/download/ssP...ch%20pedal.jpg
#39
#40
Sweet for you ARR but that sucks for you Bryan, so is current actually get to the pump. I always wondered if you could just remove the banjo bolt at the filter put it an bottle or something then turn the key...
By that I mean the pressure wouldnt be too high and spray too hard to hold even in a bottle and my bad I didnt read the 2nd page before I posted hehe
#41
#42
Did you test the battery, I let the light on once and drained the battery, it sounded just like you said after, freaked out at first but boosted it no problem.
#43
Thanks tho!
DC5yo
05-19-2015 12:03 AM
RobbieDB
07-06-2007 09:11 AM
