► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
#76
#78
Re: ► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
Is there a difference in a hydro clutch gear and a cable clutch gear, and can i change all b series transmission gears with other b series?
#79
Is there a write up for which water pump and timing belt are the best? Pros and cons of OEM vs Gates etc.
#82
Hello. Can someone point me in the direction or share a link(s) on how to do a timing belt change on a Gen3 99' Integra LS non-vtec? Basically i just wanna know if the integra uses an AUTO or MANUAL tensioner for the timing belt tension but i'd also like to see how it's done and any tips from anyone else who's done this before. Thanks.
#84
Hey guys, im having this issue in my 1993 DA9 Acura integra with a b20b and a 5 speed. One time i tried starting it to go to work but the clutch safety switch was not engaging so the car wouldn't start. So i bypassed the two cables that are in the connector from clutch safety sensor on top of the clutch pedal, so car start working again without a problem. Then a few month after my shifter linkage got bent so car was stranded about two months while the parts arrived (live in a 3rd world country lol) so i fixed my shifter problem but now my car wont start and its having that symptom from the clutch safety switch and its not not cranking. I'm looking for suggestions on what it could be since i cant seem to find any leads or solution for my problem. I would truly appreciate it if someone could guide me
Jimmy
10-29-2018 07:55 PM
