Best mods for a Accord with K24a1 engine
1 Post
Hi Guys,
A customer of ours wanted to build his 7th generation accord which comes with a K24a1 engine here in india.
What are the best mods that we can do to the car keeping in mind the car has to be a daily driver running on 91 octane. Looking for a 275-300whp NA car. Is it possible on stock K24a1 block?
Had thought of the following stuff
1> swap head with a K20 type R head and get it ported by Tom or Luke(if he has time)
2> Upgrade cams and valve train(DDtech or skunk2 pro 3)
3> Change Intake Manifold & TB - brands & size ?
4> Change exhaust
OPTIONAL
Install a Supercharger(heard we loose AC & PS) if true then cannot work for him.
Looking forward to your advice and suggestions.
Jignesh
4> Change exhaust
OPTIONAL
Jignesh
Re: Best mods for a Accord with K24a1 engine
k20/k24 with mild mods will be the best way to go personally he will get the best of both worlds a high reving torque engine and pulse it will be close to the 275-300 hp he wants
275-300 will not take anything crazy with the K24.
K24 bottom w/ K20R head and good cams--head porting isnt a must..those heads flow well stock.
I'm not great w/ the K series "lingo" but the RBC manifold and larger TB seems to be the ticket.
I would get ahold of stefan at ASP and have him build you a header
K pro and tune the hell out of it. You will see what you want.
Are you looking for peak power only?
250-300 on fraken k's have gotten cookie cutter, which is awesome.
You can achieve your goal with off the shelf parts.
GhOSt_Db8
11
04-15-2014 10:24 PM
