SYNCHROTECH *** DISCOUNTS & SPECIAL OFFERS ***
#126
Re: SYNCHROTECH *** DISCOUNTS & SPECIAL OFFERS ***
MFactory Racing Clutch
For modified street and race engines, our Racing Clutch offers sufficient daily drivability with a comfortable pedal feel and quick engagement
Made in Japan
High Clamp Pressure Plate
6-Puck Carbon Metallic Disc with High Torque Sprung hub & disc Assembly offering good wear characteristics under low and high stress usage
Includes Bearing & Tool Kit
Rated to 400lbs
Fitments: Currently available for Honda B-Series (Cable & Hydro) Transmissions. Honda D-Series, H-Series and K-Series coming soon
Price: $399.95
MFactory Racing Flywheel
Achieve increased throttle response and acceleration with the MFactory range of single-piece lightweight Racing Flywheels
CNC machined from Forged Chromium Molybdenum (Chromoly) to exacting tolerances and precision balanced to over 12,000rpm, our range of lightweight racing flywheels are specifically designed to reduce weight and inertia for improved engine response and acceleration
Made from imported Japanese SAE 4140 Steel
Forged, Double Tempered and Super Sub-Zero treated for unsurpassed toughness
Proprietary surface treatment for increased surface hardness
Fitments:
MF-TRS-09B16 - Honda B-Series (9lb Chromoly-Zinc Racing Flywheel)
MF-TRS-09K20 - Honda K-Series (9lb Chromoly-Nitride Racing Flywheel)
Price:
Honda B-Series - $219.95
Honda K-Series - $239.95
Made in Japan
Rated to 400lbs
Price: $399.95
Fitments:
Price:
#133
We have the LS 5th gear set for $175. It is a simple gear swap of the 5th gear on each shaft. Everything else is the same so you will not need any other parts unless you want to freshen up the trans while it is open.
#142
Hello Synchrotech, i want to buy this rebuild kit, could u ship to chile?
http://shop.synchrotech-transmission...SYN107-YS1.htm
aslo i need more info about the sleeves and hubs u have, i have a LS YS1 transmission, im building a high rpm non vtec engine for 402m
thank u!
thank u!
#143
thank u!
thank u!
Yes we ship to Chile with PayPal or wire payment. If you need the sleeves and hubs, get the Master kit and it will include the 1/2/3/4/5 sleeves and I will include a free new 3/4 hub: http://shop.synchrotech-transmission...YN107B-YS1.htm
#144
#145
Here is a link for the LS YS1 Carbon master kit: http://shop.synchrotech-transmission...SYN107-YS1.htm
#146
We now offer 3 different types of 3-4 synchros for all Hydro Vtec B-series and YS-1 Vtec transmissions. The Brass synchros are great for Daily drivers and the Newly added Carbon Fiber Lined synchros are great for street/strip cars. The Carbon Composite Pro Series synchros are the best option all around and are what Racer's prefer!! FOR ALL SYNCHRO INQUIRIES>>>PLEASE SEE OUR SYNCHRO PAGE:
http://shop.synchrotech-transmission...ynchros_c2.htm
#149
http://shop.synchrotech-transmissions.com/
New Items! We now have the K20 5-6 sleeve, Y1 5th sleeve and H23 3-4 sleeve available.
Synchrotech® Hardened Sleeves $99.95-$149.95
B16/B18 1-2 Hardened Sleeve $149.95
B16/B18 3-4 Hardened Sleeve $99.95
B16/B18 5-R Hardened Sleeve $99.95
K20 6 speed 1-2 Hardened Sleeve $149.95
K20 6 speed 3-4 Hardened Sleeve $99.95
K20 6 speed 5-6 Hardened Sleeve $99.95
Y1/S1 1-2 Hardened Sleeve $149.95
Y1/S1 3-4 Hardened Sleeve $99.95
Y1/S1 5th Hardened Sleeve $99.95
H22 1-2 Hardened Sleeve $149.95
H22 3-4 Hardened Sleeve $99.95
H22 5-R Hardened Sleeve $99.95
H23 3-4 Hardened Sleeve $99.95
D16 1-2 Hardened Sleeve $99.95
D16 3-4 Hardened Sleeve $99.95
D16 5th Hardened Sleeve $99.95
D17 1-2 Hardened Sleeve $99.95
D17 5-R Hardened Sleeve $99.95
