New Battery, New starter, still wont start.
Old 04-23-2014, 08:22 PM
zc_mike's Avatar
Default New Battery, New starter, still wont start.
I'm thinking it's not grounded, but maybe someone else has had same problem.
My starter was fried (Had to push start everywhere)
Got the starter, went ahead and replaced the four year old battery, and still won't crank over.
Has a fast paced clicking sound from starter, it just will not turn over.
Any ideas?
I'm running new grounds tomorrow, but any input will help!
this is in a 92 civic CX with ZC swap, manual.
Old 04-23-2014, 08:27 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: New Battery, New starter, still wont start.
is your 1972 nova auto or manual?
Old 04-23-2014, 08:29 PM
zc_mike's Avatar
manual.
The starter is getting power to it, so it's not the clutch safety switch, or neutral safety switch, whatever you wanna call it.
Old 04-24-2014, 05:08 AM
moss500's Avatar
If you haven't, take a look at the fuses, see if your starter signal or another is blown.
Old 04-24-2014, 06:37 AM
mikekh10a's Avatar
besides grounding, there could be other problems in the wiring.
1 problem i've ran into personally is corrosion on the wire going to the fusebox. poured some coca cola on it, and it was all better.
Old 04-24-2014, 11:40 AM
ElectronBlue00's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Go through this, and if you have any issues after this... let us know.
Old 04-24-2014, 07:52 PM
zc_mike's Avatar
Alright!
Got it solved.
I cleaned up all grounds, and went to local auto store, bought a meter of 4 gauge grounding wire, ran it from negative terminal (With new terminal connectors), and ran it to engine.
Runs like a ******* charm and turned over first time after that.
Thanks for all help!
street_ride14
08-25-2014 05:20 PM
wastedfaith
38
07-10-2011 03:14 PM
Din
06-27-2011 11:18 AM
go2sleep
05-06-2007 08:42 PM
ZexyAccord
01-09-2006 03:34 PM
Quick Reply: New Battery, New starter, still wont start.
