Won't start.
Old 04-13-2014, 11:30 AM
Honda_bed's Avatar
Default Won't start.
My 96' isn't turning. Electronics turn on. New alternator, nee battery, and the starter is good. I had all these tested but it still won't turn. What else should I look at?
Old 04-13-2014, 03:27 PM
Sparksman's Avatar
Default Re: Won't start.
When you say " wont turn" do you mean the crank wont or isnt spinning, or it does spin but just wont run?
Old 04-14-2014, 02:03 AM
Z99doc's Avatar
Is it warm where you live? If so get in uour car turn the key in the on position you should hear a tickx2. If you dont hear these ticks its the main relay. Its located under the dash on the drivers side.
Old 04-14-2014, 07:44 AM
bamaland601's Avatar
check engine fuse.
Old 04-21-2014, 10:51 AM
Honda_bed's Avatar
It won't turn it won't run it won't crank nothing. All electronics turn on. My fuses are all good. I'll check the main relay. I can't even get it to run by push starting it.
Old 04-22-2014, 12:22 AM
holmesnmanny's Avatar
My first guess would be ignition switch is bad but you're saying the electronics turn on. I would think maybe you blew the ecu fuse. Check for any stored codes.
And the main relay won't prevent the car from cranking. How do you know the starter is good?
Check the thermostat housing ground. See if it's broke, take it off clean it, put it back on. See if it cranks.
JorgeR559
06-10-2014 10:50 AM
Taimaishuuyo
04-28-2012 07:57 PM
egcivic
11-20-2006 05:32 PM
Rukusmasta2
13
02-07-2006 07:11 AM
PUSHER
06-21-2004 11:21 AM
Quick Reply: Won't start.
