is it worth to tune stock motor ??
#26
Re: is it worth to tune stock motor ??
My point was slapping random parts period isn't a good idea if you aren't following a plan and watching what parts you use. The term "random performance parts" ranges from intakes to clutches to turbo kits. All of which can **** something up if not done right.
To the OP, when I say it's okay to tune a stock motor, I personally would do the whole shebang with OBD1 conversion and Neptune, ECtune, etc. To do it right, you'll be on a dyno anyway, so might as well get all the tuning options you can to maximize the tune and investment.
#28
Nobody likes a moron posting incorrect info to a simple question.
You're like a broken record. It seems all your posts are reserved simply to disagree with everything I say. I've got first-hand experience on the subject, what about you?
#29
#30
j-ktuning has a nice deal on a chipped p28 with an s2/300, that would not only help you now working with bolt ons but you can easily use it later if you decide to put on a turbo or go all motor, no matter what you do its all about what you want dont listen to anyone on what they would do just take advice and make your own decision
#31
before tuning I will install cams,maybe 1 or 2 years later supercharged or turbo.for now i just whant the car to run better an cleaner to
#33
You're a retard stop giving advice. A tune on a light modded H22 will easily yield 15-20hp through out the powerband. Slapping on parts like many of these kids do with out even a simple tune is a waste. Hell a tune on an unmodded H22 will likely yield at least 10-15 hp. have you ever seen the A/F ratios on a stock H22. A tune is never a bad thing...
#34
#35
I would rather leave a prelude completely stock(untuned) and do my best to maintain it than buy parts that I would only end up replacing in the future anyway. If you do decide to tune, buy an EMS like s300 or ectune etc. Something you can use later when you boost. This will also allow the tuner to give you an even more fine tune. (Intake, header, exhaust) These are the ricer mods I was talking about earlier... its just a term used by some enthusiast because everyone has them. Especially on Honda's, the gains are usually minimal to mediocre at best. If you have a goal for your car then shoot for it.
#37
Hey, get yourself together. Your throwing an insult for what? The topic title is clearly asking for opinions. Yours matters no more than mine. And your numbers are bloated btw. If you think its worth it to spend $600 just to get the car tuned... so what. Tuning a car on safc is also dumb... its a waist. If he plans to go turbo/supercharge later then why buy parts that he will be replacing. I have been there done that. The name calling doesn't change my opinion...
(BTW: All manufactures tune the car for emissions purposes only. At WOT the maps are preset and are set-up for engine longevity rather than power,i.e. butt loads of fuel. At least 25% of an engines power is left on the table from the factory)
#39
you're not going to gain 10-15hp for less money.
those numbers are not bloated, i have seen it and done it many many times
and yes tuning a vafc is worthless, sell it, get a chipped ecu with crome for the time being. its cheap and easy
#40
The difference between our statements is mine is not an opinion. You clearly have no idea what you are talking about yet talk with authority and in my book that's a retard. Just because you bought a bunch of random"ricer" parts and did not bother to tune them you saw little gains and feel its not worth it. Did you even do a before and after dyno after you slapped said parts on? Or is it you just "know" there were no gains had?? I digress, the fact is that a tune will greatly benefit an H22 with "ricer" bolt-ons. And the numbers may be slightly high. But you can come damn close with bolt on parts and a tune. Consider this: an H22 with I/E/and at least a decent header(not necessarily one of the best) will gain somewhere in the neighborhood of 10-13 hp by just slapping the parts on as is. Now tune those parts for maximum efficiency and you have a very nice running H22. Many, and I mean MANY people stop with an I/E/H, even though they plan to do more. They simply never get around to it. And purchasing an s300 or similar program to tune now will benefit in the future should the OP decide to move forward with his modding. Yes I also believe a VAFC is a waste. But some tuners can work wonders with it...
#41
I say it depends on the state of the car, what it means to you, and what you really want from it. If you only want more mpg then id listen to those that point towards fuel system treatments, regular maintenance, tuning, etc; but if your looking for more hp from a stock motor you have to be serious. You dont wanna slap on mods but rather make them work together. If you port and polish intake and heads get larger exhaust manifold as needed. If you put in bigger cams look into bigger throttle body. Also keep in mind more power means more strain on the motor. You dont wanna put in stage 3 cams only to shredd your stock timing belt and bend one or more valves. Also keep other upgrades in mind like suspension, cooling, wheels, and stripping out the inside or carbon fiber. Iv got a 92 prelude and your never gunna get mindblowing performance but if you mod, try to upgrade the system rather than just a single part. Hope this has helped!
#43
#44
I think this convo died about 5 years ago... Dont expect a reply from anyone you may be quoting, only new people have been commenting on this thread in the past half decade.
#45
Yes that's what I figured. Thought I would give a try anyways, lol.
Thanks for the heads up though, and about the question, what do u think? I'd appreciate anyone with more experience giving they're useful opinion. Gracias sparksman.
#46
Cool, hey thanks for replying I really appreciate. Especially since sparksman had let me know that maybe no one would answer due to how old this is. Glad I joined!
