wont go pat 4500rpm while driving
Old 04-15-2014, 09:11 PM
bigpudge813's Avatar
Icon2 wont go pat 4500rpm while driving
I have a 96 rs integra jump down to obd1 chipped and base mapped with a b20b was driving fine after I did the swap due to a rod knock to the original engine I had no problems with that motor and my ecu but after driving it for awhile I notice it wouldnt go past 4500 and will 2 step at that rpm range while driving cluster does read how fast I go and I also notice when the check engine light comes on the 2 step will deactivate and let me pass 4500 all I want but the 2 step wont engage at a complete stop like it supposed to do when the check engine light is on can anyone tell what could be the problem thank you any info will help
Old 04-16-2014, 12:52 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: wont go pat 4500rpm while driving
Pull the check engine light
Old 04-16-2014, 03:31 AM
? Why would I do that ?
Old 04-16-2014, 02:45 PM
Anyone have a clue?
Old 04-16-2014, 03:05 PM
Technical Hero
Because the check engine light is telling you to check something on your engine, and it's the cause of your rev limiter?
Old 04-16-2014, 06:42 PM
Before the check engine light comes on is when it when it it wont go past 4500 that is where my rev limiter is set up and engages while driving but as soon as my check engine light comes on my rev limiter is disengaged at a complete stop and while driving it will let me go past 4500 rpm while the check engine light is on
Old 04-17-2014, 01:31 AM
I'm Huge In Japan
VegasInvasion's Avatar
1.) you're a noob.
2.) you clearly didn't search the forums, which IF you read the forum rules, is what you're instructed to do before posting a new thread.
3.) that engine light is literally going to tell you the answer to this problem if you check the codes.
Old 04-17-2014, 06:32 PM
Ok so if im a noob how can you get the engine codes out the car if i got a jumper harness to jump down to obd1? Explain that to me sir?
Old 04-17-2014, 11:21 PM
jvr
jvr's Avatar
Stick either end of a paper clip in the holes of the blue 2-pin connector under the passenger side dash, turn car on, CEL will blink the codes (short vs long blinks is how you differentiate between the first and second digit). At least that's how you do it with a normal obd1 car, if you can't do it due to the swap then sorry I'm not more helpful lol.
Old 04-18-2014, 01:22 AM
Technical Hero
You do it the same way you would normally as listed above ^
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old 04-18-2014, 08:58 AM
thats in a obd1 one car my car is obd2 but with a obd1 computer on a jumper harness thats my whole situation i connected my snap on scanner to the car and says car is not communicating
Old 04-19-2014, 02:39 AM
Technical Hero
No it works for OBD2 as well, your OBD1 ECU will not connect to the scanner. Pull the codes via the method in the link.
Old 04-22-2014, 08:20 AM
thank you sir
delboydavies
Honda CR-V & Element
09-09-2014 08:55 AM
aspire
06-28-2010 10:49 AM
91b16acrx
04-20-2008 09:20 AM
98teg
10-06-2003 07:39 PM
Quick Reply: wont go pat 4500rpm while driving
