What did you do to your integra today?
#3355
Re: What did you do to your integra today?
Traded for it... lol
Well, technically it was on Saturday. Picked this up for my 2002 base rsx
94 LS, JDM front, ITR interior, B18C5 swapped.
#3358
Changed rear lca's, rear upper control arms, front upper control arms, rear struts, extended top hats, brand new dizzy, adjustable rear sway bar links, and last of all new tires all the way around:D
#3359
Bought it!!!!
Have always had civic's in the past, and saw this on craigslist for an awesome deal. Very pleased with it. Besides the previous owner doing a **** job painting the valve cover, and it having 14" steelies/hub caps, it's an unmolested 1995 gsr db8 with 139,xxx miles.
#3360
Old Fart
Snow is gone so went out so see if it would start, [stored all winter] and she fired right up no problem.
Spring is here, so time to put it back on the road, I am single and my winter car ,[89 Dynasty] is no chick magnet, but a little red sports car is. 94
#3361
Bought it!!!!
Attachment 357026
Attachment 357027
Attachment 357028
Attachment 357029
Attachment 357026
Attachment 357027
Attachment 357028
Attachment 357029
#3363
I picked up a much cleaner valve cover that has the original finish. Going to get the oem plug wire cover as well, when I can find one.
I also like seeing that the previous owner changed the oil.
#3365
skunk2 header and fujitsubo exhaust install
full write up
http://noxqcsmotorsports.wordpress.c...tem-install-2/
full write up
#3367
Old Fart
Pulled it out of winter storage, fired right up.
Need a new exhaust system. my 5Zigen is almost as old as the car, [94RS], time to loose the fart can and get something a little quieter so I can drive with windows open and still hear the radio, the boys down at Classified Motor Sports said they can get me exactly what I need, cat back with a resonator test pipe.
Should be here in a few days. will update with pix then. 94
#3370
started with replacing my upper engine mount and bracket, then pulling off my accessory belts to find a seized idler pulley which I removed. Looks like its probably going to be a few days before I finish this little project
#3371
Installed new oem honda shift boot
Put on a new oem honda dohc vtec badge to replace the missing original emblem
Installed koni g/c 450f 350r
Found a nice set of fat fives with h center caps to replace the steelies hub caps.
#3372
Put my blackworks lcr's on. In the process I had to change out my shocks, they were the same ones that were installed on the car when the car was made in 94. All the bolts were rusted out so I had to tourched them out and replaced the hardware including brakes. Soon I'll order my brace from blackworks.
