Intake question...
Intake question...
I bet there have been many discussions about modifying the air intake on a 4G, and I see for sale many kits, with varying tales of their worth and efficiency.
It seems to be that removing the resonator might help, in that it must surely restrict the airflow, but mounting a new filter inside the engine bay also surely isn't a good thing as it'd be warm air that's drawn in.
But what about an arrangement that took air from behind one of the 'nostrils' via a pipe, then forced it over the surface of a cone type air filter? Wouldn't that be a good thing?
Has anyone tried this?
A
A
Re: Intake question...
Not sure what 4g you're talking about, but yes more air is a good thing. On my 5th gen accord I have a ram intake with two dams going in...one from the lower grille and the other via hood scoop. I can't say you'll see big gains in power however you will get the cool whoosh sound, and maybe a slight power increase and as you said warm air is not a good thing
I'll get one within the next day or so, she's all torn apart right now as I had a bit of an overheating issue...fun story, overflow cap came off so I ended up losing most of my coolant without notice until the gauge went higher than normal, opened up the hood and thought the overflow was my only problem and it was too hot to pull the rad cap so I put it back together and the temp went back down, kept driving and then the temp gauge pegged...coasted into my garage and found that the radiator was bone dry. Went into panic mode and started checking the oil and pulling plugs to do a compression test, everything checked out ok so now I'm just waiting for her to cool. Thank god for honda reliability. Any pics of the 'lude?
A
A
Bottom line is theres almost no intake that will give you noticeable gains by itself. They change the sound of the car for sure, but really they just compliment other mods.
