Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord (1990 - 2002)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 10-19-2013, 07:21 AM   #1
qhiggy
1995 Honda Accord
iTrader Rating: (0)
Default Heater (vents) stay running when off.
I have done some research and found a few similar posts but no answer. i went to start my car one day to find it dead so i jumped it. later when i parked my car and turned it off, my fans stayed on as well as the little green lights that show my selection on on climate control. I disconnected the relay for the fans but the lights still stay on. Could this be an ignition problem? 1995 honda accord EX
qhiggy is offline   Reply With Quote
Old 10-19-2013, 07:24 AM   #2
qhiggy
1995 Honda Accord
iTrader Rating: (0)
Default Re: Heater (vents) stay running when off.
also when i turn my car off, i hear a click followed ny the fans powering on. unless i turn them off manually but they r still getting power.
Old 10-19-2013, 11:59 PM   #3
holmesnmanny
Garage is empty, add now
iTrader Rating: (0)
Is the car overheating at all ? Do the fans come on when they key is in the on position or while you're driving ?
Your fan timer unit could be bad.
I'm not sure about the climate control lights. I suppose it could be a relay stuck in the on position. Hopefully someone else knows.
__________________
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is online now   Reply With Quote
Old 10-21-2013, 06:10 PM   #4
qhiggy
1995 Honda Accord
iTrader Rating: (0)
Well its my fans on my dash that turn on wheb my cars off. If I leave my fan on or if I turn them on when my cars off, they woll come on. My car hasnt been over heating though.
Old 10-22-2013, 09:58 PM   #5
holmesnmanny
iTrader Rating: (0)
The fan(1 of them) that is in the dash is called a blower. If you call it a blower people will have a better idea of what you're talking about than if you call it a fan, which refers to those that are inside the engine bay.
I gotta be honest I'm not sure what would cause your issue. Hopefully someone else will have an idea.
__________________
Old 10-22-2013, 10:34 PM   #6
DeadlockRiff
1996 Honda Accord
DeadlockRiff's Avatar
iTrader Rating: (0)
raptor.dark DeadlockRiff
Send a message via AIM to DeadlockRiff Send a message via Skype™ to DeadlockRiff
I have this issue as well, but I believe it has something to do with the harness. The issue originally would occur at random points in time. It has since stopped after I modified the center console to include wiring for packs of switches. This leading me to believe I've "rustled" the issue out so to speak.
It never bothered me enough to find it out, plus as long as you remember to turn it off, the car won't die. Despite the lights for the system remaining on.
__________________
0-60(54)-112+
Can you see the future? 2500lbs, 6 puck unsprung clutch, 8lbs flywheel, Straight cut H22 trans, all tied to a Supercharged Stroker F25B2 that throws dirt? I THINK I CAN!
DeadlockRiff is offline   Reply With Quote
Old 10-26-2013, 07:50 AM   #7
Lost Again
iTrader Rating: (0)
A stuck blower motor relay would allow power to go to the blower when the car is off.....
__________________
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
Old 10-26-2013, 04:46 PM   #8
DeadlockRiff
1996 Honda Accord
iTrader Rating: (0)
Granted, not saying that it couldn't be the OP's problem. Considering the relay is under the hood that wouldn't make sense in my case.
__________________
0-60(54)-112+
submit to reddit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
