Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 10-03-2013, 08:30 PM   #1
jsanchezeEf91
Garage is empty, add now
iTrader Rating: (0)
Icon2 91 civic anti theft questions
Hi I'm a new owner to a 91 civic dx, and before I start dumping money into this thing I want to know what type of security systems work best for all honda owners? I reside in socal so the crime level in this area is low. Some of the ideas I was considering were getting a viper alarm, however I'm really interested in killswitches I just don't know how to do them, if I were to do some I would like to do the fuel pump, main relay, and ignition. Can anyone help me or give me a write up?
I just wanted to ad that I was talking to a guy and this is what he told me to do but I just don't understand can someone please explain go into detail
This is exactly what he told me
On the thermostat housing its 3-4 wires screwed into it those ground wires control ecu main relay dizzy an fuel pump take the wires off connect to one good wire to a 2 prong switch an the other prong run wire to ground make sure switch is were only you no were it is so nobody else no Use the info I gave you very easy an simple to do this is what I an all my buddies have
jsanchezeEf91 is offline   Reply With Quote
Old 10-03-2013, 09:10 PM   #2
jonGSR
1991 Honda Civic
jonGSR's Avatar
iTrader Rating: (0)
Default Re: 91 civic anti theft questions
That's one long sentence. I would have read it but got lost at thermostat.
__________________
www.EF-Honda.com
91 ED3, 91 ED7, 90 ED8, 91 EE2
jonGSR is offline   Reply With Quote
Old 10-03-2013, 09:13 PM   #3
jsanchezeEf91
iTrader Rating: (0)
Quote:
Lol I know I couldn't understand it either. Do you have any suggestions?
Old 10-03-2013, 11:53 PM   #4
schueytenten
schueytenten's Avatar
iTrader Rating: (0)
collage
schueytenten is offline   Reply With Quote
Old 10-04-2013, 01:33 AM   #5
glockjs
iTrader Rating: (0)
no one security system is going to be "best". if somebody wants your **** they're gonna get your ****. the only thing you are trying to do is deter and also buy time for you to get back to your car.
the alarm systems with the 2 way are nice to give you a heads up when your alarm is going off. i went with a crimeguard because it was the cheaper option for an alarm designed for manual tranny auto start. python also makes a nice one for a few bucks more. i also have an old school kill switch hidden and i plan on getting a quick release steering wheel x.O
even with all that if somebody wants my car they're going to get it
glockjs is offline   Reply With Quote
Old 10-04-2013, 02:31 AM   #6
Freemananana
1989 Honda Civic
iTrader Rating: (2)
I have a flat bed with fold down ramps and a 10 ton winch. I'll take your car even if it didn't have wheels. And I'll never go inside.
OP, kill switches are nice. They are about as good as locking your doors. The common day theif often just looks for open doors.
Freemananana is offline   Reply With Quote
Old 10-04-2013, 03:56 AM   #7
jsanchezeEf91
iTrader Rating: (0)
Thanks guys for all the feed back!
Old 10-04-2013, 03:57 AM   #8
jsanchezeEf91
iTrader Rating: (0)
Quote:
Originally Posted by schueytenten View Post
collage
? Do you mean college
Old 10-04-2013, 04:06 AM   #9
jsanchezeEf91
iTrader Rating: (0)
Yup I really just want something that will slow down a thief, because I know that if someone really wanted to get in my car they will do it no matter what. As far as a flatbed I highly doubt anyone will go through all that hassle for a honda S*** with a flatbed my last option would be a honda.
Old 10-04-2013, 04:10 AM   #10
Freemananana
1989 Honda Civic
iTrader Rating: (2)
Quote:
Honda motors are easy to sell. Honda civics are the most stolen car in the states, I believe. That was a couple years ago when I read that.
If you want to slow the theif down. Locked doors, a very well hidden main relay kill switch, and some sort of alarm set up to go off with 1. broken glass 2. hood opening 3. ignition tampering. I have also seen alarms that work with a magnetic field that can go off if someone reaches into, for example, a convertable with the top down. I assume those are pretty pricy, but it's always an option.
Old 10-04-2013, 08:23 AM   #11
jsanchezeEf91
iTrader Rating: (0)
Could you give me a write up on how to do a main relay switch?
Old 10-04-2013, 08:29 AM   #12
Freemananana
1989 Honda Civic
iTrader Rating: (2)
Man, don't want to be overally mean, but use google to search. It's super easy. With that said, I found it for you.
Quote:
Originally Posted by 95TeggyRacer View Post
Main Relay Kill Switch
This modification will disable all components connected to the main relay.
Difficulty: Easy
Time: 20 min. (or more depending on switch location)
I Have included close up pictures for wire, color, and location reference. As well as a list of wire terminals and destinations
Materials and Tools:
-Desired length of wires for switch location (20 gauge or thicker)
Example:
Click the image to open in full size.
(having dual insulated wire like shown makes routing and looming super easy)
-Wire Loom (Get enough to sufficiently if not completely hide all new wiring)
(should be big enough to fit around all wires for harness and new switch wires)
-Electrical Tape
-Wire Strippers
-Wire Cutters
-Soldering Iron
-Solder
-Switch
Example:
(this is the same switch I have/it's a 5a 125vac switch)
-Other Materials For Hiding Switch Better
Steps:
1.Find a location for your switch. (It doesnít have to be hard to access to be well hidden)
2.Make sure the switch fits and wonít have or create any clearance issues.
3.Determine the length of wire needed to extend from your switch to the main relay while staying hidden.
3 1/2. Remove anything necessary to run wires.
4.Run your kill switch wires along your desired path. (leave a couple inches slack on either end)
5.Find the Ground Wire for the main relay harness and cut it at the desired point.
6.Strip both ends of the cut Ground Wire.
7.Strip the ends of your kill switch wires that are at the relay end
8.Solder Kill Switch Wires to the 2 ends of the cut Ground Wire.
9.Tape the new connections to keep the wires insulated.
10.Mount your switch in the desired location.
11.Strip both wire ends at the switch.
12.Solder Kill Switch Wires to the switch.
13.If possible insolate the connections
14.Test the switch. (it would suck to have to tear a bunch of loom and tape off to fix something)
15.Go back and loom all exposed wires. Make your work as hidden as humanly possible.
15 1/2.It was brought to my attention that a thief could easily bypass this by sticking a wire into the pin and
grounding it straight to the body. If you are worried about this you could always relocate the relay. (I didn't
mention this earlier because I didn't feel it was neccessary after all looming and taping was completed)
16.Put Everything back together.
17.Sit back and enjoy your new layer of security
Location of main relay: Right above hood release lever and next to fuse box.
Wire Colors:
1-(94-01): Green/Blue : To ECM Connector Terminal A16 (FLR)
2-(94-01): Blue/White : To ST. Switch
3-(94-01): Black : To Ground
4-(94-97): Yellow/Green : (98-01): ? : To Fuel Pump
5-(94-97): Black/Yellow : (98-01): *Yellow/Green* : To IGN. 1
6-(94-97): Yellow/Black : (98-01): ? : To ECM Connector Terminals A11 & A24 (IGP)
7-(94-01): Yellow/White : To BAT. Positive
Thereís some info that Iím missing for later models. As well as a questionable color for terminal 5. If anyone can confirm and give me the missing info I would greatly appreciate it. Just PM or reply with info.
Please feel free to leave any comments questions or suggestions. Let me know if there is any info I left out or that you need.
Old 10-04-2013, 08:52 AM   #13
jsanchezeEf91
iTrader Rating: (0)
Thanks man I really appreciate and believe me iv done research. The main purpose of this forum is to help others with questions or problems and give each other feedback it might be easy to read or say but actually doing it is the hard part. Again I appreciate your help, I will now try to do this my self
Old 10-04-2013, 09:03 AM   #14
Freemananana
1989 Honda Civic
iTrader Rating: (2)
Figuring stuff out is the hard part for me. I can search and find write ups all day without a problem. Doing it is easy. My engine swap took me months to figure out. There were a lot of little things I didn't understand. But actually doing it, might have taken me a weekend.
Old 10-04-2013, 09:27 AM   #15
4drEF
4drEF's Avatar
iTrader Rating: (0)
Wheel Boot
__________________
All of my posts should be considered for being made into a sticky.
4drEF is offline   Reply With Quote
Old 10-04-2013, 10:43 AM   #16
Freemananana
1989 Honda Civic
iTrader Rating: (2)
Quote:
Originally Posted by 4drEF View Post
The one that covers the nuts is the best. Those things are a pain.
Old 10-04-2013, 11:20 AM   #17
jsanchezeEf91
iTrader Rating: (0)
I'm actually thinking of getting one, you can never be too safe
submit to reddit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
