Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic/Del Sol (1992 - 2000)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 03-23-2013, 09:58 PM   #1
JJT211
1998 Honda Civic
iTrader Rating: (0)
Default Brake pedal squeaks when releasing brakes
On my 98 Civic Cx, the brakes squeak whenever I release the pedal. It sounds as if its coming from under the hood and not the brake pedal itself.
Let it be noted that I did flush/bleed the brakes a week ago and the brakes work amazingly but the squeak it really pissing me off.
Any ideas?
JJT211 is offline   Reply With Quote
Old 03-23-2013, 10:35 PM   #2
JJT211
1998 Honda Civic
iTrader Rating: (0)
Default Re: Brake pedal squeaks when releasing brakes
OK after a thorough search of the forums, this seems to be a FAQ and all signs point ot the rear drum brakes.
Still doesnt make sense as the sound appears to be coming from under the hood. Either way ill check the drums and report back. Any other suggestions welcome
Old 03-24-2013, 03:33 AM   #3
Mr. Bojangles
1999 Honda Civic
Mr. Bojangles's Avatar
iTrader Rating: (0)
I had a 98 DX coupe that did that, and my current 99 EX coupe does it as well. It never caused me any problems, just slightly annoying. I assume something just needs lubed up a bit.
Mr. Bojangles is offline   Reply With Quote
Old 03-24-2013, 05:46 AM   #4
hoorah
1996 Honda VFR 750
My Garage
hoorah's Avatar
iTrader Rating: (0)
I had a Subaru when I worked there which did the same type of thing, that one was the brake switch...believe it or not.
Another issue I have seen on other manufacturers are squeeks from the pads where they meet the brake pad carriers.
GL.
hoorah is offline   Reply With Quote
Old 03-24-2013, 06:04 AM   #5
lacrosse12
Garage is empty, add now
iTrader Rating: (0)
My 00 civic was also doing this. Even when I was to pull up on the E-brake it did it. I didn't look into the problem but I did swap out my drums for rear discs and has been fine since.
lacrosse12 is offline   Reply With Quote
Old 03-26-2013, 06:12 PM   #6
JJT211
1998 Honda Civic
iTrader Rating: (0)
After reading that DIY....i stuck my head out the window and could clearly hear it comjng from the rear drums. Ill def be replacing them soon!
Old 05-10-2013, 05:05 PM   #7
hoorah
1996 Honda VFR 750
My Garage
hoorah's Avatar
iTrader Rating: (0)
don't replace anything. Tear down and inspect. Usually it's the contact points between the shoes and backing plates. Clean all off with water, blow dry with compressed air and apply a lubricant like white lith or antiseize. Manually adjust the brakes and carry on.
Old 05-10-2013, 05:30 PM   #8
JJT211
1998 Honda Civic
iTrader Rating: (0)
Yup you are right....I noticed that after I took the first one off but figured I might as well change em anyway by that point.
submit to reddit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
