Will a sir ecu work on a vti engine?
1 Post
Re: Will a sir ecu work on a vti engine?
If you are talking about the B16A VTI then yes it will run, but not without issues.. The parameters are a bit different such as timing, fuel maps, vtec engagement, rev limiter, etc.. But it will start and drive if that's all you need it to do.. I'd suggest just chip/tune the EDM P30 or buy one for your specific setup to match the more aggressive parameters if that's what you're after..
