Go Back   Honda-Tech >
> Lighting
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 04-30-2012, 01:34 PM   #1
max626
Garage is empty, add now
iTrader Rating: (0)
Default Led guage problem
I ordered a set of replacement leds for my friend 95 civic after installation it didn't work. The secondary lights work (signals ect) but the speedo/tach lights wont work. We then proceeded to put the original bulbs back in which also ended up not working I bench tested the leds they all work and so do the factory bulbs and i have power at board where they mount but they don't light up can anyone help????
max626 is offline   Reply With Quote
Old 04-30-2012, 01:39 PM   #2
Blacknight117
1995 Honda Civic
Blacknight117's Avatar
iTrader Rating: (1)
Default Re: Led guage problem
Check the underdash fuses.
__________________
EG/EJ Sideskirt removal: http://honda-tech.com/showthread.php?t=3043855
Nottin but OEM: www.hondapartsunlimited.com
My build: MY EJ1 Build
Blacknight117 is offline   Reply With Quote
Old 04-30-2012, 01:45 PM   #3
max626
iTrader Rating: (0)
Sorry forgot to add that all fuses were checked also
Old 04-30-2012, 01:48 PM   #4
Blacknight117
1995 Honda Civic
iTrader Rating: (1)
All plugs plugged into that back of the cluster? Make sure their pushed in, sometimes you may think their in when they are not.
__________________
Old 04-30-2012, 01:55 PM   #5
max626
iTrader Rating: (0)
plugs are fine as well, with either bulb placed in they wont light up but when i put the test light to the board where its suppose to make contact with the bulb i have power
Old 04-30-2012, 03:17 PM   #6
gzes
gzes's Avatar
iTrader Rating: (0)
The contacts aren't contacting or are they?
__________________
project nickle n dime: 94 del sol b16
93 del sol wrecked d16 for parts pm me for anything http://hondamarketplace.com/showthread.php?t=3114776
gzes is offline   Reply With Quote
Old 04-30-2012, 03:40 PM   #7
fungus mungus
1992 Honda Civic
fungus mungus's Avatar
iTrader Rating: (0)
Is your dimmer switch plugged in? Do the radio and climate control lights work?
fm
fungus mungus is offline   Reply With Quote
Old 04-30-2012, 04:00 PM   #8
gzes
gzes's Avatar
iTrader Rating: (0)
I no u said even with the original bulbs it doesn't turn on but did u check the polarity on the leds and also did u try more than one bulb? They can look good but be bad aswell
__________________
Old 04-30-2012, 09:43 PM   #9
max626
iTrader Rating: (0)
I tested about 4-6 bulbs, dimmer was plugged in and i tired adjusting it still nothing. As far as it making contact i bent the tabs thinking it was making contact with the board but it was evident it was since it began to smeer the copper on the board. If we have time after work we'll def go through all the suggested steps again just to make sure
submit to reddit
Tags
climate, powered, regional, vbulletin, western
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Emails & Contact Details
