| Welcome to Honda-Tech! | ||
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today! |
#1 |
Garage is empty, add now
i am putting konis with gc top hat on my car today. when i put the top hats on the front shock i could only get one of the nuts on when there is supposed to be two to them the top hat will not go any further down. it seems that the top hat bushing is stoping the top hat short because there is a peice of metal welded to the shock. does any one have a picture of the top of there shocks with the top hats on so i can see what it looks like. any help would be good
#2 |
make sure the bushings and the shaft tube are pressed all the way in. when i had that setup i had to switch the tubes out (they shipped them with the non-koni tubes) and pressing the tubes into the bushings was a pain in the ***.
__________________
91 DB1 sold | 92 DB2 RIP | 90 DB1 Speed kills so put as much stickers on your car as you can! |
#3 |
yea i got the tubes all the way in and i ordered it all together so i dont know why it wouldent work
#4 |
now when this is happening, are the coilovers in the car or in your hands while assembling? maybe you should lower the springs and perches.
__________________
#5 |
I give out free hugs
2004 Honda S2000My Garage |
FWIW I have GC top hats on my progress stuff and I had to play musical bushings/washers/nuts to get it to work lol
#6 |
yea i called ground control and wow the best customer service i have every seen. they told me to email them some pictures and i did and he called and just told me you have to push the sleeve thru the top hat from the bottom bushing and then tighten it up and it will push it all together and after doing that it works thanks
#7 |
do you guys keep your dust covers or do they not really matter?
#8 | |
be professional
Quote:
__________________
1996 Accord | 1998 CB750 | 2001 Integra | 2012 Giant Anthem X29 |
#9 |
absolutely not compatible. you dont need them anyway.
__________________
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
#10 |
bumping because ill be able to sleep easy knowing that i wont need dust covers thanks search engine!
#11 |
2002 Chevrolet Corvette |
you can use $5 off road rancho boots with zip ties should you choose to install dust covers. you just trim a bit to fit
__________________
carpet cleaning beaverton Do you own a turbo honda and want the build to have it's own page for free? see turboinstall.net |
#12 |
1990 Honda Civic |
found this old thread after searching for hopefully an answer to my question....
i am currently putting together my koni/Ground Control coil over kit and ground control extended top hats on the front suspension. is the OP referring to the little cylindrical sleeve that is supplied with the koni's from the factory that slides over the threads of the shock piston and rests on the welded on "stopper" just under the threads? what i'm trying to figure out is do i need to use that little sleeve with the Ground Control top hats or is that only if i was going to be using the stock top hats? thanks |
#13 | |
Quote:
Basically, if the shaft fits, you don't. If it doesn't fit, you do. And before someone else writes it, "that's what she said!". |
| Tags |
| accord, control, extended, fit, g2ic, ground, hat, hats, honda, install, installing, koni, required, tools, top |
