| Welcome to Honda-Tech! | ||
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today! |
#17626 |
Garage is empty, add now
do you think the 550s will be enough injector for e85? Trying to make in the 260-270whp range
__________________
94 Acura Integra- All Motor H2B- 12.6@111mph |
#17627 |
I'd be iffy about that, looks like a unorthodox pulley; known to break oil pumps and other problems.
#17628 |
I believe 750's would be more suited for e85
__________________
DD TECH camshafts*QSD* SYNCROTECH TRANSMISSIONS*PROSTREET IMPORT*FOREVER ASHBURY |
#17629 |
1992 Honda Civic |
I'd be sketched out rocking a crank pulley that didn't have a harmonic balancer within it.
You could get close to that power. Just pump that base fuel pressure lol |
#17630 |
yea thats what i was going to run was 750s but if the 550s would work i was going to scoop them up from you.
What crank pulley would yall recommend? I know for a fact a factory one will not work lol.
__________________
#17631 |
Ek Forever y0!
2000 Honda Civic |
__________________
OMG LIBERTARIAT FINALLY HAS A BUILD Need help choosing suspension? Click here!! Finally for sale! Progress CS-II Coilovers (350/350) setup. Great for daily and entry/mid level autocross. Landed a 1st place win with these on 3/24 ![]() Learning the ropes at The Retrofit Source |
#17632 |
1992 Honda Civic |
I've been using a shaved oem pulley for a while. Krut has a euroR single row on his. That seems to be the general consensus as far as pulleys being used. I think I was at like 70-80% duty cycle when I was making 233 with 45psi base fuel pressure. Duty cycle might be less. To be safe, you can roll with some id725s or 1000s(I think jaywest is using these)
#17633 |
I use ID 725cc and have made 280 and still had more to go
__________________
#17634 |
Fuel injector clinic 900s here
Might do some injector/fuel testing this year.
__________________
Stock Block All Motor H2B 11.32@117.9 Powered by Turbogixxer Tuning |
#17635 |
1992 Honda Civic |
Car fired up today, injectors were not getting power at first, rywire harness had a plug for what looked like it was meant for a resistor box (1 power wire and 4 for the injectors) had to snip the plug off and tap them all to that power wire, started right up after that
__________________
All Motor H2B Stock Longblock: 211/158=12.1@110 2200lbs with driver Stock Bottom/Pro1s: 226/162=11.8@114 2005lbs with driver |
#17636 |
1992 Honda Del SolMy Garage |
Well the Sol is FINALLY in for tuning
![]() custom lower TB cover: ![]() ![]() ![]() ![]() ![]() ![]() Suspension finally fitted: ![]() ![]()
__________________
All Motor H2B Delsol in UK - 260bhp/180lbft QSD-Quaife-Mahle-Eagle-SK2-Innovative-GE-AEM-Hondata www.delsoluk.com |
#17637 |
1992 Honda Civic |
When are you getting tuned?
#17638 |
hMmm, that's what i thought. I knew the OEM pulley will have a problem with the belt going onto the alternator. I need a new belt since i deleted ps and ac. Where can i buy these items ?
#17639 |
lower timing belt cover looks sick!
#17640 |
I guess i should have specified..... The last time the motor went into the car we shaved the factory crank pulley down, but the top of the pulley hit the frame rail and i was not pulling the motor back out to bang in the side. So we decided to use a unorthodox pulley since it was smaller and im pretty sure thats what my problem was with the last motor. The pulley thats on there now isnt the same as i had before and is a different style, but was on the motor when i got it and was running fine.
I plan on beating in the frame rail to give me more clearance this time, so should i go back with the shaved down factory pulley? Edit: keep in mind this is in an integra..
__________________
#17641 |
I purchased a f20b pulley from steve at h motors that may be another option for you.
#17642 |
You should definitely bang the frame rail in and use a shaved oem pulley or f20b single row pulley moved in 1/2"
I am using a stock h22 shaved pulley, with qsd kit and hasport mounts in a crx. all i had to do was bang the frame rail for the alternator and crank pulley. im using an explicit speed alternator bracket |
#17643 |
Looks like i need to go dig up the shaved pulley. Luckily i had no problems with the altenator clearing, its a little tight but no modification was needed.
__________________
#17644 | |
Upper or lower?
Quote:
#17645 |
#17646 |
1992 Honda Civic |
There's really just one spot that you need to bang for eg/dc. So ez, better to be safe than sorry IMO. Especially since you killed some bearings last time with an aftermarket pulley. I'd be paranoid.
#17647 |
Yea i was going to go ahead and bang that spot where the top of the factory pulley hit when the motor comes out. There was just no way to do it without pulling the motor last time and we were on a tight schedule.
__________________
#17648 |
Ek Forever y0!
2000 Honda Civic |
Burned up my logic header today!
__________________
#17649 |
Do I need to relocate my alternator lower,
Or will it work in the stock position? (in an Ek hatch)
__________________
VOUCHES:Tanmt, sung, 95accordH22A, Stealth1, lightning, PerformanceCloseout, SILVER97EX, Danny_EJ, EgSalad, TahitianEG, El_Capitan, White Smoke, gotboosthatch, tamadrummer1120, widebodyeg, Silvertc, 93egboosted, neofreak, a2dadamm |
#17650 | |
Ek Forever y0!
2000 Honda Civic |
Quote:
Besides, any lower you would be in the way of the A/C compressor
__________________
| Tags |
| chasiss, clutch, crx, dc2, ef, effect, gude, h22, h2b, honda, hood, mile, prep, quarter, tilton, time |
