1998 d16y8 civic ex, how do I know if the VTEC is kicking in
while driving what indications should i get to show that my VTEC is kicking in with w/o doing all the testing, Is there a light that comes on to indicate you are now in VTEC mode? I conducted a road test took it up to 6,000 rpm and Hold that engine speed for at least two seconds. but i didnt seen like nothing happened guess I expected to go into warp speed, I currently have a bad knock sensor with a malfunction Indicator Lamp (MlL) but nothing else help anyone
Re: 1998 d16y8 civic ex, how do I know if the VTEC is kicking in
If you have a bad knock sensor, you're VTEC WILL NOT engage
Fix that, and once you get around 5500 RPMS (and above about 30 mph) you should be able to hear the engine pitch go a little higher (much more noticeable with a cold air or short ram air intake because the stock intake box is designed to muffle the noise)
But it's a single cam, not a fire-breathing double cam engine, so don't expect "warp speed"
XD;
XD;
The Grumpiest
OMG to this. At least you admitted it.
If you can get it past 500RPMs as stated you are working to spec.
VTEC on a single cam is nothing to write home about.
[QUOTE=rafe850;46857818] but i guess I expected to go into warp speed,
I was on the floor when i read that part lol......but yea when you fix all that stuff go to a nice clear open road with no cars of course.....and have a intake installed and go from third gear to 5500rpms and try to hear the corssover its bearly hearble but you noticed and yea ...vtec really wont make you go nowhere but reach a higher rev quick with no speed lol
[QUOTE=flmzero13;46858731][QUOTE=rafe850;46857818] but i guess I expected to go into warp speed,
you'll go from rrrrrrrrrrrrrrrrrrrrrrrr.... to BWAHHHHHHHHH once the you hit the crossover lol but as stated, a knock code means vtec will no worky worky :-(
hey guys, so i got a y8 also. And my code is on P0325 which is knock sensor. So i have some malfunction there... and my vtec works just like it should. At 5500 rpms the engine pitch changes like it should. i have a short ram intake so its a little easier to hear.
are you running a chipped ecu??? because with my swap (b16a2) my pr4 wouldn't engage vtec because I didn't even wire the knock sensor... my friend gave me his chipped p28 tuned on crome and had knock and secondary 02 disable and it's a screaming beast lol
oh hey, thats a good point there. havent tried that yet! but i did just buy a new knock senor and put it in...just hanging loosely and my light is still on, so it could be wiring or ecu?
If your wiring all looks good it could be a fried spot on your ecu board... which is why I'm still calling the ecu...
what do you mean hanging loosely??? the knock sensor needs to be in the block to get an accurate reading...
i mean i bought the car, and it was spitting the code. So i bought a new knock sensor and i put it in, and what do you think a few days later the light came on. So i said screw it, and didnt bother with it no more. Now i decided to fix it again. So i went to a mechanic which is a buddy of mine, and he said i should just plug in the knock sensor and let it just hang on the plug to see if the light comes on.... to tell whether it is or isnt the sensor itself. So i did as he said and the light still came on.
ok, well then i will put it in here in the next days! when i have time..... but thanks you guys.
well i thought my vtec didnt work either at first, cuz i was expecting a little pull cuz of my friends b20v that i am used to. But i got no pull... so i tried fixing the problem...which there was no problem! but it was a head ache... then i decided to disconnect the intake hose from the air filter box... and that was when i heard it cross over! so maybe try that??
You should never run a engine without an air filter on it. Thats a quick easy way to suck garbage in the engine and trash it.... just saying.
I have a 4 door with a z6 with I/H and you cant tell any crossover whatsoever! Now when my GSR crosses over you can definately hear and feel the crossover!
Have you checked your oil level? Sounds remedial, but the VTEC solenoid requires proper oil level to activate!
I also have the p0325 knock sensor code for my 1997 Civic along with the following codes:
P1259 VTEC System Malfunction
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption (*I think this is a crankshaft sensor)
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
I already know that the VTEC solenoid is leaking but I am wondering if any of these are related to the same problem.
Any ideas or advice?
stehigs321
15
03-01-2019 05:16 PM
