99 V6 Coupe - P0108, P0122, P0301, P0302, P0304, P0305, P0306, P1399
Old 01-21-2010, 11:22 AM
92integraVTECgsr's Avatar
Default 99 V6 Coupe - P0108, P0122, P0301, P0302, P0304, P0305, P0306, P1399
Neighbor has a 99 Accord V6 coupe. Check engine light is on and the codes are:
- P0108 MAP Sensor
- P0122 TPS Sensor
- P0301 #1
- P0302 #2
- P0304 #4
- P0305 #5
- P0306 #6
- P1399
What confuses me is how come every cylinder except #3 is throwing a miss fire?
Also, what would trigger the MAP and TPS sensors to throw a check engine light?
Old 01-21-2010, 12:17 PM
PilotOnDubs's Avatar
Default Re: 99 V6 Coupe - P0108, P0122, P0301, P0302, P0304, P0305, P0306, P1399
i think your next step is to clear all the codes and see which ones come back...and go from there
Old 11-16-2011, 09:44 AM
kris00's Avatar
Hi,
Mine is 00 V6 Coupe and I have seen the same problem three or four times in the past. I don't think I have seen P0108 or P0122. Last time I got to see (and FEEL) that problem was yesterday. The car has 271000 kms and I am the original owner.
The interesting thing is that this happens when the car has warmed up (never when cold) has been turned off for something like 10 or 15 minutes with the ambient temperature around +12 degrees Celsius and then restarted. Things get back to normal after it warms up again - with the exception of the set trouble codes. And yes, the P0303 is never there.
There is a service bulletin for something similar but it mentions that a freeze frame would indicate the engine was above 4000 RPM. I am reasonably sure the engine was not at 4000 RPM when it was misfiring in my case. Spark plugs are fine too, just drove 80 kilometers (50 miles) without any problems...
Old 11-17-2011, 08:34 PM
crazeewhiteboi's Avatar
I have a 99 accord coupe 3.0 v6, and mine popped up with alot of codes like the map sensor and one of the misfirings (can't remember which one now) and also egr flow insufficient. after replacing my egr, map sensor, and my temp sensor all codes went away for a day, then the egr is reading again, so i replaced the egr again, and now its reading again. my accord is still doing this stalling thing sometimes as well.
Old 11-21-2011, 06:06 AM
kris00's Avatar
Hello,
I now have put an additional 500kms on my V6 Honda and there is no hint of that problem. I should mention that I really go out of the way to fix anything that is wrong on this car - had to re-solder the odometer and the headlamp control unit this year. Anything that goes wrong gets ma attention... fast.
c.w.boi
I have heard that the EGR port needs some serious cleaning when replacing EGR, so... Did you clean the EGR port?
From what I understand the EGR valve has a vacuum connection which is controlled by an electric valve, so if the valve is stuck in the open position there will be some misfiring problems , but not with EGR flow insufficient. I wonder how the computer knows that the EGR flow is insufficient...
Old 11-24-2011, 04:12 PM
I cleaned out the EGR Chamber before replacing the egr the second time. I guess i could try it again. I was told i should use a oem egr valve instead of the one i got. any more help would greatly help. my accord is high mileage...285,000 miles.
Old 11-28-2011, 06:25 AM
kris00's Avatar
Hello,
Well, I just had that misfiring problem again. On Saturday the ambient temperature was just right for this, and after about 25 minutes in the parking lot, when I got back the car would be misfiring. No codes triggered. This time I decided to just let the damn thing cool down a bit more, came back 30 minutes later and... the problem was not there. I really need to get one of those ODB2 things that can show sensor readings.
c.w.boi - I took my EGR valve off this weekend, just to have a look. During the last Emissions test I noticed some NOx particles which I have not seen before. There is an interesting document about the EGR problem:
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
Take a good look. Honda had a warranty extension! I remember I had this problem after six years of driving - at about 135000 km (~83k miles). London Honda fixed this at no charge. I am now at 273000km so it is probably time for another go at this. You might have to take the intake manifold off, just like that service bulletin describes.
Let me know how it goes.
dahd00d
01-16-2024 12:28 PM
drdavidge
24
12-11-2011 07:06 PM
ultragc
09-03-2007 01:24 PM
Quick Reply: 99 V6 Coupe - P0108, P0122, P0301, P0302, P0304, P0305, P0306, P1399
