b18c CEL code p1337 & p1457??????
Old 04-19-2011, 05:48 AM
gsr-t9303's Avatar
Default b18c CEL code p1337 & p1457??????
hey guys i have a 2000 teg with a jdm b18c swap obd2 and these freaking codes are poping up. does anybody know what they are?
any help is great.
Old 04-19-2011, 11:20 AM
53JDMDC2's Avatar
Default Re: b18c CEL code p1337 & p1457??????
the 1337 is cause you dont have a crank sensor any more with the jdm engine.
google CKF trick it should help.
on the CKF trick dont use the blue connectors he shows. use red ones they r for small wire. Dont cut any wires. and depinning i dont think will work cause the cpu needs to see a signal. as for 1457 i have to check what that code is.
Old 04-19-2011, 11:29 AM
53JDMDC2's Avatar
1457 is a vaccum leak code. check all your vaccum lines, gas cap, and the canister.
Old 04-19-2011, 06:36 PM
gsr-t9303's Avatar
thanks 53JDMDC2 ima get on that asap. if i swap over a usdm oil pump can i just mount the sensor and will it work on my b18c???
Old 04-20-2011, 10:58 AM
gsr-t9303's Avatar
can any 1 help please i need to figure this out quick sense this is my only car.
if i swap the usdm gsr oil pump will the ckf sensor mount and work on my jdm b18c?
Old 04-20-2011, 08:22 PM
53JDMDC2's Avatar
if you put a usdm oil pump you will have the sensor and it will get rid of the code p1337. as for p1457 you need to find the vaccum leak.
Old 10-02-2011, 03:47 PM
siboost93's Avatar
quick question, i have a 96 civic ex with the 1337 code, will that make the car wanna stall and rpm gauge jump all over the place when tryin to drive it?
Old 10-02-2011, 05:14 PM
fcm
Old Fart
fcm's Avatar
http://www.ff-squad.com/technet/ckftrick.htm 94
Frany
09-23-2015 05:33 PM
gsr-t9303
03-30-2011 09:45 PM
JAMN J
09-11-2007 03:56 PM
EKen9
07-06-2002 04:20 AM
CivicEx95
05-09-2002 03:22 PM
Quick Reply: b18c CEL code p1337 & p1457??????
