Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic/Del Sol (1992 - 2000)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 05-13-2010, 07:06 AM   #1
azandford
Garage is empty, add now
iTrader Rating: (0)
Default Ignition Fuse Keeps Blowing Out
Car wouldnt start so i did all the normal things....tried a jump and then i bought a battery...didnt work. I checked the under hood fuses and noticed the ignition fuse was blown. i went and bought a new one. As soon as i turned the key to the on position i had some hope but as soon as i tried to start it it blew the fuse.
i tried it 4 more times. Every time the fuse blew right as i tried to turn it on. I have no idea what to do next. Please help!
azandford is offline   Reply With Quote
Old 05-13-2010, 07:41 AM   #2
azandford
iTrader Rating: (0)
Default Re: Ignition Fuse Keeps Blowing Out
bump cuz im stuck at advanced auto parts
Old 05-13-2010, 08:03 AM   #3
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
iTrader Rating: (0)
Does the fuse blow when the key is turned to ON(I)/ACC or ON(II) or only when turned to ON(III)/START?
__________________
Don't guess, troubleshoot.
Useful tech links -- FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV
RonJ@HT is offline   Reply With Quote
Old 05-13-2010, 08:06 AM   #4
azandford
iTrader Rating: (0)
only when you turn it to start
Old 05-13-2010, 08:09 AM   #5
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
iTrader Rating: (0)
Disconnect both starter wires to see whether this prevents the fuse from blowing.
__________________
Old 05-13-2010, 08:11 AM   #6
azandford
iTrader Rating: (0)
well im gonna have to buy some more fuses..lol
ok if it doesnt blow if then is it wiring to the starter or a starter issue? the starter is brand new
Old 05-13-2010, 08:19 AM   #7
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
iTrader Rating: (0)
If the fuse does not blow with the starter disconnected, then there's a short in the starter and it needs to be replaced.
If the fuse still blows with the starter disconnected, then the short is in the ignition switch or the wires between the ignition switch and starter.
__________________
Old 05-13-2010, 10:25 AM   #8
azandford
iTrader Rating: (0)
so i unplugged the wires and tried to start it and it did not blow the fuse
does this mean it is the starter at fault?
Old 05-13-2010, 10:47 AM   #9
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
iTrader Rating: (0)
Yes, there's a short inside the new starter.
__________________
Old 05-13-2010, 11:43 AM   #10
azandford
iTrader Rating: (0)
Thanks for the help. Ill update you when I get the starter tomorrow and hook it up
submit to reddit
Tags
blow, blowing, blown, car, civic, everytime, fuse, honda, ign, ignition, main, shorted, start, starter, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
