what would cause my back tire to wear on the inside?
i just got a allignment and replaced my struts and its still doing it.. im guesssing a bad trailing arm bushing?
Re: what would cause my back tire to wear on the inside?
yes it can be aligned, the dillweed alignment guy probably didnt notice the toe ends right in front of the gas tank under the back seat area of the car. also check for bent parts like they said. and if you are rollin slammed, im not even gonna answer why its happenin
well he really didnt give to much info thats why i kinda went with that.. cuz i used to have the same problem with my hatch.. but as far as the bent part goes some of the more experienced dudes should know
camber would be the camber arm that bolts to the inside of the wheel wheel. as far as toe goes, it could be a really jacked up lca or a slightly bent trailing arm. and even like i said before, the toe arm is a high thought suspect
EnjoyTheRideDC2
03-02-2006 04:05 AM
