b16 torque specs any 1.?
Old 07-31-2007, 07:04 PM
lilsicsoul's Avatar
Default b16 torque specs any 1.?
I try looking 4 it in the faQ section wit no luck....i need the torque specs for a b16a motor if any 1 has a link on this lemme noe thanx
Angel...
Old 07-31-2007, 07:23 PM
powerpro_69's Avatar
Default Re: b16 torque specs any 1.? (lilsicsoul)
me too nedd all the torque specs
Old 07-31-2007, 07:57 PM
pauld's Avatar
Default Re: b16 torque specs any 1.? (powerpro_69)
What torque? B16's dont make any! sorry....had to.....
Do you mean things like the head bolt torque specs, or rods, or mains,etc??
Old 07-31-2007, 07:58 PM
Tippyman's Avatar
Default Re: b16 torque specs any 1.? (pauld)
Negative 7.
Old 07-31-2007, 08:03 PM
mr.speaker's Avatar
I got the shop manual,but I'm not about to list all the tq specs for every single bolt
let me know what exactly you need
Old 07-31-2007, 08:23 PM
lilsicsoul's Avatar
Default Re: b16 torque specs any 1.? (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">I got the shop manual,but I'm not about to list all the tq specs for every single bolt
let me know what exactly you need</TD></TR></TABLE> head bolts and bolting down patern...its a obd0 b16 thanx
Angel...
Old 07-31-2007, 08:31 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilsicsoul &raquo;</TD></TR><TR><TD CLASS="quote"> head bolts and bolting down patern...its a obd0 b16 thanx
Angel...</TD></TR></TABLE>
honestly dude, you(or whoevers car this is) can afford a b16 swap but dont have a manual for your(or thier) car?
thats crazy talk.
I'll go open my good ole greasy shop manual and i'll take a pic of the bolt bolting down pattern for yah.... it'll be up in a bit.
But honestly, you(or they) gotta get a shop manual for that car, and one for the integra/civic/cr-v too, (for the b-sereis stuff.)
Old 07-31-2007, 08:39 PM
Tippyman's Avatar
Default Re: b16 torque specs any 1.? (89s1)
they do have them at the library too, lol.
Old 07-31-2007, 08:52 PM
89s1's Avatar
Default Re: b16 torque specs any 1.? (Tippyman)
As promised:
the head bolts you tighten in stages, to not warp anything....
The torque specs are:
Step 1: 22 ft/lbs
step 2: 61-63 ft/lbs (pre-1996 motors are 61 and post-1996 are 63.)
Old 07-31-2007, 10:17 PM
uberhaulin's Avatar
[QUOTE=89s1]honestly dude, you(or whoevers car this is) can afford a b16 swap but dont have a manual for your(or thier) car?
thats crazy talk.
lmao.. i owned a b16 months b4 i got a manual.. but your right he needs one
Old 08-01-2007, 02:17 AM
lilsicsoul's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">honestly dude, you(or whoevers car this is) can afford a b16 swap but dont have a manual for your(or thier) car?
thats crazy talk.
But honestly, you(or they) gotta get a shop manual for that car, and one for the integra/civic/cr-v too, (for the b-sereis stuff.)</TD></TR></TABLE> yes ur right its my first b16 loll i have a bunch of sohc books thanx 4 the pic
Angel....
Old 02-15-2010, 02:27 AM
New User
green69's Avatar
Contents [hide]
1 B16
1.1 JDM B16A (First Generation)
1.2 JDM B16A (Second Generation)
1.3 B16B (Type R)
1.4 B16A1
1.5 B16A2
1.6 B16A3
1.7 B16A4
1.8 B16A5
1.9 B16A6
2 B17
2.1 B17A1
3 B18
3.1 B18A
3.2 B18A1
3.3 B18B1
3.4 B18B4
3.5 JDM B18C
3.5.1 Highlights of B18C Spec R compared to standard B18C GSR
3.6 B18C1
3.7 B18C2
3.8 B18C3
3.9 B18C4
3.10 B18C5
3.11 B18C6
3.12 B18C7
4 B20
4.1 B20B
4.2 B20B/B20Z
5 B20A/B21A
6 B Series Transmissions
6.1 J1/S1
6.2 S1/YS1
6.3 Y1
6.4 YS1
6.5 S80
6.6 S80/Y80
6.7 S9B
6.8 Y21/Y80/S80/S4C
7 See also
[edit] B16
[edit] JDM B16A (First Generation)
The first VTEC engine Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
VTEC
Found in:
1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1990 JDM Honda CRX SiR (EF8)
1989-1990 JDM Honda Civic SiR (EF9)
Displacement: 1,595 cc (97.3 cu in) 1.6 liter
Compression: 10.2:1
Bore: 81.0 mm (3.2 in)
Stroke: 77.4mm
Rod Length: 134mm
Rod/stroke ratio: 1.745
Power: 160ps (118 kW) @ 7,600rpm & 15.5kgm (152 Nm) @ 7,000rpm
Redline: 8100 RPM
Transmission: S1/J1/YS1 (4.4 final drive), Y1 (4.266 final drive, cable clutch, optional LSD)
ECU code: PR3-003 (DA6/DA8), PW0-000 (EF8/EF9/DA6)
ODB0
[edit] JDM B16A (Second Generation)
Found in:
1991-1994 JDM Honda Civic Sir/SiRII (EG6)
1991-1993 JDM Honda Civic Ferio SiR (EG9)
1992-1995 JDM Honda CRX Delsol SiR (EG2)
1995-1998 JDM Honda Civic Sir/SiRII (EK4)
1995-1998 JDM Honda Civic Ferio Si (EK4)
Compression: 10.4:1
Stroke: 77.4mm
Rod Length: 134mm
Power: MT: 170ps (118.kW) @ 7,800rpm & 16.0kgm (156.91 Nm) @ 7,300rpm (AT: 160ps (114.0 kW) @ 7,300rpm & 15.6kgm (152.98 Nm) @ 6,500rpm)
Redline: 8200 RPM (AT: 7700 RPM)
Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
ECU code: P28 (EG2), P30 (EG2/EG6)
ODB1/ODB2
[edit] B16B (Type R)
VTEC
Found in:
1997-2000 JDM Civic Type R[EK9]
Compression: 10.8:1
Bore: 81 mm (3.2 in)
Stroke: 77.4 mm
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.607 in)
Power: 136 kW (185 PS) @ 8200 rpm & 16.3kgm (118 ft/lbs) @ 7500 rpm
Redline: 8400 rpm
Rev-limit: 9000 rpm
Transmission: S4C With Helical LSD (4.1 final drive, dual-synchromesh on 2nd, 3rd and 4th gears)
Vtec engagement @ 5800 rpm
ECU code: PCT
Note: This engine uses the same block as the Integra Type R (B18CR), which is taller than the B16a block (by approx 17mm), but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16.
[edit] B16A1
VTEC
Found in:
Early Integra, CRX, Civic'1.6i-VT'(EE8)(EE9)
Displacement: Template:Convert/aa 1.6 liter (1595)
Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
Compression: 10.2:1
Power: 150 hp (111 kW) @ 7600 rpm
Torque: 106 ftlb @ 7100 rpm
Redline: 8000 rpm
Transmission: Y2
aluminium casting
[edit] B16A2
VTEC
Found in:
1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
1992-1997 Honda Civic Del Sol EDM VTi (EG)
1996-1997 Honda Civic Del Sol USDM "VTEC"
1999-2000 Honda Civic USDM Si (EM1)
1999-2000 Honda Civic CAN SiR (EM1)
Compression: 10.2:1
Power: 160 hp @ 7600 rpm & 118 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 or S4C
Redline...8,000 RPM
Rev Limit...8,450 RPM
VTEC Engagement...5,500 RPM
aluminium casting
[edit] B16A3
VTEC
Found in:
1994-1995 Del Sol VTEC
Displacement 1,595 cc (97.3 cu in)
Power: 160 hp @ 7,600 rpm & 118 ft·lbf (160 N·m) @ 7,500 rpm
Redline: 8,200 RPM
Transmission: Y21
[edit] B16A4
VTEC
Found in:
1996-2000 Civic Si-RII (JDM version) (EK4)
Compression: 10.4:1
Power: 125.04 kW (170 PS; 168 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
Redline: 8200 rpm
Transmission: Y21
Note: Only offered with SiRs with manual tranmissions.
[edit] B16A5
VTEC
Found in:
Compression: 10.4:1
Power: 130 kW (177 PS; 174 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
Redline: 8000 rpm
Transmission: Y21
Note: Only offered with SiRs with automatic transmissions.
[edit] B16A6
VTEC
Found in:
1996-2000 Honda Civic - South Africa VTEC (EK)
Compression: 10.2:1
Power: 118 kW (160 PS; 158 bhp)
[edit] B17
[edit] B17A1
VTEC
Found in:
1992-1993 Integra GS-R (DB25)
Displacement: 1,678 cc (102.4 cu in)
Bore: 81 mm (3.189 in)
Stroke: 81.4 mm (3.205 in)
Rod/Stroke Ratio: 1.63
Rod Length: 132.28 mm (5.208 in)
Compression: 9.7:1
Power: 160 hp (120 kW) @ 7600 rpm & 118 ft·lbf (159 N·m) @ 7000 rpm
Came equipped with the YS1 cable trans, which was different than other cable B-series transmissions as it has a different input shaft.
[edit] B18
[edit] B18A
The B18A is not considered part of the modern B-series family. This engine shares many characteristics with the B20A/B21 See Honda B20A engine.
Non-VTEC
Found in:
1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
1986-1989 Accord EXL-S/EX-S (Japan)
1986-1989 Vigor MXL-S (Japan)
Displacement: 1,834 cc (111.9 cu in)
Compression: 9.4:1
Stroke: 89 mm (3.5 in)
Dual Keihin Carbs
Power: 100 hp (97 kW) @ 6100 rpm & 128 ft·lbf (164 N·m) @ 4700 rpm
Transmission: A2N5, E2N5
[edit] B18A1
NON -VTEC
Found in:
1990-1993 Acura Integra usdm "RS/LS/GS" (DA9, DB1)
Compression: 9.2:1
Rod Length: 137.01 mm (5.394")
Rod/Stroke Ratio: 1.54
Redline: 6500 rpm
Rev Limiter: 7200
Programmed fuel injection
Power: 90-91 Only: 130 bhp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
Power: 92-93 Only: 140 bhp (100 kW) @ 6300 rpm & 126 ft·lbf (171 N·m) @ 5000 rpm
Transmission: 90-91: A1,S1, cable
Transmission: 92-93: YS1, cable
[edit] B18B1
NON-VTEC
Found in:
1994-2001 Acura Integra "RS/LS/GS/SE" (DC4/DB7)
Compression: 9.2:1
Rod Length:5.394in
Power: 142 hp (106 kW) @ 6300 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
Redline: 6800 rpm
Rev Limit: 7200 rpm
Transmission: Y80/S80
[edit] B18B4
NON-VTEC
Found in:
1996-2000 Honda Ballade 180i
Compression: 9.2:1
Rod Length: 137.01 mm (5.394 in)
Power:
Redline: 7200 rpm
142 hp (106 kW) @ 7000 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
Transmission: Y80/4254245
[edit] JDM B18C
SPEC R
VTEC
Found in:
95-00 JDM Honda Integra Type R DC2
95-00 JDM Honda Integra Type R DB8
Rev-limit: 8600 rpm
Power: 200ps (147.10 kW/ 197.26 HP) @ 8000 rpm & 17.5kgm @ 7500rpm (96 spec) 18.5kgm @ 6200 rpm (98 spec)
Transmission: S80 with Helical LSD
S80 spec: J4D (96specR & 4.4 final drive), N3E (98specR & 4.785 final drive)
Displacement: 1,797 cc (109.7 cu in)
Compression: 11.1:1
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
VTEC Engagement @ 5800 RPM
ECU code: P73-003 (96specR) P73-013 (98specR)
(Source: BMI Vol.1 Type R Legend)
SiR/GSR
VTEC
Found in:
93-95 JDM Honda Integra Si (DB8, DC2)
95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
98-99 JDM Honda Integra SiR-G (DB8, DC2)
Identification: Black valve cover with dual runner intake manifold
Rev-limit: 8000 Rpm
Power: 132.39 kW (180 PS; 178 bhp) @ 7200 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
Compression: 10.6:1
ECU code: P72
[edit] Highlights of B18C Spec R compared to standard B18C GSR
1. Camshaft - Wide-angled, high-lift, high-durability camshaft
2. Exhaust Valve Spring - High-lift, dual-layered spring
3. Spark plug - High-heat-type #7 platinum plug
4. Engine Stiffener - Aluminum die-cast, high-durability, one-piece type
5. Crankshaft - Full-counterweight, 8-weight, high-output, custom crankshaft
6. Connecting Rod - Custom TypeR rod, high-durability, lightened
7. Pistons - High-compression, low-friction, custom pistons
8. Inlet Valves - Lightened inlet valves
9. Intake Manifold - Custom tuning, single-port type.
10. Throttle Body - 62mm wide-mouth throttle body.
11. Inlet Valve Springs - High-lift, flat-surfaced, dual-layered spring
12. Port Buffing done by hand
13. Fastening of Connecting Rod done with micrometer
14. All stainless steel headers
[edit] B18C1
VTEC
Found in:
1994-2001 USDM Integra GS-R (DC2/DB8)
Compression: 10.0:1
Power: 170 hp (125 kW) @ 7600 rpm
Torque: 128 ft·lbf (175 N·m) @ 6200 rpm
Redline: 8100 rpm (Fuel cut-off @ 8200 rpm)
VTEC Engagement @ 4400 rpm
Transmission: Y80(No LSD) 5-Speed Manual Transaxle
[edit] B18C2
VTEC
Found in:
1994-1999 Honda Integra VTi-R
AUDM Spec 1993-1999 Honda Integra VTi-R
Compression: 10:1
Power: 168 hp (125 kW) @ 7600 rpm
Redline: 8200 rpm
Fuel Cut: 8300 rpm
[edit] B18C3
VTEC
Found in:
1995-1998 Honda Integra Type R
Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft·lbf/172 N·m @ 7500 rp
[edit] B18C4
[VTEC] vtec
Found in:
1996-2000 UK Civic 1.8i VTi 5-door Hatch (MB6)
1996-2000 UK Civic 1.8i VTi-S (Limited Edition) 5-door Hatch (MB6)
1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
1998-1999 EU Civic 1.8i VTi 5-door Hatch (MB6)
VTEC engagement@4,400 rpm
IAB open@5,750 rpm
Compression: 10.0:1
Power: 169 hp (124 kW) @ 7600 rpm & 117 ft·lbf (158 N·m) @ 6200 rpm
Limit: 8,100 rpm
Transmission: S9B w/Torsen LSD.
0/100 km/h : 7.9 seconds (8.5 Aerodeck)
[edit] B18C5
VTEC
Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Compression: 10.6:1
Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (180 N·m) @ 7300 rpm
Redline: 8400 rpm (Fuel cut-off @ 8500 rpm)
VTEC Engagement @ 6000 rpm
Transmission: S80 w/LSD
[edit] B18C6
VTEC
Found in:
1998-2001 Honda Integra UK and Euro Spec Type R
Type: 1.8 litre 16v DOHC 4 cylinder in-line
Compression: 11.1:1
Air intake diameter: 62 mm (2.4 in)
Power: 190 PS/140 kW @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm
Redline: 8400 rpm
Rev-limiter: 8700 rpm
Vtec engagement: 5700 rpm
[edit] B18C7
VTEC
Found in:
1996- Honda Integra Type R (Australia)
Power: 193 PS/189 hp (141 kW) @ 8200 rpm & 127 ft·lbf/172 N·m @ 7500 rpm
[edit] B20
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
[edit] B20B
1996-1998 specs
NON-VTEC
Found in: USDM and JDM Honda CR-V, Honda Orthia
Displacement: 1,973 cc (120.4 cu in)
Power: 126 hp (94 kW)) @ 5400 rpm
Torque: 131 ft·lbf (178 N·m) @ 4300 rpm
Rod length: 137 mm (5.4 in)
Compression: 8.8:1 or 9.2:1
Bore: 84 mm (3.3 in)
Redline: 6300 rpm
[edit] B20B/B20Z
1999 - 2000 specs
NON-VTEC
Found in: USDM CRV as a B20Z, JDM Honda CR-V and Honda Orthia as a B20B
Power: 146 hp (109 kW)) @ 6200 rpm
Torque: 133 ft·lbf (180 N·m) @ 4500 rpm
Rod length: 137 mm (5.394 in)
Compression: 9.6:1
Redline: 6700 rpm
[edit] B20A/B21A
[edit] B Series Transmissions
Note: All B series Transmissions are interchangeable. YS1 casing can take S80 Internals or a hydraulic conversion kit can be used to operate hydraulic transmissions in cable operated models.
[edit] J1/S1
Found in: Integra XSI/RSI (DA6)
Type: Cable
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
R: 3.000
FD: 4.400
[edit] S1/YS1
Found in: 1990-93 USDM Integra LS/RS (DA)
Type:cable
1st: 3.230
2nd: 1.901
3rd: 1.269
4th: 0.966
5th: 0.742
R: 3.000
FD: 4.266
[edit] Y1
Found in: CRX/Civic (optional LSD)
Type: Cable
1st: 3.166
2nd: 2.052
3rd: 1.416
4th: 1.103
5th: 0.870
R: 3.000
FD: 4.266
[edit] YS1
Found in: Integra 92-93 XSI/RSI (DA6, DA9)
Type: Cable
1st: 3.307
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.880
R: 3.000
FD: 4.400
[edit] S80
Found in: Integra Type R 98+ (LSD)
Type: Hydraulic
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.034
5th: 0.787
R: 3.000
FD: 4.785
[edit] S80/Y80
Found in: JDM SiR-G (optional LSD) / 94+ USDM GS-R (no LSD)
Type: Hydraulic
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
R: 3.000
FD: 4.400
[edit] S9B
Found in: EDM UKDM MB6 (LSD)
Type: Hydraulic
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.848
R: 3.000
FD: 4.266
[edit] Y21/Y80/S80/S4C
Found in:
JDM 96-97 Integra R(LSD)
JDM Civic R [EK9](LSD)
JDM Civic SiR [EK4, EG6]
JDM CR-X DEL SOL SIR (EG2)(optional LSD)
USDM DEL SOL VTEC (EG2)(OPTIONAL LSD)
Type: Hydraulic
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
R: 3.000
FD: 4.400
Old 02-15-2010, 06:52 AM
gringo7718's Avatar
Yea the H-T search sucks sometimes. I just googled it and here ya go
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-b-series-torque-specs-953151/
Old 02-15-2010, 12:43 PM
D16SiHatch's Avatar
guy above me ^ helpful
guy above him.. wtf.
Ninja Mike
09-28-2007 11:08 PM
hondatuningboi96
08-18-2007 06:54 PM
electron_si
04-18-2007 02:42 PM
G-reX
10-06-2003 04:55 PM
Quick Reply: b16 torque specs any 1.?
