Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord (1990 - 2002)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 01-07-2010, 09:45 AM   #1
uberEFtuner
1991 Honda Civic
My Garage
uberEFtuner's Avatar
iTrader Rating: (0)
Default What is your tire pressure???
Post your opinions and your preference for tire pressure.
I have a 93 accord LX with 15" wheels. Inside the door it says 29psi but the car came with 14" wheels. The tires look flat when at 29psi.
-I always had my 91 civic with 14" wheels at 35psi.
uberEFtuner is offline   Reply With Quote
Old 01-07-2010, 09:49 AM   #2
TheMuffinMan
He knows where you live!
Garage is empty, add now
TheMuffinMan's Avatar
iTrader Rating: (1)
Default Re: What is your tire pressure???
Should be 32 PSI, it's written in your door
__________________
2004 NFR S2000
Quote:
Originally Posted by slomofo
I think TheMuffinMan is Chuck Norris. Seriously, you can't find the TheMuffinMan,TheMuffinMan finds you.
TheMuffinMan is offline   Reply With Quote
Old 01-07-2010, 10:02 AM   #3
GhostAccord
1996 Honda Accord
GhostAccord's Avatar
iTrader Rating: (0)
Send a message via MSN to GhostAccord
It is stated on the tire sidewall as well. Most times I go buy the tire manufacturers recommended tire pressure. Between the two they are probably within 3-4 psi of each other.
GhostAccord is offline   Reply With Quote
Old 01-07-2010, 10:39 AM   #4
Conan
Conan's Avatar
iTrader Rating: (0)
If you have a decent name brand tire, the manufacturer may have fitment guide that has a good place to start. Or the place you purchased them from may have a fitment guide with the info for your car. The number on the sidewall is normally MAX pressure. Another old rule is take the vehicle weight and divide by 100. then add 2 psi to the heavier end. And add 2 psi if the suspension is stock.
Conan is offline   Reply With Quote
Old 01-07-2010, 11:23 AM   #5
TheMuffinMan
iTrader Rating: (1)
Quote:
That's always the max tire pressure I've seen............ which is like 80 + psi
__________________
2004 NFR S2000
Old 01-07-2010, 11:37 AM   #6
GhostAccord
1996 Honda Accord
iTrader Rating: (0)
Quote:
You are correct about the Max pressure. But the stamp on the side of my tires says 35psi Max and that is what I have always put in them. No odd wear and they were on my car for three years. Still have lots of tread too.....They never wore down the center like an over inflated tire would. guess I got lucky eh!
Old 01-07-2010, 11:57 AM   #7
02 accord
2002 Honda Accord
02 accord's Avatar
iTrader Rating: (0)
Send a message via AIM to 02 accord
I run 39 psi in my 02.
__________________
2002 Accord SE 5 speed
Quote:
Originally Posted by Hidenplanvew
why are you scared to go under the car? Just get in do what you have to do and get out its not that scarry
02 accord is offline   Reply With Quote
Old 01-07-2010, 12:47 PM   #8
alkoholikwun
alkoholikwun's Avatar
iTrader Rating: (0)
around 37psi
alkoholikwun is offline   Reply With Quote
Old 01-07-2010, 05:07 PM   #9
djkurious
djkurious's Avatar
iTrader Rating: (0)
32 PSI
__________________
95 Accord EX MT
djkurious is offline   Reply With Quote
Old 01-07-2010, 07:45 PM   #10
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
iTrader Rating: (0)
35 PSI in my 16" Rota.
__________________
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Quote:
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 01-07-2010, 08:59 PM   #11
Bright13
1990 Honda Accord
My Garage
iTrader Rating: (0)
50 psi, but i have 205/40 r 17s. I think I had like 34-36psi in my stock tires, which were 185/70 r14s i believe, which were stock size tires on my '90 lx.
Bright13 is offline   Reply With Quote
Old 01-08-2010, 01:23 AM   #12
aasaa666
aasaa666's Avatar
iTrader Rating: (0)
Every tire brand and model has their own max psi like everyone here is saying. The door jam recommended pressure is the minimum recommended by Honda on controlled conditions. Tire pressure changes during hot or cold, elevation, and depends on what you fill the tire with. So if you live in hot places like the desert of Nevada then Id recommend you fill it to minimum pressure and don't go over the max indicated on the tire sidewall. I live in tropical weather, when the tire heats up it rises 2-3 psi. So I put mine at 36 psi. just because it looks flat doesn't mean it is, you might get yourself hurt if the road is slippery or wet when you over inflate it. so please don't.
aasaa666 is offline   Reply With Quote
Old 01-08-2010, 09:57 AM   #13
bigsnorlax
bigsnorlax's Avatar
iTrader Rating: (0)
Quote:
correct, but also having it under inflated can cause you to hydroplane easier in wet conditions because of the increase in surface area atleast my drivers ed book said that. My tires say 35, and if yours are stock, id say thats the average. Just look into what the tires say
__________________
1996 Accord lx 4 cylinder F22B2 5 Speed
bigsnorlax is offline   Reply With Quote
Old 01-08-2010, 01:49 PM   #14
accord_raffi
1999 Saab 9-3
My Garage
accord_raffi's Avatar
iTrader Rating: (0)
Send a message via AIM to accord_raffi
my tires handle more boost than my engine. wooooo
__________________
1996 Turbo Honda Accord LX *SOLD*
1999 Saab 9-3 Viggen *Current*
CD Squad Member #196
accord_raffi is offline   Reply With Quote
Old 01-08-2010, 03:49 PM   #15
fleetw00d
fleetw00d's Avatar
iTrader Rating: (0)
The tires on all four of mine list 44 psig max. Typically run them mid to upper 30's. 40 for a long trip with a load. No abnormal pressure related wear. Keep in mind that most of the manufacturer's recommended numbers are a compromise among tire life, handling, comfort, etc. Running them on the high side, while it may be a stiffer ride (which I suspect many of us prefer) improves handling and reduces rolling resistance, which improves gas mileage.
__________________
90 LX 4dr 5 spd 315,000 . . . . . . . . . . . . . . . . . 93 LX 4dr 5 spd 137,000
93 EX 4dr auto 153,000 . . . . . . . . . . . . . . . . . 93 LX Wagon auto 191,000
99 Ford E350 197,000 . . . . . . . . . . . . . . . . . . 05 Town Car 65,000
fleetw00d is offline   Reply With Quote
Old 01-08-2010, 04:15 PM   #16
j3wman
j3wman's Avatar
iTrader Rating: (0)
40 PSI on 15" Wheels
25 in front when at the strip
j3wman is offline   Reply With Quote
Old 01-08-2010, 06:42 PM   #17
WHEEELMAN
WHEEELMAN's Avatar
iTrader Rating: (0)
17" rims. Falken 912 w/ 215-50 profile. 41 front/39 rear
WHEEELMAN is offline   Reply With Quote
Old 01-11-2010, 10:08 AM   #18
professorman
iTrader Rating: (0)
i have always ran between 35-37 and occasionally even 40 psi as well in my 215/45/17. I always get edges of my tires wearing off more than the middle. I know with over-inflation is supposed to cause the middle to wear more, but I have yet to see one of my tires that the middle wear more. This was always the case, even with stock suspension.
I am thinking of just running 32psi now and see if it correct the problem.
__________________
94 5spd Accord -270k | 99 Accord Auto -120k | 00 BMW 528i | 03 Suzuki GSX-R1000 | 04 Honda Aquatrax Jet Ski
RoopsPhoto.com | facebook.com/RoopsPhotography
professorman is offline   Reply With Quote
Old 01-11-2010, 11:40 AM   #19
alvarado626
alvarado626's Avatar
iTrader Rating: (0)
I got 0 PSI one of my tires get flat this Morning When i Got to My Car This Morning My Car Was Uneven WTF
__________________
Real cars are built, not bought!
http://www.cindysinsurance.com/
alvarado626 is offline   Reply With Quote
Old 01-24-2013, 05:34 AM   #20
Chaulkie
iTrader Rating: (0)
I was advice by a mechanic to remove the themostat of my Honda accord Ex 2005. he said the thermostat is ment for cold regions and not for places like Nigeria with 45 dgress celcius. Should i remove it or leave it? i need advice to proceed
Chaulkie is offline   Reply With Quote
Old 01-24-2013, 05:39 AM   #21
coolkidirish
coolkidirish's Avatar
iTrader Rating: (0)
mine is usually 34psi, but then my slicks are 15-18psi
coolkidirish is offline   Reply With Quote
Old 01-24-2013, 07:57 AM   #22
vega66lm
iTrader Rating: (0)
I keep the tires psig on my 95' Honda Accord at 40 and runs fine. I may have to drop the psig on the rear tires by 2-3 psig. The tire size is 185/75 R14 and Max. 44 psig. So far, the car runs fine and looking to save the most gas.
vega66lm is offline   Reply With Quote
Old 01-24-2013, 11:01 AM   #23
TheMuffinMan
iTrader Rating: (1)
Quote:
How is this anyway related to tire pressure from 2 years ago?
Plus, you're in the wrong section (90-02 Accords)
Plus, you don't say why the thermostat change was recommended in the first place. If the car is running fine, don't mess with it.
__________________
2004 NFR S2000
Old 01-24-2013, 02:58 PM   #24
EfyourK
EfyourK's Avatar
iTrader Rating: (0)
32 psi alllllll day!
EfyourK is offline   Reply With Quote
Old 01-24-2013, 11:26 PM   #25
holmesnmanny
iTrader Rating: (0)
lol good luck NOT blowing your tire when you try to reach 80 psi.. I assume that's a joke
__________________
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is offline   Reply With Quote
submit to reddit
Tags
1994, 2000, 2001, 95, 96, 99, accord, civic, cold, honda, lx, pressure, recommended, tire, tyre
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
