| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Used Cars | Garage | Vendor Directory |
#1 | |||||
1996 Honda AccordJoin Date: Aug 2009
#2 |
as far as i know the only bad side effects are only being able to pass most visual emissions tests and that it will make your car louder (which you may like). it'll increase flow a bit. 1/10 of a HP FTW!!!!!
lol jk. i'm guessing you are thinking about this because it is clogged.
__________________
1993 Integra LS Sedan 5 Speed ~RIP~ 1994 Accord EX Coupe 5 Speed |
#3 | |
Quote:
If you've an OBD2 equipped vehicle, 1) You'll forever have to contend with the CEL lamp glaring in your face when the secondary O2 sensor goes bug f**k. 2) You'll be presented with Increased Noise, which will beget increasing attention by the police which will bring forth such wondrous things like Notice of Demands; those pesky legal thingies which force you to fix the *&*^% thing. 3) IF you do make it to your next inspection cycle, they will reject you and demand it be replaced before you darken their door again. Now, if you want to do it correctly, get a high-flow cat. Basically, it's a stock converter that's bigger, thus is can flow more. You'll be happier, your neighbor will be happier and the police will go bother someone else. Sounds like a win/win to me P
__________________
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare) One more "What's the Top Speed..." thread and I think I'll flame someone
#4 | |
Quote:
we're lucky to have you around here P!
__________________
#5 |
don't forget it willll hurt your mpg ... and since f22/f23's are low compression motors ... sure suppose you get that .000005 hp in the high end but you will lose alot more low end torque
#6 | |
1995 Honda AccordJoin Date: Jun 2007
Quote:
YOU DO GAIN A FEW THOUGH! |
#7 |
as far as the CEL ... some ppl have found that using a "Spark Plug Defouler" fixes that ... although i've yet to try it myself
http://www.honda-tech.com/showthread...light=defouler |
#8 | |
1999 Honda AccordMy Garage |
Quote:
Gutting the cat will increase flow and increase gas milage. Not much of an increase unless you change out the muffler then you could obtain a 1/2 mpg increase. *personally on my f23 i knocked out the honeycomb after the O2 sensor on my cat and not check engine light occured. cant remember if f22 has the same cat/ P_adams- you would hate to be my neighbor ~ my truck, car and bike are all unrestricted flow, haha.
__________________
99 ACCORD COUPE 5SPEED F23A1 BOOSTED! 13.83 @102.83 mph 236WHP/255TQ@10 PSI :.63TRIM T04E, AEM Tuned w/ 550CCs Inj. Check out my Garage! |
#9 |
gutting cat will increase flow but will not increase gas mileage ... i don't know where you heard that ... i couldn't say how much you lose because you would need to dyno test the same car with a working cat and a gutted cat and compare ... i just know when i gutted the cat on my f23 it felt like it lost some low end torque
#10 | |
Quote:
I think the perceptions of power gains lays with the increase in noise, not what you may feel thru the Dyno-Butt. The increased noise plays to the stereotypical male perception of louder is better / more powerful. P
__________________
#11 | |
Quote:
Heres a good link for saving gas heres whats qouted out of the exhaust section, "virtually ending turbulent back pressure that can hold your vehicle much the way drag does. The average improvement to gas mileage is between 1 and 2 mpg, which varies by vehicle." http://www.autoanything.com/ResearchGuides/Savegas/ first link after googling. My f23 incresed by 2 mpg after complete exhaust and half gutted cat, checking mpg the correct way.
__________________
#12 | |
Quote:
#13 | |
Quote:
P
__________________
#14 |
New User
no use in doing since accords are economy cars. just get an upgraded cat from magnaflow if you want the vehicle to breathe better. japanese vehicle have been made to perform better with them for 20+ years.
#15 |
#16 | |
Quote:
![]() careful! dont want to make the creator of the internet mad P! he might take it away.... LOL!
__________________
#17 | |
Quote:
There are a few reasons why you think you might have lost torque. There's a lot going on when you change your exhaust. If you go with something radical enough, you'll be changing your intake, tune, etc. etc. to compensate for the loss in back pressure or increase in gas scavenging, which is higher exhaust gas velocity. Exhaust setups that are too large will result in more cooling of the exhaust gases which leads to lower exhaust gas velocity (because cool air is denser than hot air). To make up for this, you'll need more air entering the engine to create more hot exhaust gases to keep velocity up. This is also why exhaust wrap can sometimes help on a larger exhaust, by increasing the amount of exhaust flow by providing insulation so as to keep up exhaust gas velocity. When you bring in more air, you'll need more fuel, which means another tune so that you don't encounter a lean condition. Exhaust setups that are too small will lead to excessive back pressure and loss of torque/hp all over the powerband due to the engine not being able to push out all of the exhaust gas from the cylinder. In this case the charge of air coming in is heated by the left over exhaust gas and you could encounter a rich condition, though unlikely as your stock tune is set for your stock exhaust, which should be the most restrictive exhaust you ever use. There's more to it than that, like dealing with exhaust pulses, but that's a dark art that I really don't know much about, and something you probably shouldn't really be concerned with unless you're trying to squeeze out every single ounce of power possible. |
#18 |
well that's all very interesting but in my overall experience ... it made my mpg drop and made my car feel gutless at lower rpm ... i have a cold air intake ... 4-2-1 header ... full catback exhaust ... and of course the gutted cat ... i'm sure a tune would help but i still think that the gutted cat is the real problem ...
anyone else with a 6th gen f23 gut their cat? |
#19 | |
Quote:
#20 |
i wish i knew, all i know is ever since i had to gut my cat i've had problems
#21 | |
Quote:
There is a consideration which almost always gets forgotten in these discussions; this being Scavenging. This is a phenomenon utilized by engineers to improve the volumetric efficiencies of automotive power plants through the application of Fluid Dynamics and Newton's Law whereas a "mass in motion stays in motion". In effect, the exhaust gasses traveling thru the exhaust system generates a vacuum behind the exhaust valve when it closes. When the exhaust valve next opens, this vacuum is instrumental in drawing spent combustion gasses out of the combustion chamber and conversely pulling a fresh charge into the cylinder. (That's why there is always some "Overlap" where both the intake and exhaust valves are open ....) The exhaust system is designed to facilitate this exhaust velocity by the careful selection of not only the length of the system but also (wait for it) the pipe diameter as well. What happens when you enlarge the exhaust pipe's diameter? The velocity of the exhaust gasses DROPS; it moves more slowly through the pipe. Why? You're now pumping the same mass of gasses thru a larger area, thus it slows down. What does this do (You ask)??? It decreases the vacuum effect behind the exhaust valve thus decreasing the scavenging effect. Less scavenging effect, less air/fuel through the engine and ultimately less power. True, there are advantages to large(er) diameter pipes, but that is more for systems which are boosted and operate at positive atmospheric pressures. In this case, you're literally pushing the gasses thru. This all raises some serious questions. Why go to all the expense of a larger set of pipes / muffle if you're still dealing with restrictions upstream? Even with headers, you're still dealing with a 2" collector (They do hook up to stock systems, RIGHT). P
__________________
#22 |
Look 4 posts up, or better yet, read through the entire thread next time.
#23 |
i have a straight pipe on mine.. i lost my bottom end torque and instead of buying a test pipe my whole exhaust is welded 2 1/4 piping.. i got a ticket so i bought a used cat for 10bux now im gonna put my DC headers on thats been sitting
| Bookmarks |
| Tags |
| 1996, accord, cat, catalytic, cel, converter, flo, high, honda, light, lx, oxygen, put, s2000, secondary, sensor |
